Why is y = x^2 not one-to-one?
  • MHB
  • Thread starter mathdad
In summary, an expression fails to be a function when it does not pass the vertical line test, meaning that there are multiple outputs for a single input. In other words, there are two or more values of the independent variable that map to the same value of the dependent variable. This is also known as a one-to-many relationship and is not considered a function.
mathdad
1,283
Mathematics news on Phys.org
Consider y = 1...there are two inputs (x = -1 and x = 1) that map to y = 1. And so y = x² is not one-to-one. :D
If we try to solve for x, we get:
\(\displaystyle x=\pm\sqrt{y}\)
This tells us that for a particular y greater than zero, we have 2 x's that map to it...unless we restrict x (the domain) such that it is either non-negative or non-positive.
Ok. If we let x = 1 or -1 for y = x^2, both values lead to y = 1 after squaring. We can also say that y goes to 1 for both values of x. The conclusion is that the parabola y = x^2 is a function but not one-to-one.
Correct?
Correct?
It passes the vertical line test, and so is a function, but fails the horizontal line test, and so is not one-to-one. :D
I like the vertical and horizontal line tests.
Question:
When does an expression fail to be a function?
FAQ: Why is y = x^2 not one-to-one?
The graph of y = x^2 is a parabola, which opens upwards and has a vertex at (0,0). This means that for every x-value, there are two possible y-values. Therefore, the function is not one-to-one because there are multiple y-values for some x-values.
How can I tell if a function is one-to-one?
A function is one-to-one if every x-value has a unique y-value. This means that no two different x-values can have the same y-value. To determine if a function is one-to-one, you can graph it and see if it passes the horizontal line test. If a horizontal line intersects the graph at more than one point, then the function is not one-to-one.
Can y = x^2 ever be one-to-one?
No, the function y = x^2 can never be one-to-one because of its shape. A parabola will always have two y-values for each x-value, unless it is a straight line (which is not the case for y = x^2).
Why is it important for a function to be one-to-one?
One-to-one functions have a unique inverse, meaning that the input and output values can be switched to create another function. This can be useful for solving equations or finding the original value of a function. Additionally, one-to-one functions have a clear and predictable relationship between the input and output values, making them easier to work with and analyze.
Can a function be one-to-one but not onto?
Yes, a function can be one-to-one but not onto. Being one-to-one means that each input has a unique output, but it does not guarantee that every output has a corresponding input. Being onto, or surjective, means that every output has a corresponding input. A function can be one-to-one but not onto if there are some outputs that do not have an input that maps to them.
