MHB Why is (x,e_i) a zero sequence?
  • Thread starter Thread starter mathmari
    Sequence Zero
An infinite orthonormal system in a Hilbert space is closed if the norm of any vector can be expressed as the sum of the squares of its inner products with the basis elements. This leads to the conclusion that the sequence of inner products, denoted as (x,e_i), is a zero sequence. The convergence of (x,e_i) to zero as i approaches infinity is supported by the nth term test for convergence. The discussion highlights the relationship between the properties of orthonormal systems and the behavior of sequences derived from them. Understanding this connection is crucial for grasping the fundamentals of functional analysis.
mathmari
MHB
Hey! :o
An infinite orthonormal system $\{e_1, e_2, ... \} \subset H$ is closed in $H$ iff $\forall x \in H$
$$||x||^2=\sum_{i=1}^{n}{|(x,e_i)|^2}$$
From the summability of the right part of the relation above, we conclude to that the sequence $(x,e_i)$ is a zero sequence.
Could you explain me how we conlude to that?
Mathematics news on Phys.org
Do you mean why $(x,e_i)\to0$ as $i\to\infty$? This follows from the nth term test.
Aha! I got it! Thank you! (Smirk)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
