Why is this length included when finding moment about an axis
In summary, the book is trying to find the moment about the z axis but is having trouble understanding what the book is doing. The equation they are using is different than the equation I found online.
wahaj
156
I have to find reaction at the joints but that's not important. I'm having trouble understanding what the book is doing but first allow me to explain the diagram so there is no confusion because 3D pictures are kinda hard to draw. In the first diagram there is a crank shaft running along the y axis. 0.1 m after point B it goes down 0.2 m along the z axis and then 0.1 m along the y axis.A is a thrust bearing and B is a smooth journal bearing
Statical equilibrium equations apply here
When finding the moment about the z axis the equation should look something like this according to me.
Bx(0.5+0.6)- ux x rCA x F = 0
rCA=-0.1i - 1.3j + 0.2k
and ux = i
but here is how the book does it.
Bx(0.5+0.6) - F(0.2+0.1+0.6+0.5) = 0
Now I understand to find the moment about an axis I have to take the force and multiply it by the perpendicular distance between the force and a point on the axis. This works if both the axis and the force lie on one plane. When dealing with multiple planes I have to take the cross product. But I really have no idea why the book is doing what its doing. Can someone tell me if my equation is right or not and also explain why the book simply takes all the distances involved in getting from C to A and adds them without any regard of which axis they follow. Ask for clarification if I did a bad job of explaining.
Your dimensioning seems off, and I don't know what happened to the 75 kg load, but in any case you can solve by noting that in general , summing all moments about an axis
Mx = Fy(z) + Fz(y), My = Fz(x) + Fx(z), and Mz = Fx(y) + Fy(x). x, y , and z are perpendicular distances. Looks like for solving Bx, solution used last equation with x = 0. No need to fool with cross product.
yes like I said 3d images are hard to draw. don't worry about the load its not important to my question because it doesn't have an x or y component to cause rotation about the z axis. I know how to find the moment about an axis I'm just having trouble with the distances. There are two forces that produce a moment about z axis. The force F and the reaction force at B. I understand how the distance for the reaction force was calculated. but not for F. using the equation you gave me
Mz = Fx(y) + Fy(x) (I'm assuming this is how you meant it)
Since the force F acts only in the x direction Fy is 0 as a result Fy(x) is 0. this leaves me with Fx = F and y = 0.2
so Mz = 0.2F
this is still different than
F(0.2+0.1+0.6+0.5)
It is not a good idea to denote an applied force as F, since F is more of a general term to designate a Force; you should use a different letter like P for example to designate the applied force. But anyway, apparently moments are being summed about joint A to solve for Bx, so the y distance for the applied force F (or P if you will) is the distance along the y-axis from P to A, which is difficult to determine from your sketch (looks to me like 0.6 + 0.5 + 0.1 + 0.1, the way you have described it, not drawn it). y is certainly not 0.2, that is a z dimension yielding a moment about the y axis.
Yes the 0.2 is on the z axis my bad I'm kinda frustrated with this. and you got the numbers just right. The moments are being summed about the z axis. The reason A isn't included is because the Z axis passes through it so A can't produce any moment about z. It seems my drawing is more confusing than I thought. I'll wait till monday and ask a professor instead. thanks for trying to help.
Related to Why is this length included when finding moment about an axis
1. Why is the length of an object important when calculating moment about an axis?
The length of an object plays a crucial role in calculating the moment about an axis because it determines the distance from the axis at which the force is applied. This distance, also known as the lever arm, is a key component in the calculation of moment, as it directly affects the amount of torque or rotational force that is produced.
2. How does the length of an object affect its moment?
The longer the object, the greater the moment about an axis will be. This is because a longer object has a larger lever arm, resulting in a larger distance from the axis at which the force is applied. As a result, a greater torque or rotational force is produced, leading to a larger moment.
3. Is the length of an object the only factor that affects moment?
No, the length of an object is not the only factor that affects moment. The direction of the force in relation to the axis also plays a crucial role. If the force is applied perpendicular to the axis, it will result in a larger moment compared to a force that is applied parallel to the axis.
4. How do I determine the correct length to use when calculating moment?
The correct length to use when calculating moment is the perpendicular distance from the axis to the line of action of the force. This is also known as the lever arm. It is important to ensure that the length used is measured from the point where the force is applied, not from the end of the object.
5. Can the length of an object change the direction of its moment?
Yes, the length of an object can change the direction of its moment. If the force is applied at an angle to the axis, the length of the object will affect the direction of the moment. A longer object will have a greater tendency to rotate in one direction, while a shorter object will have a smaller tendency to rotate in the same direction.
14K
