Why normal force is not equal to gravity?
In summary, the normal force is not always equal to the gravitational force because it depends on the specific conditions of the system. The normal force acts perpendicular to the contact surface and can vary due to factors such as the angle of inclination, additional forces acting on the object, or the presence of friction. For instance, on an inclined plane, the normal force is less than the gravitational force, while in scenarios involving vertical acceleration, it can exceed gravitational force. Thus, the normal force and gravitational force are distinct and can differ based on the context.
  • #36
kuruman said:
here is an "action" force on the mass but the mass can exert no "reaction" force on anything because it doesn't exist. .
action force is centripetal?
What you say about my post #34?
  • #37
I say that's a different physical situation. I am considering a simpler case to answer your question
user079622 said:
why we need introduce fictive forces if object dont accelerate?
and I have answered that.
  • #38
user079622 said:
But if moon rotate very fast,(so no synchronous rotation) we have now two sources of centripetal acceleration, revolution and rotation?
Why not then?
You would still be double dipping. The two sources are still not independent.
  • #39
So you want to say that ball that revolving 500rpm and spinning 1000rpm has same centripetal acceleration as ball that is only spinning 1000rpm?
This sound impossible.
  • #40
user079622 said:
So you want to say that ball that revolving 500rpm and spinning 1000rpm has same centripetal force as ball that is only spinning 1000rpm?
What do mean by "has same centripetal force"? Maybe draw a diagram and label is properly.
  • #41
I mean centripetal acceleration,
Point A and B has same centripetal acceleration?
  • #42
Be careful. Are you specifying a "sidereal" rotation rate? Or a rotation rate relative to a frame that rotates with the orbit?
Let us assume sidereal. Let us speak of a bug perched on a rigidly spinning ball in a circular orbit about the center of a carousel.
We calculate the centripetal acceleration required to keep the bug on the surface of the spinning ball without accounting for the orbital motion. Simple. That's ##\omega^2r## where r is the ball's radius and ##\omega## is the rotation rate of the ball.
Now we go to add in the orbital motion.
The center of the ball is at one orbital radius. The outer surface of the ball is at a larger orbital radius. The acceleration of the bug relative to the ball due to the orbital motion would seem to be the difference of the two. But wait a minute... If we used this calculation, it would be like assuming that the bug is moving in lock step with the carousel. But it is not. The ball is spinning. The bug is moving with the ball. And we've already accounted for the acceleration associated with that spin.
So to do the calculation correctly, we would need to do the orbital calculation as if the ball has zero sidereal rotation. In that case, the bug's acceleration due to orbital motion would exactly match the acceleration of the center of the ball.
  • #43
Tangential velocity and radius of point A and B are different.
why you calculate like there are same?
it could be 2 turn table,frame earth, inertial
small table r=1m, 1000rpm
big table r=10m, 500rpm
point A at small table, ac=10966 m/s2 , tangential velocity=104 m/s
now I am first find what is tangetianl velocity at point B if table is lock to table, so r=11m tan. velocity=576 m/s
I add both tang. velocity 104+576=680 m/s is in point B,when table spin unlock from big table
ac=42036 m/s2
I am not sure if I correct calculate tangential velocity at point B...I strugle in relative motion.
Velocity 104 and 576 are both relative to earth, so I think cant add them,
I turn out that velocity at B due to just "revolution"(lock small table to big one) is faster then velocity of A, I must get velocity at B when small table is spinning
  • #44
@jbriggs444
I post task to Homework help, where it belong.
  • #45
What is providing the centripetal acceleration? Gravity or a carousel?
  • #46
carousel
  • #47
So not relevant to the normal force on the moon.
  • #48
But I didnt mention normal force for this task.
  • #49
user079622 said:
We learned that normal force equal in magnitude as mg and opposite direction, it is reaction force to gravity.
1.If normal force is not equal gravity, isnt this violate newton 3. law action=reaction?
2. If gravity is higher than normal force , this system has net Force non zero,it means accelerate in dircetion of higher force ,which is not true?
3.Professor say it must be higher otherwise we will not move with earth?
It can be equal, when rotate stone with rope,stone pull your arm with same force as arm pull stone,so not need to be higher..
When an object is placed on a horizontal bench in the class room, we have several pairs of forces, which are reaction forces as mentioned in Newtons 3rd law.
1: The object pushes down on the surface -- the surface pushes up on the object.
2: The Earth pulls down on the object -- the object pulls up on the Earth (effect of gravity)
3: The bench pushes down on the Earth -- the Earth pushes up on the bench.
Each force in those pairs are equal in magnitude and opposite in direction.
If you were to place a 1 kg mass on top of your object, the pair of forces mentioned in #2 do not change, but the upward force on the object MUST increase, as it now supports both the object AND the 1 kg mass
Likes PeroK
  • #50
user079622 said:
16:23
The presenter made a very misleading statement.
He said the force of gravity had to be slightly more than the normal (reaction) force.
The size of the force of gravity is determined by the mass of the two objects (Earth and Person) and the separation of their centres of mass. We cannot alter any of those, so the force of gravity does not change.
He should have said "the reaction force is slightly less than the force of gravity" (giving the net downward force)
Note: another way to reduce the Normal force, would be to attach a Helium balloon to you - but not one big enough to lift you off the round. (Perhaps a couple of those balloons people take to parties).
Likes PeroK
