Why is this equation from Purcell's EM textbook correct?
  • Thread starter Thread starter Leo Liu
    Em Textbook
The equation from Purcell's EM textbook, which relates force on a unit area to the electric field, is debated regarding its correctness. One participant argues that the coefficient should be the inverse of what is presented, suggesting it should be ##\frac{\epsilon_0}{2}## for dimensional consistency. Others clarify that the formula has been corrected in later editions of the textbook, indicating that earlier versions may contain errors. The discussion highlights the importance of verifying equations against the most current edition of the textbook. Overall, the conversation emphasizes the need for careful examination of mathematical expressions in physics.
Leo Liu
I saw the following equation on page 31 in Purcell's EM textbook.
$$F=\epsilon_0\int_{E_1}^{E_2} E\, dE=\frac 2 {\epsilon_0} (E_2^2-E_1^2)$$
Here, F is the force on a unit area.
And then he claims that since ##E_2-E_1=\sigma/\epsilon_0##, the equation can be further simplified to
$$F=\frac 1 {\epsilon_0}(E_1+E_2)\sigma$$
However, I think the correct coefficient in the last part of first equation should be the inverse of what it is now (##\frac{\epsilon_0}{2}## instead), as only then can I obtain the second expression. I have no idea why the author wrote the equation this way. To give it a little bit of background, dE is the change in the electric field of a thin layer of a charged sphere, E1 is the the electric field inside, and E2 is the electric field outside. Could someone explain?
yes, at least viewing from a purely mathematical view (integrating ##\int x dx=\frac{x^2}{2}## that should have been ##\frac{\epsilon_0}{2}##. Also from a dimensional analysis point of view ##\epsilon_0## just cannot be on the denominator, the units won't match then.
Likes Leo Liu and Steve4Physics
Leo Liu said:
Homework Statement:: .
Relevant Equations:: .
The formula (1.48 in the book) is in fact
##\frac F A = … = \frac {\epsilon_0}{2}(E_2^2 – E_1^2)##
Check your book!
Check your book!
Here is a picture of my book. This book is probably an older edition which is authorized to be printed in China by the original publisher.
Leo Liu said:
;View attachment 287228
I guess this is an error in earlier editions which has now been corrected. The 3rd edition (bottom of page 31) shows this:
Likes Delta2 and Leo Liu
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
