Why isn't the magnification of a telescope (-)
In summary, the sign convention for magnification in telescopes is not considered negative because it would confuse customers and it can be corrected by using a right angle mirror or prism star diagnonal. Different textbooks may use different conventions to avoid copyright infringement.
Rib5
59
I was wondering why the magnification of a telescope is not considered negative since it is inverted. I know it doesn't really matter much since all you are trying to do is get a larger image but the sign convention should still be followed I think. The book I am using is Giancoli Physics for Scientists.
Astronomy news on Phys.org
A telescope is working with two sections, the objective and the eyepiece. The objective provides an inverted real image of angular magnification(-M). The eyepiece is a magnifier creating a magnified virtual image from the object which is the image of the objective which is upright or +m as it's also an angular magnification. The result is mM = -fobj/fe which is inverted and hence negative. When dealing with a 'grocery store' gift telescope (the optical equivalent of a fruitcake) magnification is the most important sales gimmick and having a - sign in front of the magnification would terribly confuse all customers who might consider purchasing one of those toys. Besides, if you insert a right angle mirror or prism star diagnonal, the image becomes upright without affecting the magnification.
I leave it to your choice concerning why the sign convention in the Giancoli book was not followed as there are possibilities as to why normal sign convention was not followed in that book. Other books such as University Physics texts that introduce the basics of optics - such as Sears & Zemansky (now known as Young & Friedman) do follow the proper convention. Other less important conventions - such as s and s' versus p and q for object and image distances or M and m for angular versus lateral magnification (or lateral versus angular magnification) do tend to vary from textbook to textbook, perhaps to avoid potential copyright infringement. Note here I'm using both m and M for angular magnification - just for the eyepiece and objective rather than trying to figure out how to insert subscripts to differentiate them (at 4am local time).
The magnification of a telescope is not considered negative because it is a ratio of the size of the image to the size of the object being viewed, and ratios do not have a sign. The sign convention is typically used for quantities that have a direction or orientation, such as displacement or force. In the case of a telescope, the magnification is simply a comparison of the sizes of the object and the image, regardless of their orientation. Therefore, it is not necessary to assign a positive or negative sign to the magnification. Additionally, the inverted image in a telescope is a result of the optics and does not affect the magnification itself. So while the sign convention is important in many areas of physics, it is not applicable when discussing the magnification of a telescope.
Related to Why isn't the magnification of a telescope (-)
1. Why isn't the magnification of a telescope constant?
The magnification of a telescope is not constant because it depends on several factors such as the focal length of the lenses, the diameter of the lenses, and the observer's eye position. These factors can vary and therefore, the magnification will also vary.
2. Why isn't the magnification of a telescope infinite?
The magnification of a telescope cannot be infinite because of the limitations of the telescope's lenses. The lenses can only bend and focus light to a certain extent, and past a certain point, the image quality will deteriorate instead of becoming more magnified.
3. Why isn't the magnification of a telescope the same for all objects?
The magnification of a telescope will not be the same for all objects because each object is located at a different distance from the telescope. The magnification is directly proportional to the distance of the object from the lens, so objects at different distances will have different magnifications.
4. Why isn't the magnification of a telescope always higher than the naked eye?
The magnification of a telescope is not always higher than the naked eye because it depends on the parameters of the telescope. If the telescope has a low magnification power, then the image may appear smaller than what the naked eye can see. Additionally, atmospheric conditions and light pollution can also affect the perceived magnification of a telescope.
5. Why isn't the magnification of a telescope the only factor that affects image quality?
The magnification of a telescope is not the only factor that affects image quality because other factors such as the quality of the lenses, the atmospheric conditions, and the stability of the telescope also play a crucial role. A high magnification may not necessarily result in a clear image if the other factors are not optimal.
12K
