Why must the state transformation be unitary?
  • I
  • Thread starter eoghan
In summary, the necessity for state transformation to be unitary arises from the principles of quantum mechanics, specifically the conservation of probability and the preservation of information. Unitary transformations ensure that the total probability remains equal to one and that quantum states evolve in a reversible manner. This characteristic is crucial for maintaining the coherence and integrity of quantum information, which is fundamental to processes such as measurement and quantum computation.
eoghan
210
TL;DR Summary
Why can't we have non-unitary transformations followed by a normalization of the transformed state, instead of considering only unitary transformations that lead to normalized states?
Hi there,
In QM it is said that state transformations must be implemented via unitary operators. The reason is that, if ##\left| \Psi\right\rangle## is a normalized state and ##U## is a unitary operator, than ##U\left|\Psi\right\rangle## is also normalized.
But why do I need ##U\left|\Psi\right\rangle## to be normalized? A state in QM is actually a ray in a Hilbert space, so if ##\left|\Psi\right\rangle## represents my state, ##\alpha\left|\Psi\right\rangle## also represents my state. Therefore, I can apply a non-unitary operator and then divide the resulting state to make it normalized.
What am I missing?
eoghan said:
TL;DR Summary: Why can't we have non-unitary transformations followed by a normalization of the transformed state, instead of considering only unitary transformations that lead to normalized states?
Hi there,
What am I missing?
Is that a well-defined process? The scale factor ##\alpha## will depend on the initial state. That's no longer a well-defined operator. Consider ##Tu, Tv, T(au + bv)##, where ##T## is a non-unitary operator.
eoghan said:
What am I missing?
If you got a probability of 7, would this be sensible?
Hi there,
What am I missing?
It's not only that you have to preserve the norm of a state ket but the entire system of equations of QT. This means a transformation that preserves one to one all equations of QT you have to think of what's the essence of the entire formalism.
You have quantum states, which are described in the most general case by a statistical operator ##\hat{R}##, which is a positive semidefinite adjoint operator with trace 1. Then you have a set of self-adjoint operators, which build the observable algebra with the commutator as the algebraic operation (building a Lie algebra). Finally the physical meaning of the state is that for a complete set of compatible observables, ##A_1,\ldots,A_n##, the probability to find the eigenvalues ##a_1,\ldots,a_n## of their representing operators ##\hat{A}_1,\ldots,\hat{A}_n##,
$$P(a_1,\ldots,a_n)=\langle a_1,\ldots,a_n|\hat{R}|a_1,\ldots,a_n \rangle.$$
It turns out that the most general type of transformations of this entire mathematical system are unitary (or antinitary) transformations.
Likes Spinnor
My idea goes like this. Let's suppose there is an observable ##A## with eigenvalues ##a_1##,...,##a_n## and eigenvectors ##|a_1\rangle##,...,##|a_n\rangle##. Our state is described by a state vector ##|\Psi\rangle##. The probability to measure the value ##a_1## for ##A## is then given by
P(a_1) = \frac{\langle a_1|\Psi\rangle\langle\Psi|a_1\rangle}{\langle\Psi|\Psi\rangle}
Similarly, under a non-unitary transformation ##\hat R##, we have
P(a_1) = \frac{\langle a_1|\hat R|\Psi\rangle\langle\Psi|\hat R^\dagger |a_1\rangle}{\langle\Psi|\hat R^\dagger \hat R|\Psi\rangle}
Therefore, the probability cannot be, e.g., 7. Nor it doesn't matter if the normalization factor depends on the initial state. The denominator would take care of both cases.
Interesting. Can you please elaborate on this? Or, do you know some textbook / reference about this?
Okay.
What is your physical interpretation of that calculation?
Therefore, the probability cannot be, e.g., 7. Nor it doesn't matter if the normalization factor depends on the initial state. The denominator would take care of both cases.Interesting. Can you please elaborate on this? Or, do you know some textbook / reference about this?
This is known as Wigner's theorem. A very concise derivation can be found in the (older) textbook by Gottfried:
Kurt Gottfried, Quantum mechanics, CRC (1974)
For a general transformation ##\hat R##, that won't necessarily be a real number. In fact, I suspect it's only a real number for all states ##\Psi## if ##\hat R## is a scalar multiple of a unitary transformation.
FAQ: Why must the state transformation be unitary?
What is a unitary transformation?
A unitary transformation is a linear transformation that preserves the inner product in a complex vector space. Mathematically, a transformation U is unitary if it satisfies U†U = UU† = I, where U† is the conjugate transpose of U and I is the identity matrix. This ensures that the transformation preserves the length and orthogonality of vectors.
Why is unitarity important in quantum mechanics?
Unitarity is crucial in quantum mechanics because it ensures the conservation of probability. A unitary transformation preserves the norm of the state vector, which corresponds to the total probability of all possible outcomes of a quantum measurement. Without unitarity, probabilities could either increase or decrease in ways that would violate the fundamental principles of quantum theory.
How does unitarity relate to the evolution of quantum states?
In quantum mechanics, the evolution of a closed quantum system is described by the Schrödinger equation, which involves a unitary operator. This means that the time evolution operator, which governs the change in the state of the system over time, must be unitary to ensure that the system's state remains valid and that probabilities sum to one throughout the evolution.
What happens if a transformation is not unitary?
If a transformation is not unitary, it can lead to non-physical results such as probabilities that do not sum to one, which violates the fundamental principles of quantum mechanics. Non-unitary transformations can lead to the loss or gain of information, making the system's evolution unpredictable and inconsistent with the established framework of quantum theory.
Can measurements in quantum mechanics be described by unitary transformations?
While the evolution of a quantum state is governed by unitary transformations, measurements are described by a different process called wavefunction collapse, which is generally non-unitary. However, the overall process, including both the unitary evolution and the measurement postulates, ensures that the probabilities remain consistent with the rules of quantum mechanics.
