Why is there atmosphere at the equator?
In summary, the bulge at the equator, which is 42km according to Wikipedia, results in a point on the equator being 21 km further from the center of the Earth than the poles. This difference in distance does not significantly affect the force of gravity between the two points. The equatorial bulge is caused by the Earth's rotation, which also results in the atmosphere being centrifugally bulged at the equator. This is not a coincidence, but rather a cause and effect relationship. This can be seen in the example of a puddle of water fitting perfectly into a hole it sits in. More information on this phenomenon can be found in the provided links.
peanutaxis
25
The bulge at the equator, which Wikipedia says is 42km, means that a point on the equator (at sea level) is 21 km further away from the centre of the Earth than the poles. That's two and a half Everests!
I think that the difference in the force of gravity (gravity only) between the equator and poles will not be much, and it is gravity alone that keeps the atmosphere here, so why on Earth is standing at the equator not like standing at the height of nearly 2.5 Everests?!
Am I right in assuming that that very spin which gives the equatorial bulge also ensures that the atmosphere - spinning with the land - is...centrifugally bulged the the equator, too?
If so, it almost feels like a happy coincidence.
Yes.
It is not a coincidence. It's cause and effect.
Same as why the puddle of water manages to exactly fit the hole it sits in.
Likes jim mcnamara
Simon Bridge said:
Yes.
Thanks. Yes, I suppose so [puddle].
Related to Why is there atmosphere at the equator?
1. What causes the atmosphere at the equator?
The atmosphere at the equator is caused by the Earth's rotation and the sun's radiation. As the Earth rotates, the equator experiences the most direct sunlight, resulting in warmer temperatures and creating a zone of low pressure that allows for the atmosphere to exist.
2. Why is the atmosphere thicker at the equator?
The atmosphere is thicker at the equator due to the Earth's rotation. The centrifugal force created by the Earth's rotation causes the atmosphere to bulge at the equator, resulting in a thicker layer of atmosphere compared to the poles.
3. Does the equator have a different type of atmosphere?
No, the atmosphere at the equator is not fundamentally different from the rest of the Earth's atmosphere. However, the equator does experience unique weather patterns and atmospheric phenomena due to its location and the influence of the sun's radiation.
4. How does the atmosphere at the equator affect weather patterns?
The atmosphere at the equator plays a significant role in shaping weather patterns around the world. The warm temperatures and low pressure at the equator create a convection current, which drives global wind patterns and helps distribute heat and moisture around the Earth.
5. Can the atmosphere at the equator change?
Yes, the atmosphere at the equator can change due to various factors such as changes in global temperatures, ocean currents, and human activities. Climate change, for example, can impact the equatorial climate and result in changes in the atmosphere's composition and weather patterns.
  • Earth Sciences
  • Earth Sciences
  • Earth Sciences
9K
  • Astronomy and Astrophysics
