Why is there a sonic boom at Mach 1.5?
  • I
  • Thread starter Dead Rabit
  • Tags
    Mach
In summary, a sonic boom is created when an object travels at or above the speed of sound, causing a cone-shaped region of high-pressure air which expands outwards after the object passes. This phenomenon is caused by shock waves forming in various places on the object, and can be studied through books on aerodynamics. The sound of a sonic boom is the remnants of these shock waves spread out in time, and multiple initial shock waves can result in multiple booms.
Dead Rabit
It's my understanding that a sonic boom is the doppler effect taken to the extreme, with a sound emitting object traveling at the speed of sound, your building the ultimate constructive wave.
I want to know, if you were traveling at Mach 1.5, why doesn't the sound you're generating cancel itself out? (in layman's terms)
More precisely, if you understood how the frequency of the sound generated by your aircraft varied at different speeds as it's travelling, why can't you:
a) choose to travel at a speed that would destroy the sound wave produced?
b) deliberately place the elements of your design that cause drag (and hence, noise) offset by half the wavelength?
Or at least I assume you can't because it still takes 8 hours to fly to America from the UK, 50 years after Concorde was invented =P.
Cheers,
J
Once you hit Mach 1, you're no longer generating sound waves in the traditional sense. Further increases in velocity do not create sound waves with different frequencies. What's happening is that you're pushing the air out of the way faster than it can form a wave in the first place. This creates a cone-shaped region of high-pressure air which expands outwards after the plane passes, which is where the sound comes from. Increasing the plane's velocity just elongates this cone.
Likes phinds, CWatters and FactChecker
Interesting, are there any topics you can recommend I read up on to improve my understanding of this phenomenon?
"sonic boom" only seems to bring up high level synopsis.
Other than wikipedia, I'm afraid I can't. :cry:
The sonic boom is simply a moving shock wave. Shock waves form in many places on the wing and in the jet exhaust. In fact, in the jet engine exhaust, there is a nested set of shock waves, one inside the other. There is a great deal of information in books on aerodynamics. You can go to Amazon and find many books by searching "aerodynamics shock wave". I have never studied it, so I can not recommend any particular book.
Search on ' formation of shock waves on aircraft ' and ' NASA supersonic aircraft '
At a distance from the high speed object, the air will have slowed to below sonic speed. (i.e. When the object has passed) the impulse will have spread out and the particle speeds will no longer be sonic. What you hear is not a 'shock wave' but the remnants of it, spread out in time on the journey to the ground into a single pulse of long duration. Boom not crack.
You get more than one boom when there are multiple initial shock waves.
Likes FactChecker
Related to Why is there a sonic boom at Mach 1.5?
1. What causes a sonic boom at Mach 1.5?
A sonic boom is caused by a rapid increase in pressure and temperature as an object, such as an aircraft, travels at or above the speed of sound (Mach 1). At Mach 1.5, the object is moving faster than the speed at which sound waves can travel, resulting in a shock wave.
2. Is Mach 1.5 the only speed at which a sonic boom occurs?
No, a sonic boom can occur at any speed above Mach 1. However, the intensity of the boom increases as the speed of the object increases.
3. Can a sonic boom be heard on the ground?
Yes, a sonic boom can be heard on the ground as a loud noise similar to an explosion. However, the intensity of the boom decreases the further the object is from the ground.
4. Are there any negative effects of a sonic boom?
Yes, sonic booms can cause damage to buildings and disrupt wildlife. They can also be a nuisance to people living near airports where supersonic flights occur.
5. Can a sonic boom be prevented?
Currently, there is no technology that can completely eliminate sonic booms. However, advancements in aircraft design and technology have helped reduce the intensity and frequency of sonic booms. In addition, regulations and guidelines are in place to limit supersonic flights over populated areas.
  • Other Physics Topics
15K
  • Mechanical Engineering
  • General Engineering
15K
