Why Isn't My DIY DC Motor Turning?
In summary, a DIY DC motor may not be turning due to several common issues, including inadequate power supply, incorrect wiring, insufficient magnetic field strength, or mechanical obstructions. Ensuring that the components are properly connected, providing enough voltage, and verifying that the motor's parts are free to move can help troubleshoot the problem. Additionally, checking for damaged components can also be crucial in diagnosing the issue.
Benedict Pham
You are to construct a DC electric motor using simple materials. No extra marks can be obtained by using expensive equipment and the use of a purchased kit is not permitted. If in doubt see your physics teacher
Your motor works smoothly and regularly using a maximum 12V power pack or battery.
Your motor is less than 20cm x 20cm in dimensions.
Your motor must be sturdy in construction and easy to start.
The motor must have magnets or electromagnets, a split-ring commutator, brushes and a coil.
Your brushes need to be attached to the motor.
You have used raw materials (where appropriate) in the construction process
𝜏 = 𝑛𝐼𝐴𝐵sin𝜃
𝐹 = 𝑙𝐼𝐵sin𝜃
Hi so I'm making a DC motor for my school project and I have no clue why it doesn't work properly. I used copper wire to make the coil (around 50 windings) and put that around a wooden axle (the windings and the coil itself are secured using tape and cable ties), I have a split ring commutator, and I have 2 magnets on either side of the coil. The Magnets are oriented correctly - (NS) Axle (NS) - and electricity goes through it, (it sparks when I put the wire onto it) and it vibrates a bit when I put the wire onto the commutator but it doesn't turn or anything.
:welcome:
Give it a spin with your finger(s) to get it started.
A motor with just two poles can have some dead spots and often will not start on its own.
If that does not get it going, check the rotational relationship between the rotor poles, the commutator, and the magnets. (figure out where in the rotation you want the commutator to switch)
Have Fun!
Cheers,
Tom
Maybe magnet orientation, or external magnetic circuit ?
Please attach a photo(s) of your motor to your next post, so we can see what you have done.
Where we see possible problems, we can ask further questions.
I had a problem once where the connection from the supply to the commutator was inconsistent and the motor only vibrated like you described.
Tom.G said:
:welcome:
Have Fun!
Cheers,
Tom
Thanks, turns out the magnetic field wasn't strong enough so I added some more magnets and it worked.
Likes scottdave, hutchphd, Mooorshum and 2 others
FAQ: Why Isn't My DIY DC Motor Turning?
Why isn't my DIY DC motor turning at all?
There could be several reasons for this issue. First, ensure that the power supply is connected properly and providing the correct voltage. Check for loose or broken connections in the circuit. Also, verify that the motor windings are intact and not damaged. Lastly, make sure that the commutator and brushes are making good contact.
Why does my DC motor only turn intermittently?
Intermittent operation can be caused by poor connections or a faulty power supply. Inspect all wiring and solder joints for any signs of weakness or corrosion. Additionally, check the brushes and commutator for wear or dirt buildup, which can disrupt the electrical contact needed for smooth operation.
Why is my DC motor turning in the wrong direction?
If your motor is spinning in the wrong direction, you likely have the polarity of the power supply reversed. Simply switch the connections of the positive and negative terminals to the motor to correct the direction of rotation.
Why does my DC motor make a grinding or squeaking noise?
Grinding or squeaking noises can indicate mechanical issues. Check for any debris or obstructions in the motor. Ensure that the bearings are lubricated and not worn out. Misalignment of the motor shaft can also cause noise, so make sure everything is properly aligned and secured.
Why is my DC motor running slower than expected?
A motor running slower than expected can be due to insufficient power supply voltage or current. Verify that your power source meets the motor's requirements. Additionally, check for any mechanical resistance in the motor or load that could be causing it to slow down. Dirty or worn brushes and commutator can also impede performance, so inspect and clean them if necessary.
9K
