Why isn't Thorium used for reactor fuel rods?
  • Thread starter ComputerJockey2017
  • Tags
    Fuel Reactor
In summary, Thorium has been considered as a viable alternative reactor fuel for the past 6 decades, with active programs in countries like India and China. However, it has shown to have less burnup per ton of fuel compared to uranium and poses a proliferation risk due to the production of U-233 and U-232, which emit intense gamma rays. Additionally, the process of converting thorium to U-233 is expensive and it has not been deemed economically feasible compared to current fuel options.
ComputerJockey2017
Is THORIUM a viable alternative Reactor Fuel? Seems like URANIUM and PLUTONIUM are to easily weaponized.
Thorium itself isn't fissible. There were some breeding reactor concepts which produced U-233 from Th-232, but they required large quantities of U-235 and therefore also contained a large proliferation risk.
https://www.gen-4.org/gif/upload/docs/application/pdf/2013-10/gif_egthoriumpaperfinal.pdfhttps://www.gen-4.org/gif/jcms/c_9359/msr
Folks have been thinking about thorium fuel cycles for the last 6 decades. The idea gets revived periodically, and nations such as India, China and others with substantial thorium deposits have active programs.
Thorium fuel was tested an Indian Point 1 starting around 1962, and on a limited basis in the Shippingport (LWBR) reactor in the late 1970s through early 1980s.
Fuel Summary Report: Shippingport Light Water Breeder Reactor
INEEL/EXT-98-00799 https://www.nrc.gov/docs/ML0923/ML092310709.pdf
MIT study (1999) - http://ltbridge.com/assets/15.pdf
http://www.barc.gov.in/reactor/tfc.html
In a light water reactor, thorium has less burnup per ton of fuel than uranium by a significant amount. It has a parasitic effect on its neutron economy which essentially wastes reactivity compared to uranium/plutonium.
Thorium is "fertile" not fissile, and needs to be converted to U233 before it can be used, in which process U232 is also produced, in small quantities, but enough to wreak havoc on weapons use as it is a hard gamma emitter, detectable from far away.
The premise of Thorium use is in Molten Salt Reactors, either once-thru, or a breeder where fertile material is converted, and byproducts are removed in-line, some for use in other applications. The increased temps in MSRs allows for use in industrial processes, and/or extremely reduced size CO2 turbines, desalination of sea water, or use air to dissipate waste heat, allowing arid areas for sites.
Avoiding water with its weak covalent H / O2 bond is a bonus, both from a stability, efficiency, and safety point t of view.
How is this a problem?
U-233 has a small critical mass, comparable to Pu-239. And lower radioactivity.
And lower spontaneous fission rate. An U-233 bomb would actually seem relatively easy to build.
Quite a necromancy, the original question is already three years old...
Thorium was used in commercial reactors already. Indian Point I. has many to say about the economical consequences of using thorium being a lone wolf in a conservative industry, and also there were several other 'live' tests with mixed-thorium fuels: it happens a few times in every decade.
I think the most correct answer for the original question would be: it is not used because it does not worth the effort yet.
Intense gamma rays make handling the material much more difficult and it makes the activities much easier to detect. Even if you keep humans out of the process it means you have to make everything more radiation tolerant. You also have to worry about the gamma rays producing neutrons and so on.
Related to Why isn't Thorium used for reactor fuel rods?
1. Why isn't Thorium used for reactor fuel rods?
Thorium is not used for reactor fuel rods primarily because it cannot sustain a nuclear chain reaction on its own. Unlike uranium, which is commonly used in nuclear reactors, Thorium does not produce enough neutrons to sustain a reaction. However, it can be used as a supplement to uranium in certain types of reactors.
2. Is Thorium a safer alternative to uranium for nuclear reactors?
Thorium does have some safety advantages over uranium, such as its higher melting point and lower levels of radioactivity. However, it still produces radioactive waste and has the potential for accidents. Therefore, it is not necessarily a safer alternative but may have some benefits in certain reactor designs.
3. Why hasn't there been more research and development on using Thorium as a fuel source?
The main reason for the lack of research and development on Thorium as a fuel source is due to the abundance and already established infrastructure for using uranium. Many countries already have well-developed nuclear energy programs and it would require a significant investment and effort to switch to using Thorium.
4. Can Thorium be used in existing nuclear reactors?
Thorium can be used in existing nuclear reactors, but it would require modifications and changes to the reactor design. This is because Thorium has different properties and behaviors compared to uranium, so it would require a different fuel rod design and control mechanisms.
5. Are there any countries currently using Thorium as a fuel source?
There are a few countries that have experimented with using Thorium as a fuel source, such as India, China, and some European countries. However, no country has fully adopted Thorium as the primary fuel source for their nuclear reactors. More research and development is needed before it can be considered a viable alternative to uranium.
  • Nuclear Engineering
