Why must the x and y axis be perpendicular?
In summary, the x and y-axis must be perpendicular in the Cartesian coordinate system, which is conventionally used in physics. This allows for easier calculations and is a standard convention used globally. However, in general, it is not a necessity and other coordinate systems can be defined with non-perpendicular axes. The concept of vector bases is further explained in linear algebra.
Phillipv2004
I have a conceptual question regarding why the x and y-axis must be perpendicular. Chapter 2 in section 2-1 of Giancoli's Physics states that " The x and y axes are always perpendicular". This chapter is one-dimensional motion and the section is Reference frames and Displacement.
It is a convention, not a necessity. It makes calculations a lot easier as if the angle was another, but it is not a must. However, if you say ##x,y## coordinates, everybody around the world will assume perpendicular axis. So it you should use others, please tell.
They are perpendicular because that's how the Cartesian coordinate system is defined. In general, they don't have to be, in the sense that one can define a coordinate system in N dimensions consisting of N linearly independent basis vectors that can be at any angle w/r to each other. So for example in 2 dimension you could have a coordinate system defined by two vectors at 45° to each other, and still be able to uniquely name any position on this 2D plane as well as convert to the Cartesian coordinates.
But the Cartesian coordinate system is conventionally used in much of physics, and it requires the axes to be at 90° by definition.
The topic of vector bases is covered by linear algebra, so if you are going to be taking those classes, it'll all be explained there.
Related to Why must the x and y axis be perpendicular?
What is the purpose of having perpendicular x and y axes?
The perpendicular x and y axes serve as a reference point for plotting and analyzing data. By having them intersect at right angles, it allows for accurate measurement and comparison of different variables.
Why is it important for the x and y axes to be perpendicular?
If the x and y axes were not perpendicular, it would be difficult to accurately determine the relationship between two variables. The perpendicularity ensures that the axes are independent of each other and do not influence the data being plotted.
Can the x and y axes be at any other angle besides perpendicular?
Yes, the axes can be at any angle depending on the type of graph being used. For example, in a polar coordinate system, the axes are not perpendicular but instead intersect at the origin and form a 90-degree angle with the radial line.
What happens if the x and y axes are not perpendicular?
If the axes are not perpendicular, it can lead to distorted or inaccurate data representation. This can affect the interpretation of the data and potentially lead to incorrect conclusions.
Why do we use perpendicular axes instead of parallel axes?
Perpendicular axes allow for a clearer and more precise visualization of the data. Parallel axes can make it difficult to distinguish between different variables, especially when dealing with large datasets.
