Why not a particle for charge?
In summary, the Higgs field gives mass to elementary particles, which explains one of the properties of matter, mass. However, there is no field that gives particles a charge, and the electron's charge and the charge of neutrons and protons are determined by the arrangement of quarks. Additionally, there are other properties of matter such as spin, helicity, and color, which are rarely discussed in popular science. The Higgs field itself has a generic mass term but with the "wrong sign," causing a breaking of the local gauge symmetry and giving rise to the Higgs boson. The fermions in the standard model are originally massless, but the interaction between the Higgs boson and fermions acts as a mass term
Mayank Jately
I was recently seeing videos on standard model of particle physics and something occurred to me that ,Higgs field gives mass to elementary particles ,this gives reason for one property of matter that is mass. Why not a field that gives elementary particles a charge ? After all their are two properties of matter - mass and charge. if their is a field what is it called ?if not then how does electron gets its charge?Also how does arrangement of quarks determine the charge of neutron or proton?
And spin, helicity, isospin, strangeness, weak hypercharge, lepton flavor numbers, color, and many more. You'll rarely see them in popular science but they exist.
Mass is fundamentally different from all the other properties. It is not a multiple of some elementary number, it is directly linked to the rest energy of the particle (unlike all others), and so on.
In spin-charge separation phenomenon in 1D conductors, we have "chargons" or "holons", which are the carrier of charge that have been "separated" from the spins of those particles.
Zz.
Some people say that the Higgs gives the other particles mass, but that’s inaccurate (at best). The Higgs gives only about 2% of the mass of the matter around us in everyday live. The rest is provided by the spontaneous breaking of chiral symmetry and the trace anomaly in QCD. Within the standard model of elementary particles the condensate of the Higgs field provides mass to the quarks and leptons.
The Higgs field itself has a generic mass term by its own, but with the “wrong sign”, so that the local SU(2) x U(1) gauge symmetry is broken to U(1). The great discovery of Brout and Englert, Higgs, and Guralnik, Hagen, Kibble (all three articles in PRL 13, 1964) was that in the case of such a spontaneous breaking of a local gauge symmetry is an exception to Goldstone’s theorem that applies to global gauge symmetries only. In the case of a spontaneously broken local gauge symmetry the “would-be Goldstone bosons” are lumped into the gauge fields of the broken part of the symmetry group and thus provide the longitudinal third component of a massive vector boson, i.e., these gauge bosons become massive. In the case of the electroweak standard model that means that the SU(2) weak-isospin gauge bosons become massive (these are the three W and Z bosons), while the unbroken electromagnetic U(1) keeps its massless gauge boson (the photon). Excitations of the Higgs field above its vacuum expectation value (VEV) appear as physical particles in the theory, and that’s the Higgs boson. It gets its mass from the generic mass term and part of the Higgs-self interaction around the VEV. This leads to an effective mass term for the Higgs boson with the right sign. For the usual choice of a “minimal Higgs sector”, where the Higgs field is a SU(2) weak-isospin doublet (4 real field-degrees of freedom, of which 3 are providing the longitudinal components of the W and Z bosons and 1 describes Higgs-boson particles after spontaneous symmetry breaking).
In the original version of the Standard Model, the fermions are massless. When you try to add a mass term by hand, it violates gauge invariance. If there is a Higgs boson, there would have to be an interaction term between the Higgs boson and the fermions, and that interaction term has the same mathematical form as a mass term for the fermions would have, if there were a mass term, and so therefore you can use the interaction term between the Higgs boson and the fermions for the mass term for the fermions, and thus you end up with a mass term for the fermions.
The Higgs boson mass is given by m_H = √ λ/2 v, where λ is the Higgs self-coupling parameter and v is the vacuum expectation value of the Higgs field, v = (√ 2G_F )^ {−1/2} ≈ 246 GeV, fixed by the Fermi coupling G_F , which is determined with a precision of 0.6 ppm from muon decay measurements. λ is presently unknown. Therefore, the Higgs boson mass depend on the Higgs VeV.
  • Beyond the Standard Models
