Why is this set Open and Connected?
  • Thread starter hadroneater
  • Tags
    Set
In summary, the conversation discusses the concept of a set D in complex analysis, defined as the complex plane excluding the non-positive real axis. The question arises as to why this set is considered open and connected. It is determined that D is open because it does not contain any of its boundaries, and is connected because every point in the set has a sphere (disk) around it that is also in the set.
hadroneater
59
This isn't a homework problem but just a fundamental concept that my entire complex analysis course is based on.
The set D = ℂ \ non-positive real axis. Why is it considered open and connected (domain)?
When it says non-positive real axis, is the origin included? I can see why D is connected. But why is it considered open? The set is open when it contains all of its boundaries. But the set D clearly does not contain any point on the non-positive real axis.
Yes, 0 is not a positive number so it is part the "non-positive real axis".
Your error is the statement "The set is open when it contains all of its boundaries." That is exactly backwards. A set is open if and only if it contains none of its boundary. A set is closed if and only if it contains all of its boundary.
An open set does not contain all of it's boundaries. Moreover the boundary of a set is defined as it's closure without it's interior. An open set is equal to it's interior since the interior is defined as the 'biggest' open set that is a subset of the set it is the interior of. (i.e. it's the union of all open sets in the set it is the interior of).
all you really have to ask yourself in this case since you're probably using the Euclidian topology on the complex plane is: Does every point in the subset have sphere (disk) around it that is also in the subset. Which is in this case is clearly true (if you are not on the non-positive real axis you can allways get closer to it, which is why actually zero is also taken oout of the plane).
FAQ: Why is this set Open and Connected?
1. Why is it important for a set to be both open and connected?
Being both open and connected ensures that the set contains no isolated points and that it can be continuously deformed without being broken into separate pieces. This makes it easier to analyze and understand the properties of the set.
2. How can I determine if a set is open and connected?
A set is open if every point in the set has a neighborhood contained in the set. It is connected if it cannot be separated into two non-empty disjoint open sets. To determine if a set is open and connected, you can use topological tools such as the definition of open and connected sets, or topological theorems such as the Intermediate Value Theorem.
3. Can a set be open but not connected?
Yes, a set can be open but not connected. For example, the set of all real numbers greater than zero is open but not connected since it can be separated into two disjoint open sets, (0, infinity) and (negative infinity, 0).
4. What are some applications of open and connected sets in science?
Open and connected sets have many applications in various fields of science such as physics, engineering, and computer science. In physics, they are used to describe the continuity and smoothness of physical systems. In engineering, they are used in the design of structures and networks. In computer science, they are used in the development of algorithms and data structures.
5. Can open and connected sets be used to describe real-world phenomena?
Yes, open and connected sets can be used to describe real-world phenomena. For example, the concept of open and connected sets is used in weather forecasting to describe the continuity of atmospheric conditions. It is also used in economics to analyze the stability and connectivity of financial markets. Moreover, open and connected sets are used in biology to model the interconnectedness of ecological systems.
