MHB Why is $X \subset \mathcal{P}X$ true for a transitive set $X$?
  • Thread starter Thread starter evinda
    Relation
The discussion centers on the equivalence of several conditions for a transitive set \( X \), specifically addressing why \( X \subset \mathcal{P}X \) holds. It is clarified that this inclusion is true if \( X \) is transitive, as each element \( x \) of \( X \) is a subset of \( X \), thus belonging to \( \mathcal{P}X \). The participants engage in proving the implications between the conditions, emphasizing the need for clarity in assumptions and definitions. The conversation highlights the logical structure required to establish the equivalence of the propositions. Overall, the thread provides insights into the foundational aspects of set theory related to transitive sets.
evinda
MHB
Hello! (Wave)
Proposition
Let $X$ be a set. The following are equivalent:
  1. $X$ is transitive
  2. Each element of $X$ is a subset of $X$ $\left( \forall x(x \in X \rightarrow x \subset X) \right)$
  3. $X \subset \mathcal{P}X$
  4. $\bigcup X \subset X$
Could you explain me why this: $X \subset \mathcal{P}X$ holds?
When we have for example $X=\{ a, b, c \}$, then $x \in a \rightarrow x \in X$.
So, we see that $a \subset X \rightarrow a \in \mathcal{P}X$.
But why does it also hold that $X \subset \mathcal{P}X$ ? (Thinking)
evinda said:
Sentence
Proposition, or claim.
It doesn't in general. It only holds if any of the other conditions hold.
Why do you say so? What are $a$, $b$ and $c$?
A ok.. (Nod)
Could you explain me why it holds if for example the first condition holds? (Thinking)
I thought so because $X$ is transitive. Am I wrong? (Thinking)
evinda said:
Could you explain me why it [$X \subset \mathcal{P}X$] holds if for example the first condition holds?
It's pretty straightforward to show that 1 implies 2 and 2 implies 3.
This sounds like the following dialog.
"John is a murderer and must go to jail."
"Which John? Every John? And why is he a murderer?"
"I mean, if John is a murderer, he must go to jail."
"Ah..."
You introduced $X$ by saying that $X=\{ a, b, c \}$ for unknown $a$, $b$ and $c$. Who told you that $X$ is transitive? Do you say, "If $X$ is transitive", i.e., are you assuming that $X$ is transitive? Then you should say so. For each statement that you write, you should indicate its status: whether it's an assumption, a theorem that you are starting to prove or it follows from some previous statement.
Also, in this:
it is not clear whether we see that $a \subset X$ implies $a \in \mathcal{P}X$ or that $a \subset X$ holds, and therefore $a \in \mathcal{P}X$ holds. To see the difference, $n>5$ implies $n>3$ for all $n$, but it is not true that for any $n$ it is the case that $n>5$ and therefore $n>3$.
It's pretty straightforward to show that 1 implies 2 and 2 implies 3.This sounds like the following dialog.
"Ah..."
Also, in this:
I am sorry... (Worried)(Tmi)
So can we show that the propositions are equivalent like that? $1 \to 2$: Let $x \in X$. Since $X$ is transitive we have that if $y \in x \rightarrow y \in X$. Therefore $x \subset X$.
$2 \to 3$: Let $x \in X$. Since we assume that $2$ holds we have that $x \subset X \rightarrow x \in \mathcal{P}X$.
Therefore $X \subset \mathcal{P}X$.
$3 \to 4$: Let $x \in \bigcup X$. Then $\exists y \in X$ such that $x \in y$. From $3$ we have that $y \in \mathcal{P}X \rightarrow y \subset X$.
Since $x \in y$ we have that $x \in X$.
Therefore $\bigcup X \subset X$.
$4 \to 1$: Let $x \in \bigcup X $. Since $\bigcup X \subset X$ we have that $x \in X$.
But $x \in \bigcup X$ means that $\exists y \in X$ such that $x \in y$.
How could we continue? (Thinking)
Not bad. Sorry, I'll be using this post as evidence that I don't have to explain trivial things to you. :p
You need to start with what you need to prove. $X$ is transitive if $x\in X$ and $y\in x$ imply that $y\in X$. So assume that $x\in X$ and $y\in x$. Then $y\in\bigcup X$ by the definition of generalized union, and since by assumption $\bigcup X\subseteq X$, we have $y\in X$.
(Giggle)
I understand... Thanks a lot! (Happy)
