Why is there now evidence of a lag time in the photoelectric effect?
In summary: The photoelectric effect is caused by the absorption of a photon by a target atom. As a result, an atomic electron is emitted or promoted to a bound open orbital.
qnt200
From: https://opentextbc.ca/universityphysicsv3openstax/chapter/photoelectric-effect/
"The photoelectric effect has three important characteristics that cannot be explained by classical physics: (1) the absence of a lag time, (2) the independence of the kinetic energy of photoelectrons on the intensity of incident radiation, and (3) the presence of a cut-off frequency."
How to interpret the absence of a lag time, ie instantaneous momentum.
Mechanically speaking, if we place an object on the edge of a table, any slightest action on the table will immediately cause the object to fall. However someone had to put the object on the edge of the table.
I think the example is equivalent to an electron in a photo effect. A certain amount of energy is needed to allow the electron to be very weakly bound to the surrounding atoms.
Greetings,
That condition is satisfied by the electronic structure of the atom itself. No "preparation" by the incident radiation field is required.ES
Likes qnt200
No. The electrons emitted in the photoelectric effect are already weakly bound to the surrounding atoms. At least, that's the case in the most common experiments to demonstrate the effect, which use metals. In experiments with non-metals, the cutoff frequency is higher because the electrons that are emitted are more tightly bound to the atoms, so it takes more energy to free them.
Likes bhobba and qnt200
Thanks for the answers.
To summarize - a weak electron bond at the surrounding atoms is the cause of the absence of delay time.
BS
No. The absence of delay time is there even for photoemission from non-metals, where the electrons are more strongly bound to the atoms (and the cutoff frequency is higher).
The absence of delay time is because in QM, the energy that is taken up by the electron arrives all at once, in a single "packet" (the photon), instead of being gradually given to it by incoming EM waves (which is what the classical model predicts). That is true regardless of whether the photon carries a smaller amount of energy (for photoemission from metals) or a larger amount of energy (for photoemission from nonmetals).
It is one of the most persistent legends that the photoeffect is necessarily explained only by photons, i.e., quantization of the electromagnetic field. That's not true, because on the level we discuss it here, it follows from the semiclassical approach in 1st-order time-dependent perturbation theory. "Semiclassical" means that we describe the bound electron quantum-mechanically and the electromagnetic field ("light") as a classical wave.
That there is no (or rather negligible) "delay time" but a sharp threshold in frequency for the emission of the electron is due to the fact that you can emit the electron only when the frequency of the light is in resonance with some energy difference between the electron's bound state and one of its scattering state. It is not possible to "accumulate" this ionization energy from the em. wave as the fully classical model suggests.
Likes bhobba, dextercioby and qnt200
This is not clear to me. According to this, it seems that the photoelectric effect occurs only at one (resonant) frequency or at specific frequencies, and not at a frequency that provides sufficient energy for the electron to jump out.
No. The scattered states belong to the continuum of free states so the possible energy difference is essentially continuous above threshold. Only if both states are bound do you get discreet differences.
Likes qnt200
Unfortunately I’m not that far off with quantum mechanics yet, especially when it comes to the photo effect. It’s great that you directed me to take the first steps in that direction. If I'm not mistaken, today's quantum mechanics interprets the photo effect as follows (quote):
"In the photoelectric effect, or photoeffect, a photon is absorbed by a target atom and, as a result, an atomic electron is emitted or promoted to a bound open orbital thus leaving the residual ion or atom in an excited state."
I don't know if that's today's official interpretation?
Such an interpretation seems absolutely logical to me. A photon is more likely to hit an atom (the nucleus of an atom) than the electron itself.
This is a completely different interpretation from the classical interpretation that can be seen in almost all basics of physics, where a photon hits an electron.
Whether talking about resonance or excitation of atoms, both require some time. However, as you said, we can ignore that "delay time".
No, according to this the photoeffect occurs at any frequency above the threshold frequency. The unbound electron states have a continuous energy spectrum!
qnt200 said:
"The photoelectric effect has three important characteristics that cannot be explained by classical physics: (1) the absence of a lag time"
No longer true, observed attosecond-scale delays: https://science.sciencemag.org/content/328/5986/1658
Likes qnt200, bhobba, vanhees71 and 1 other person
FAQ: Why is there now evidence of a lag time in the photoelectric effect?
Why is the photoelectric effect important in understanding the behavior of light?
The photoelectric effect is important because it helps us understand the particle-like nature of light. It shows that light is made up of individual packets of energy called photons, and that these photons can transfer their energy to electrons in a material, causing them to be ejected. This phenomenon has significant implications in fields such as quantum mechanics and electronics.
What is meant by "lag time" in the photoelectric effect?
Lag time refers to the delay between when light is shone on a material and when the electrons are ejected. In the photoelectric effect, there is a short period of time between when the light hits the material and when the electrons are emitted. This delay is due to the time it takes for the photons to transfer their energy to the electrons and for the electrons to overcome the binding forces of the material.
Previously, it was believed that the photoelectric effect occurred instantaneously, with no lag time. However, with advancements in technology and more precise measurements, scientists have been able to detect a small but measurable lag time in the photoelectric effect. This evidence supports the particle nature of light and has helped improve our understanding of the behavior of light at the atomic level.
How does the intensity of light affect the lag time in the photoelectric effect?
The intensity of light does not affect the lag time in the photoelectric effect. The lag time is determined by the energy of the photons and the binding forces of the material, not the intensity of the light. However, a higher intensity of light can result in more electrons being ejected, as there are more photons available to transfer their energy to the electrons.
What other factors can influence the lag time in the photoelectric effect?
The lag time in the photoelectric effect can also be influenced by the frequency of the light, the type of material being used, and the temperature of the material. Higher frequency light (such as ultraviolet) has more energy per photon and can cause electrons to be ejected more quickly. Different materials have different binding forces, which can affect the lag time. And higher temperatures can cause the electrons to have more energy, making them easier to eject and reducing the lag time.
