Why is the work done in moving a charge around a circular path zero?
In summary, when a charge is moved around a circular path, the work done is 0 because the distance between the charges remains the same, resulting in a potential difference of 0. However, some torque or external force may be required to move the charge along the circular path. This is similar to a satellite in a circular orbit, where gravity acts at 90 degrees to the direction of motion and does not do any work, and no other forces are needed to maintain the orbit.
Crystal037
167
Why the work done in moving a charge around any circular path inside which another point charge is kept at its centre is 0? Shouldn't it need some kind of torque? If there is no work done then the charge should keep revolving
W=delta(V)q
Work done in moving a charge around the circular path is 0 because the distance between the charges remain the same so there is no potential difference and delta(V)=0 but I thinkk some torque or external force must be required to move the charge around the circula path
The work done by the electric force is zero because that force acts at 90 degrees to the direction of motion. (For work to be done by a force, that force must have a component in the direction of the displacement.) There may or may not be other forces involved, but they are not needed.
(Think of a satellite in a circular orbit around the earth. Gravity pulls it in a circle but does no work. And no other forces are needed to maintain that orbit.)
Related to Why is the work done in moving a charge around a circular path zero?
1. What is work done in moving a charge?
The work done in moving a charge is the amount of energy required to move a charge from one point to another. It is a measure of the force applied to the charge and the distance it is moved.
2. How is the work done in moving a charge calculated?
The work done in moving a charge is calculated by multiplying the magnitude of the charge by the potential difference through which it is moved. This can be expressed as W = qV, where W is the work done, q is the charge, and V is the potential difference.
3. What is the unit of measurement for work done in moving a charge?
The unit of measurement for work done in moving a charge is joules (J). Since work is a form of energy, it shares the same unit of measurement as energy.
4. How does the direction of the charge's motion affect the work done?
The direction of the charge's motion does not affect the work done. The work done only depends on the magnitude of the charge and the potential difference through which it is moved, not the direction of the motion.
5. How is the work done in moving a charge related to electrical power?
The work done in moving a charge is directly related to electrical power. Electrical power is the rate at which work is done, and it is calculated by dividing the work done by the time taken. Therefore, the work done in moving a charge is equal to the electrical power multiplied by the time taken.
