Why most of the fans have three wings
  • Thread starter ajayguhan
  • Tags
    Wings
In summary, the most common number of blades on commercial fans is three because they sell best. There are other reasons for considering making blades with few blades rather than lots, and why an odd number would be a better design than an even number, but the configuration that does not sell, no matter how great it is otherwise, would not get made.
ajayguhan
153
Why most of the fans have three wings, why not two, four, five and so on.
The site says that they can have any number of blades depending upon certain factor.
It doesn't explain why most commercial fans have three blades?
That is correct - what are the factors that the number of blades depends on?
The site is one example of many sites which talk about this - you learn best when you do the footwork yourself, go look for other places this question may have been discussed. hint: physics forums has a search function.
You should start to get an idea of the decision making that goes into the design.
... are there any other factors which may influence the design of a commercial fan?
Aside: how did you determine the number of blades that "most commercial fans" have?
Ceiling fans usually have 4-5 but can go from 2 to 7 for example, my wee fan heater has a disk of about 20 blades in the blower and my desk fan has 5. These are all commercial fans.
Aside from commercial design considerations, as the number of blades in an axial (compare ducted) fan increases so does their restriction of the flow rate. Gedanken; imagine an operating fan, change only the number of blades, in the limits the fan stops moving air axially.
Not necessarily. The number of blades will be determined by the needs of the fan - fewer blades tend to be optimum when you want a high flow rate and efficiency, but do not need a large pressure change across the disk of the fan. If there is a large pressure change though, many more blades can be the optimum (look at the front fan on a turbofan jet engine for example).
I'd like to hear from ajayguhan before we get too far into this.
The bottom line is pretty prosaic - commercial fans tend to have three blades because those sell best.
However - there are markets for fans with different numbers of blades. There are other reasons for considering making blades with few blades rather than lots, and why an odd number would be a better design than an even number, but the configuration that does not sell, no matter how great it is otherwise, would not get made.
I'm hoping that ajayguhan will be able to identify the other constraints with a little effort.
Note: As my guide for what "commercial fan" means, I am using the google image search on the term.
This search produces mainly desk or floor standing fans and a few, small, portable, industrial designs.
3-blades in a cage is the by far the dominant design with 18 examples in the first 28.
4 blades was the next most common with 6.
Note: no aircraft-engine fans.
Doing a web search for household fans shows mostly 3 and 5 bladed fans (for fans with blades) at amazon. Also wiki.
http://en.wikipedia.org/wiki/Mechanical_fan
At our home, we a 12 inch 3 bladed fan with circular housing, and a 20 inch 5 bladed fan with a box housing. The compressor fan on our air conditioning unit has a 4 bladed fan.
It can be fun checking assumptions - one of the things I wanted OP to do.
You can check the blade shape and number against the obvious constraints - which I don't want to comment on yet.
Hmm does the box housing all-but obscure the fan?
The Pitch on the blades and how much noise the consumer will put up with count for a lot. Other than that it is mostly about having the newest style.
http://christopherteh.com/blog/wp-content/uploads/2014/05/ceiling-fans.jpg
No, just a thin plastic "grill" in an otherwise open front and back. Do a google search for "household box fan images", and you see a few similar to our 20 inch box fan. Ours is old (30+ years) and has square corners instead of rounded corners.
You won't find 4-bladed fans made in China, because the Chinese think 4 is an unlucky number.
Even in the west, 3 and 5 blades probably "look nicer" (i.e. less boringly symmetrical) than 4 when the fan is switched off.
On the other hand, the fans on the front of most large jet engines have about 24 blades (plus or minus one or two) because that is the most efficient number for them to have, not because it makes them look pretty.
@rcldr: Oh OK - I've been musing on how many-blade fans seem to be hidden.
Hmmm... the google images for box fans most of them have 5 blades.
Efficiency is much more important for a jet engine than for a desk or ceiling fan - but in both cases, the controlling restriction is "which makes us the most money". You can also get some good clues to design constraints by comparing with windmills.
I had thought that the 3 blade fan( or even a multiple of 3 ) had a more even balance than a 2 or 4, especially when one considers the blade part is stamped from a sheet of metal, and thus the tolerance of the manufacturing process do not have to be of extra high precision.
A 2-blade rotor has a different moment of inertia about different axes (along the blades and at right angles to them). That can create dynamic instability problems, but it's not likely to affect a low-speed room fan. It is a design issue for 2-blade aircraft propellers and helicopter rotors though.
Four blades are no better or worse than and other number greater than 2, so far as rotor balancing is concerned.
I understand that there are fewer resonances for an odd number of blades.
The issue with low-speed room fans is the noise you get from the wobble.
It can be surprising to a lot of people just how many every-day design concepts are not strongly constrained by engineering.
A three bladed fan has constant MMOI about any transverse axis. This is important in some high speed applications, particularly if the fan must yaw (such as a power generating windmill).
Related to Why most of the fans have three wings
1. Why do most fans have three wings?
The majority of fans are designed with three wings because it allows for more efficient air circulation. The three-winged design creates a vortex effect, pulling air in from behind the fan and pushing it forward, resulting in a stronger breeze.
2. Is there a specific reason for the number of wings on a fan?
Yes, the number of wings on a fan is carefully chosen to optimize the air flow. In the case of three wings, it is the most efficient design for creating a vortex and producing a powerful breeze.
3. Do all types of fans have three wings?
No, there are various types of fans that have different numbers of wings depending on their purpose. For example, ceiling fans may have four or five blades for a more balanced distribution of air, while desk fans may have only two blades for a more concentrated airflow.
4. Can a fan with three wings cool a room faster than a fan with two wings?
In most cases, a fan with three wings will cool a room faster than a fan with two wings. This is because the three-winged design creates a stronger, more efficient airflow, resulting in quicker circulation of air and a cooler room.
5. Are there any other advantages to a fan with three wings?
Aside from being more efficient at cooling a room, a fan with three wings also tends to be quieter than a fan with two wings. Additionally, the three-winged design is aesthetically pleasing and can add a decorative touch to a room.
