Why is this C-G coefficient always zero?
In summary, Clebsch-Gordan coefficients are used in the addition of angular momenta, so one can use a the analogy of adding classical vectors. If one wants to add a vector of length ##\sqrt{2}## to a vector of length ##\sqrt{l(l+1)}## and still get ##\ket{l,0}##, one must add a vector of length ##\sqrt{2}## to a vector of length ##\sqrt{l(l+1)}## and recover a vector of length ##\sqrt{l(l+1)}##, while all 3 vectors lie in the xy plane.
euphoricrhino
From calculating a few CG-coefficient tables, it occurred to me that when we add two angular mometa ##j_1=l## and ##j_2=1## (with ##l## whole integer), the resulting ##|j=l,m=0\rangle## state always has zero C-G coefficient with ##|j_1=l,j_2=1;m_1=0,m_2=0\rangle## component, i.e., ##\langle j_1=l,j_2=1;m_1=0,m_2=0,|j=l,m=0\rangle=0##.
But the usual C-G coefficient selection rule only dictates ##|j=l,m=0\rangle## may have components in 3 states ##|j_1=l,j_2=1;m_1=-1,m_2=1\rangle, |j_1=l,j_2=1;m_1=0,m_2=0\rangle, |j_1=l,j_2=1;m_1=1,m_2=-1\rangle##. Why was the middle state ##|j_1=l,j_2=1;m_1=0,m_2=0\rangle## forbidden? Is there deeper insights?
Thanks
Likes PeroK
Think about classical vectors. You want to add ##\ket{1,0}## to ##\ket{l,0}## and still get ##\ket{l,0}##, i.e., you want to add a vector of length ##\sqrt{2}## to a vector of length ##\sqrt{l(l+1)}## and recover a vector of length ##\sqrt{l(l+1)}##, while all 3 vectors lie in the xy plane. Can't work.
Likes PeroK, Vanadium 50 and topsquark
Thanks for the reply, but I'm sorry I don't really understand this analogy.
Where I got lost is the part when you say "all 3 vectors lie in the xy plane", which 3 vectors are you referring to (it seems you are referring to the ##|m_1=1,m_2=-1\rangle,|m_1=0,m_2=0\rangle,|m_1=-1,m_2=1\rangle## as the 3 vectors in xy plane?)
I'm also not understanding what "add a vector of length ##\sqrt{2}##" mean, since we are talking about projection of vector of length ##\sqrt{l(l+1)}## onto 3 vectors of length ##\sqrt{2}## while one of the projection has zero projected components.
Clebsch-Gordan coefficients are used in the addition of angular momenta, so one can use a the analogy of adding classical vectors. In this case, you have a state ##\ket{j,m}## that is the result of the addition of states ##\ket{j_1,m_1}## and ##\ket{j_2,m_2}##, in particular
\ket{j=l,m=0} = \sum_{m_1,m_2} \ket{l,m_1,1,m_2} \braket{l,m_1;1,m_2 | l, 0}
and ask why ##\braket{l,0;1,0 | l, 0} = 0##. The reason is that since ##m=m_1=m_2 = 0##, the two vectors being added, namely ##\ket{l,0}## and ##\ket{1,0}##, are in the xy-plane, but so is the resulting vector you are considering, and therefore the CG coefficient can only be ##\neq 0## is making a triangle out of the three vectors is possible, which is not the case if ##j=l## while ##j_1=l## and ##j_2=1##.
This is similar to the fact that ##\braket{j_1,m_1;j_2,m_2 | j, m} = 0## if ##j < |j_1-j_2|## or ##j > j_1+j_2## (triangle rule) or if ##m \neq m_1 + m_2##, as these conditions also lead to an arrangement of three vectors that is not a triangle.
Likes PeroK, topsquark and euphoricrhino
Thanks a lot for the elaboration. I think I'm forming the mental picture now. You are suggesting to visualize any state ##|j,m\rangle## as a 3-D vector of length ##\sqrt{j(j+1)}## whose ##z##-component is ##m##, and claim CG coefficient to be non-zero only if the 3 vectors involved can form a triangle.
Am I understanding your analogy correctly? I can see how this can help prove my original observation.
Thanks a lot again!
Likes DrClaude
Thinking about it a little more, I think I'm still not understanding the analogy (despite my earlier claim that I did). Take the example where we add ##|l=1,0\rangle## with ##|l=1,0\rangle##, and we are asking why the resulting angular momentum cannot be ##|l=1,0\rangle##. By the analogy, these are three vectors on xy plane, each of which has length ##\sqrt{2}##, and the claim was they cannot form a triangle. But they can, as equilateral triangle, right?
You're making me doubt my answer! I'll have to think a bit more about it.
Now I think I finally come up with a proof for this claim using Wigner-Wickart theorem. The proof is simple but "mathematical", so some physical insights are still appreciated.
Here's the proof -
Consider the vector operator ##\mathbf{J}##, and transform it into "spherical tensor of rank-1" form
T^{(1)}_{\pm1} = \mp(J_x\pm iJ_y), \qquad T^{(1)}_0=J_z
By Wigner-Eckart theorem,
\left\langle j=l,m=0|T^{(1)}_q|j_1=l,m_1=0\right\rangle = \langle j_1=l,j_2=1;m_1=0,m_2=q|j=l,m=0\rangle\frac{\langle j=l||T^{(1)}||j_1=l\rangle}{\sqrt{2l+1}}
But for ##q=0##, the LHS vanishes because ##T^{(1)}_0=J_z##, which means the CG coefficient on the RHS must vanish because the second factor on RHS, being the same for all ##m## and ##q## values, must be non-zero.
FAQ: Why is this C-G coefficient always zero?
What is a C-G coefficient?
A C-G coefficient, also known as a Clebsch-Gordan coefficient, is a mathematical term used in quantum mechanics to describe the relationship between two quantum states.
The value of a C-G coefficient is dependent on the quantum numbers of the two states being compared. If these quantum numbers do not match certain criteria, the coefficient will be equal to zero.
Can a C-G coefficient ever be non-zero?
Yes, a C-G coefficient can be non-zero if the quantum numbers of the two states satisfy certain conditions. These conditions are based on the properties of angular momentum and spin.
How is the value of a C-G coefficient calculated?
The calculation of a C-G coefficient involves the use of a mathematical formula that takes into account the quantum numbers of the two states being compared. This formula is based on the principles of group theory.
What is the significance of a non-zero C-G coefficient?
A non-zero C-G coefficient indicates that the two quantum states being compared have a relationship and can be transformed into each other through a physical process. This has important implications in understanding the behavior of particles at the quantum level.
