MHB Why is $w_p(x+y) \geq m$ and not $w_p(x+y) = m$ for $x,y \in \mathbb{Q}_p$?
  • Thread starter Thread starter evinda
The discussion centers on the properties of the $p$-adic valuation $w_p$ in the context of the addition of two $p$-adic numbers. It establishes that for $x, y \in \mathbb{Q}_p$, the inequality $w_p(x+y) \geq \min \{ w_p(x), w_p(y) \}$ holds, with equality only if $w_p(x) \neq w_p(y)$. The participants explore the reasoning behind why $w_p(x+y)$ is not necessarily equal to $m$, emphasizing that the sum could be divisible by higher powers of $p$. They illustrate this with examples, noting that even if individual terms are not divisible by a certain power, their sum might be. The conversation highlights the nuances of $p$-adic addition and the implications of the valuation's properties.
evinda
MHB
Hello! (Wave)
The additive $p-$ adic valuation of $\mathbb{Q}_p$:
$$w_p: \left\{\begin{matrix}
\mathbb{Q}_p \rightarrow \mathbb{Z} \cup \{\infty\}\\
p^m u \mapsto m\\
0 \mapsto \infty
\end{matrix}\right.$$
$$\forall x,y \in \mathbb{Q}: w_p(x+y) \geq \min \{ w_p(x), w_p(y)\}$$
If $w_p(x) \neq w_p(y)$, then the equality stands.
This is the proof, according to my notes:
$$x=p^m u_1 | u_1 \in \mathbb{Z}_p^*$$
$$y=p^n u^2 | u_2 \in \mathbb{Z}_p^*$$
$$m,n \in \mathbb{N}$$
Without loss of generality, we suppose that $m \leq n$.
$$x+y=p^m(u_1+p^{n-m}u_2)$$
$$w_p(x+y) \geq m$$
If $n>m$, then $u_1+p^{n-m}u_2 \in \mathbb{Z}_p^*$
In this case:
$$w_p(x+y)=m=\min \{ w_p(x), w_p(y) \}$$
If $n=m$, $\displaystyle{ w_p(x+y) \geq n=m=\min \{ w_p(x), w_p(y)\} }$
Could you explain me why it is : $w_p(x+y) \geq m$ and not $w_p(x+y)=m$ ? (Thinking)
Mathematics news on Phys.org
First of all, your notation sucks.
$p$-adic valuation is usually denoted by $\nu_p(\bullet)$, and the $p$-adic norm as $|\bullet |_p$.
We know by definition that $x = p^{\nu_p(x)} \cdot a$ and $y = p^{\nu_p(y)} \cdot b$. Now $x + y = p^{\nu_p(x)} \cdot a + p^{\nu_p(y)} \cdot b$. Without loss of generality, assume $\nu_p(x) > \nu_p(y)$, then $x + y = p^{\nu_p(x)} \cdot (p^{\nu_p(x)-\nu_p(y)} \cdot a + b)$. Now this factor $p^{\nu_p(x)-\nu_p(y)} \cdot a + b$ might be divisible by $p^k$ for some $k > 0$, who knows? So the largest $n$ such that $x + y$ is divisible by $p^n$ is *at least* $\nu_p(x)$, but it might be larger. Hence $\nu_p(x + y) \geq \nu_p(x) = \text{min}(\nu_p(x), \nu_p(y))$. From this one derives that $|x + y|_p \leq \text{max}(|x|_p, |y|_p)$.
We know by definition that $x = p^{\nu_p(x)} \cdot a$ and $y = p^{\nu_p(y)} \cdot b$. Now $x + y = p^{\nu_p(x)} \cdot a + p^{\nu_p(y)} \cdot b$. Without loss of generality, assume $\nu_p(x) > \nu_p(y)$, then $x + y = p^{\nu_p(x)} \cdot (p^{\nu_p(x)-\nu_p(y)} \cdot a + b)$. Now this factor $p^{\nu_p(x)-\nu_p(y)} \cdot a + b$ might be divisible by $p^k$ for some $k > 0$, who knows? So the largest $n$ such that $x + y$ is divisible by $p^n$ is *at least* $\nu_p(x)$, but it might be larger. Hence $\nu_p(x + y) \geq \nu_p(x) = \text{min}(\nu_p(x) + \nu_p(y))$. From this one derives that $|x + y|_p \leq \text{max}(|x|_p, |y|_p)$.
Could you explain me how it can be that the factor $p^{\nu_p(x)-\nu_p(y)} \cdot a + b$ might be divisible by $p^k$ for some $k > 0$ ?
In which case would it be like that? (Thinking) (Worried)
Say $b = p^k$ for some $k \leq \nu_p(x) - \nu_p(y)$. Then $p^{\nu_p(x) - \nu_p(y)} + b$ is divisible by $p^k$.
According to my notes, $a,b \in \mathbb{Z}_p^*$, so shouldn't it be:
$$b \in \{ 1,2, \dots, p-1\}$$
? Or am I wrong? (Worried)
Yes, right, my bad. I wasn't paying attention. Forget what I've said above.
But $p^{\nu_p(x) - \nu_p(y)} \cdot a + b$ might still be divisible by a power of $p$. Consider, for example, $3 + 3$. None of the two $3$s are divsible by $6$, but $3 + 3 = 6$ is.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
