I Why isn't the Lagrangian invariant under ##\theta## rotations?
The Lagrangian for a particle in a radially symmetric potential, expressed in spherical coordinates, reveals that it is invariant under shifts in the azimuthal angle ##\varphi## but not under shifts in the polar angle ##\theta##. This lack of invariance arises because the Lagrangian explicitly depends on ##\theta##, which affects the sine squared term. Consequently, while angular momentum is conserved in the system, only the component associated with ##\varphi##, specifically ##mr^2 \sin^2(\theta) \dot{\varphi}##, is conserved, not the full angular momentum. The introduction of spherical coordinates breaks the full rotational symmetry, limiting invariance to rotations around the polar axis. Thus, the conservation laws derived from Noether's theorem reflect these symmetries in the system.
PhysicsRock
TL;DR Summary
Lagrangian of a particle in radial potential isn't invariant under ##\theta## rotations.
I just calculated the Lagrangian of a particle of mass ##m## in a radially symmetric potential ##V(r)##. I thought it would be a good idea to switch to spherical coordinates for that matter. What I get is
L = \frac{1}{2} m \left( \dot{r}^2 + r^2 \dot{\theta}^2 + r^2 \dot{\varphi}^2 \sin^2(\theta) \right) - V(r)
This is typically a well-known result and I am very confident that it's correct. We instantly see that this Lagrangian does not depend on ##\varphi##, only on it's time derivative. Thus, we can introduce an infinitesimal rotational shift ##\delta\varphi##, which will not change the Lagrangian. However, a shift ##\delta\theta## does not leave this expression invariant, since ##\theta## explicitly appears in the Lagrangian. With radial symmetry though, I would expect that both angles can be altered infinitesimally without changing the physics of the system. Since ##\theta## appears in the sine squared term, we could introduce a discrete shift ##\delta\theta = n \pi## with ##n \in \mathbb{N}##. This, however, would not yield a conservation law, since Noether's theorem demands continuous symmetries. I would've expected that angular momentum is conserved here, but using said theorem, the only conserved quantity here would be
\frac{d}{dt} \left( m r^2 \dot{\varphi} \sin^2(\theta) \right) = 0
which looks like a component of angular momentum (EDIT: it is in fact the ##L_\theta## component), but not angular momentum completely.
Why is that?
A movement in the ##\theta## direction isn't a rigid rotation. It maps lines of constant latitude onto each other, and they don't have equal radius. Contrast a rotation in the ##\phi## direction that maps lines of constant longitude onto each other - they are all great circles.
There are Killing fields corresponding to rotations around the ##x## and ##y## axes (assuming rotation around ##z## is the ##\delta\phi## in your post), but they are not so cleanly expressed on spherical polars (slightly surprisingly, I agree).
Likes strangerep, Dale and malawi_glenn
So it is correct that only ##L_\theta \sin(\theta)## is conserved in such a system?
A particle moving in a central potential will have an angular momentum (about the origin), ##\vec L##, that is conserved. The direction of ##\vec L## is perpendicular to the plane of motion of the particle.
Since ##\vec L## remains constant, the projection of ##\vec L## along any fixed axis in the inertial frame will be conserved. The quantity ##mr^2\sin^2\theta \, \dot{\varphi}## is the canonical momentum associated with the variable ##\varphi## and this quantity is the projection of ##\vec L## along the fixed z-axis. So this quantity is conserved.
The quantity ##mr^2 \dot{\theta}## is the canonical momentum associated with the variable ##\theta##. At some instant of time, this quantity is the projection of ##\vec L## along an axis that lies in the x-y plane and makes an angle ##\varphi## to the y-axis. But this axis is not a fixed axis (in general) since ##\varphi## will vary with time (in general). Thus, ##mr^2 \dot{\theta}## is generally not conserved.
I don't know if this helps.
Likes Ibix and malawi_glenn
It does help a lot. Thank you.
PhysicsRock said:
TL;DR Summary: Lagrangian of a particle in radial potential isn't invariant under ##\theta## rotations.
Why is that?
From a symmetry point of view, it's because with spherical coordinates you introduce a perferred direction, i.e., the direction of the polar axis, along which the spherical coordinates are singular.
Rotational invariance is better expressed in terms of Cartesian coordinates. An infinitesimal rotation is defined by
$$\delta t=0, \quad \delta \vec{r} = \delta \vec{\varphi} \times \vec{r}.$$
Full rotation symmetry means you can take ##\delta \vec{\varphi}## in an arbitrary direction, and the Lagrangian invariant under this infinitesimal rotation.
By introducing spherical coordinates you distinguish one direction by introducing the polar axis, and the full rotation symmetry is thus broken to the symmetry under rotations only around the polar axis, and this residual symmetry is parametrized by ##\varphi##, which is thus a cyclic variable for a particle in a central potential.
  • Love
Likes PhysicsRock, Ibix and malawi_glenn
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
