Why no smear in Stern-Gerlach experiment?
In summary: File:Negatively_birefringent_material.svgA birefringent crystal like calcite might be a good analog for photons of the SG apparatus for silver atoms. In summary, the non-uniform magnetic field in the Stern-Gerlach apparatus forces a selection into eigenstates, just as it does with photons.
Alfred Cann
82
Why do the silver atoms not exist in a superposition of states with every possible mixture of spin-up and spin-down? Thermal photons do.
Because they are sent through a spin analyzer which forces them into eignestates of Jz.
Likes bhobba
What is the spin analyzer, the non-uniform magnetic field? How does that force a selection into eigenstates? If an atom has, for example, zero net spin because of superposition, wouldn't it go straight?
The equal superposition of spin-up and spin-down is not a state of zero net spin (in fact the spin has no value at all until we perform a measurement - it's like asking whether a tossed coin is heads-up or tails-up before you've tossed it). Instead, it is a state in which an interaction that depends on the spin has a 50% chance of coming out as if the spin is up and a 50% chance of coming out as if the spin is down. We call these interactions "measurements" or "observations" Of the spin because when we look at the result we know what the spin is now that the interaction has happened. The interaction with the non-uniform magnetic field is such an interaction.
In the original formulation of quantum mechanics (the "Copenhagen interpretation") we would say that the wave function was a superposition of spin-up and spin-down until it encountered the non-uniform magnetic field; and the interaction with the magnetic field caused the wave function to "collapse" into one of the two non-superimposed possibilities.
One of the postulates of quantum mechanics is that the result of a measurement must be one of the eigenvalues of the observable we're measuring (spin-up and spin-down in this case), and that immediately after the measurement the system will be in the corresponding eigenstate.
Likes bhobba
The Stern-Gerlach apparatus does not make pure states of determined ##J_z## out of a beam of thermal (i.e., unpolarized) particles but it creates a state where ##J_z## is entangled with position. With an ideal Stern-Gerlach apparatus you can then make a beam of a (nearly) pure eigenstate with determined ##J_z## by blocking out all other partial beams with a different ##J_z##. No collapse esoterics is needed just some material blocking the particles, you don't want to consider further ;-)).
I think I've got a partial understanding. The SG apparatus can only detect spin-up and spin-down. It is blind to all other states. If an atom comes in with, say, spin right, the apparatus will decompose that into its spin-up and -down components, each with probability amplitude of 0.707, and display those. This is quite counter-intuitive.
The photon case is easier to understand; a photon either gets thru a polarizer or not; you can't get 60% of a photon. If a photon goes thru a vertical polarizer, all we know is that it wasn't horizontally polarized. Its polarization could have been linear at any other angle, or elliptical of either handedness with any degree of ellipticity at any angle, which meant it had a vertical component, which, in turn meant it had some probability of going thru the polarizer. Oh, and after the polarizer we know it's vertically polarized.
How so? The difference between the two cases is that either the photon goes through or it doesn't. We could produce the same effect with the S-G machine just by blocking one or the other paths out so that we can describe the situation as "either the atom gets through or not". You can't get 60% of a photon, but you also (even more forcefully) can't get 60% of an atom.
Likes vanhees71
Likes Mentz114 and vanhees71
Related to Why no smear in Stern-Gerlach experiment?
1. Why is there no smear in the Stern-Gerlach experiment?
The lack of smear in the Stern-Gerlach experiment is due to the quantum nature of particles. In classical physics, particles are expected to take on a continuous range of values for their properties, such as spin. However, in quantum mechanics, particles have discrete values for their properties, resulting in no smear in the experiment.
2. Can the lack of smear in the Stern-Gerlach experiment be explained by classical physics?
No, the lack of smear in the Stern-Gerlach experiment cannot be explained by classical physics. Classical physics predicts that particles should have a continuous range of values for their properties, while the experiment shows that particles have discrete values. This is a fundamental difference between classical and quantum mechanics.
3. How does the Stern-Gerlach experiment demonstrate the quantization of spin?
The Stern-Gerlach experiment demonstrates the quantization of spin by showing that particles have discrete values for their spin when passing through a magnetic field gradient. This is observed as distinct bands in the experiment, instead of a continuous spread of values as predicted by classical physics.
4. Why is the Stern-Gerlach experiment important in quantum mechanics?
The Stern-Gerlach experiment is important in quantum mechanics because it provides evidence for the quantization of spin and the discrete nature of particles. It also played a crucial role in the development of quantum mechanics, leading to the understanding of the wave-particle duality of matter and the formulation of the Schrödinger equation.
5. Can the Stern-Gerlach experiment be used to measure the spin of any particle?
No, the Stern-Gerlach experiment is limited to measuring the spin of particles that have a magnetic moment, such as electrons and protons. Particles without a magnetic moment, such as photons, cannot be measured using this experiment.
  • Quantum Physics
  • Quantum Physics
