Understanding the Mass Defect in Nuclei
In summary, mass defect occurs when a comparatively unstable nucleus converts to a stable one, resulting in a decrease in mass due to the release of energy. This energy can be emitted as photons (light) or other particles, such as electron-positron pairs. The concept of mass defect is used to quantify the negative binding energy of the nucleus. In most cases, gamma rays are emitted when nuclei absorb neutrons, while in the fusion of two protons, a positron is emitted.
jd12345
256
Why is there a mass defect in the nucleus?
I think about mass defect in this way - A comparatively unstable nucleus( i.e. low binding energy) converts to a stabel nucleus( high binding energy)
Intially internal energy was U1 and then it became U2.
So when it converts then some energy should be released which should have a value
U1 - U2
Eg:- two protons far apart have some potential energy, when they get closer potential energy decreases so the lost energy is seen as kinetic energy right?
Similarly when a neutron converts to another why the change in internal energy is seen as a mass defect and not kinetic energy or something else?
There are other places the energy can go (light can be emitted, etc), but yes what you have described is basically true. You seem to understand what is going on, so is your question just about the terminology? Why call it a mass defect? Well it is a sensible name, I mean the mass of the combined nucleus is less than the mass of its component parts, so some mass has vanished. It is just the conventional terminology though; one could imagine alternatives.
Ok so let me see if i get this right :- In case of neutrons, when its (internal)energy changes it compensates that lost energy by reducing its mass and releasing energy(photons) right?
So does it always emit photons or can it emit some other particles too?
remark: two protons (di-proton) or two neutrons (di-neutron) are not stable bound states; you need a proton and a neutron (deuteron)
It's possibly easier to think of (eg) a free proton and a neutron as each having zero potential energy, but if they fuse to form a deuteron they then gain negative potential energy as a result of the binding of the (strong) nuclear force. When they fuse, this extra energy is released, eg as a gamma ray.
The result is that the combined mass of the deuteron (E/c2) is less that the sum of those of the free particles, because its total energy is lower. It is convenient to quantify the negative binding energy using the difference between the mass of the combined nucleus and the sum of the individual nucleons' free masses, as these masses are the easiest quantities we can measure. Hence the concept of mass defect.
Err sort of. The mass of these particles is not actually separate from their internal energy. Their mass is associated intimately with the configuration of the quark and gluon fields that they are made up of, which is what I expect you mean by their internal energy. When these things get close to each other the quark and gluon fields get reconfigured, and if they end up in a lower energy state, then the system has less mass, E=mc^2 and all that. The energy has to go somewhere though, so it goes into some other field, i.e. some photons get produced.
I have not studied at all what happens when bound states form, so I don't know exactly what happens, but if the energy difference is large enough to create particles other than photons I see little reason why they should not be produced sometimes. I think the energy difference would not be enough to allow much more than electron-positron pairs to be produced though. Looking at wikipedia, it says the deuteron binding energy is 2.2 MeV, which indeed is enough to produce a couple of electron-positron pairs (1.022 MeV needed each pair), but nothing else.
When nuclei absorb neutrons, it is most often that gamma rays (photons) are emitted. The resulting nuclide may emit a beta particle, but usually the initial energy is emitted as a gamma ray.
In the case of two protons 'fusing', e.g., in the p-p fusion chain of stars, a positron is emitted in conjunction with the transformation of a proton (uud) into a neutron (udd) - or rather the transformation of an u (up quark) to a d (down quark).
http://hyperphysics.phy-astr.gsu.edu/hbase/particles/qrkdec.html#c1
http://hyperphysics.phy-astr.gsu.edu/hbase/particles/quark.html#c3
http://hyperphysics.phy-astr.gsu.edu/hbase/particles/proton.html#c4
Related to Understanding the Mass Defect in Nuclei
1. What is the mass defect in nuclei?
The mass defect in nuclei refers to the difference between the mass of an individual nucleon (proton or neutron) and the mass of the nucleus as a whole. This difference is caused by the release of energy during the formation of the nucleus.
2. How is the mass defect calculated?
The mass defect is calculated by subtracting the mass of the individual nucleons from the mass of the nucleus. The difference in mass is then converted to energy using Einstein's famous equation, E=mc².
3. What is the significance of the mass defect?
The mass defect is significant because it explains the source of energy in nuclear reactions. The energy released during the formation of a nucleus is what powers nuclear reactors and nuclear weapons.
4. How does the mass defect differ between nuclear reactions?
The mass defect can vary between different nuclear reactions depending on the type of nuclei involved and the amount of energy released. Generally, heavier nuclei have a larger mass defect, meaning more energy is released.
5. Can the mass defect be observed experimentally?
Yes, the mass defect can be observed experimentally using mass spectrometry. By measuring the mass of individual nuclei and comparing it to the mass of their constituent nucleons, scientists can confirm the existence of a mass defect and calculate the amount of energy released.
