Why is \( y(x) = 1 - x \) chosen and how does it fit into the chain rule?
  • MHB
  • Thread starter aruwin
  • Tags
    Function
In summary: He gets y(x) in the chain rule by noting that the derivative of g with respect to x is the derivative of f with respect to y, dy/dx=-1, so \[g'=f'\]
aruwin
208
I have the solution to the question, but I don't understand the first step so I am just going to paste the first step here.I need people to explain to me.
Question:
For the function f(x) = (logx)/x, prove the following equality.
fn (1) = (-1)(n-1) n![1+ 1/2 +1/3 +...+1/n]
First step of the solution(The bolded ones are what I don't understand):
Let y(x) = 1 - x and g(x) = f(y(x)) = log(1 - x) / (1 - x). Then:
g(y(x)) = log(1 - (1 - x)) / (1 - (1 - x)) = log(x) / x = f(x)
Thus:
f'(x) = g'(y(x)) * y'(x) ... (chain rule)
= g'(y(x)) * -1
= -g'(y(x))
f''(x) = -g''(y(x)) * y'(x)
= -g''(y(x)) * -1
= g''(y(x))
So on, by induction, we can see that:
f^(n)(x) = (-1)^n * g^(n)(y(x))
===> f^(n)(1) = (-1)^n * g^(n)(y(1)) = (-1)^n * g^(n)(0)
Ok, first off, why and how do we know to put y(x) = 1 - x?
Secondly, the chain rule part. Where does he get y(x) in that chain rule?
I thought f'(x)=g'(y(x))
When you write [tex]f^n[/tex] do you mean the nth derivative? That is more commonly represented with (): [tex]f^{(n)}[/tex]. Just [tex]f^n[/tex] usually means the nth iteration of f but that can't be what you mean here: f(1)= 0 so [tex]f^2(1)[/tex] is not defined.
I'm not sure what there is about "y= 1- x" not to understand! They are defining a new variable in terms of the old If y= 1- x, then x= 1- y so that f(x)= ln(x)/x= ln(1- y)/(1- y)= g(y). f and g are really the same function- the only difference is that we are thinking of g as a function of y, f as a function of x. They are defining g(y) to be ln(1- y)/(1- y)= f(y). The derivative of g with respect to x is, by the chain rule, [tex]\frac{dg}{dy}= \frac{df}{dy}\frac{dy}{dx}. Of course, with y= 1- x, dy/dx= -1 so we have dg/dy= -df/dy, or g'= -f', as they say. Differentiating again, the same thing happens so that we multiply by -1 again: g''= (-1)(-1)f''= f''. It should be easy to see that as we continue differentiating, we just keep multiplying by -1 so the nth derivative of g is [itex](-1)^n[/itex] times the nth derivative of f.
No, that is precisely what the chain rule says: with the derivative of f with respect to x and the the derivative of g with respect to y, we must have f'(x)= g'(y) (dy/dx).
Question:
Thus:
= g'(y(x)) * -1
= -g'(y(x))
= -g''(y(x)) * -1
= g''(y(x))
Well I would suggest that \(y=1-x\) is an interesting change of variable to consider since we are obviously looking at the coefficients in the Taylor series expansion of \(f(x)\) about \(x=1\).
Trial and error would then have been used to find the given relation and that would then be transformed into a proof with no given reason for the choice other than it works.
What you are seeing is a streamlined proof with the scaffolding used to construct it removed.
No, the prime denotes differentiation with respect to \(x\), so the chain rule is:
\[\frac{d}{dx}g(y)=\frac{d}{dy}g(y)\frac{dy}{dx}\]
CB
FAQ: Why is \( y(x) = 1 - x \) chosen and how does it fit into the chain rule?
What is the concept of proving equality of a function?
The concept of proving equality of a function is to show that two functions have the same output for all possible inputs. It is a way of determining if two functions are equivalent or not.
Why is it important to prove equality of a function?
It is important to prove equality of a function because it ensures the accuracy and validity of mathematical calculations and equations. It also allows for a better understanding of the relationship between different functions and their properties.
What are the different methods for proving equality of a function?
There are various methods for proving equality of a function, including direct proof, proof by contradiction, proof by induction, and proof by construction. Each method has its own specific steps and techniques.
Can two functions be equal but have different forms?
Yes, two functions can be equal but have different forms. For example, the functions y = x^2 and y = (x+1)(x-1) both have the same output for all possible inputs, therefore they are equal even though they have different forms.
What are some common mistakes when proving equality of a function?
Some common mistakes when proving equality of a function include not considering all possible inputs, using incorrect mathematical operations or properties, and assuming that equal outputs for a few inputs means the functions are equal for all inputs.
