Why not use proton bombardment to trigger nuclear fission?
In summary, fission type nuclear bombs and nuclear reactors use neutron bombardment to trigger the fission reaction because it takes much more energy to accelerate protons than the energy produced by fission. This method is only used for research neutron sources. The neutrons are easier to release in the spallation process because they do not have a charge and are not repelled by the protons or electrons in the nucleus. Protons are more difficult to use for bombardment due to their positive charge, requiring a lot of energy to get close enough to the nucleus for a reaction to occur. This is why neutrons are preferred for inducing fission reactions.
Bararontok
298
Fission type nuclear bombs and nuclear reactors use neutron bombardment to trigger the fission reaction but why not protons? Protons can repel the like electromagnetic fields of the other protons in the atomic nucleus so why not bombard the nucleus with protons instead?
That works perfectly well, only you need much more energy to accelerate the protons than you get out of the fission. It is therefore used only for research neutron sources.
Look at the "production of neutrons" section in this Wiki article
http://en.wikipedia.org/wiki/Spallation
Why are the neutrons easier to release from the atoms in the spallation process?
Because in another thread,
https://www.physicsforums.com/showthread.php?t=594030,
also in this forum, atoms with more protons are more unstable because the protons repel each other due to their like charges. So should this not make it easier for protons to be released from the atom?
In the design of fission nuclear bombs it is said that it is the neutrons added to the radioactive isotopes that makes them unstable enough to fission when the atoms are collided together using the gun-type and implosion assembly methods. But why is this so when atoms with more protons are the ones that are supposed to be unstable? Should it not be the atoms with more protons that are more likely to fission during nuclear spallation?
Could it be that the protons are more difficult to use for bombardment because they may repel each other but the electrons in the atoms are keeping them bound to the atom because of the attraction of opposite charges?
But if this is the case, why should the neutrons be easier to release if there are no repulsion forces making it difficult for them to bind?
If you want protons, you just strip the electron off a Hydrogen atom, at the cost of 13 eV or so. No need for nuclear physics.
If you want neutrons, (and a lot of experiments do) you have to use nuclear physics.
Lighter nuclei have a lower ratio of neutrons/protons, therefore fission tends to produce extra, free neutrons.
The question is how to induce fission. Either by neutrons, which is easy because the neutron has no charge (but you need a source of neutrons to do this), or by spallation with protons.
Protons are more difficult to use because of their charge. It takes a lot of energy to get the proton close enough to the (positively charged) target nucleus before any nuclear reaction can happen.
That is correct. The neutron from a source can be collided into an atom more easily because it will not be repelled like the proton since it has no charge. If a charged particle is used, either the positive charge of the protons or the negative charge of the electrons will repel the charged particle and prevent spallation from happening in the first place.
It needs a lot of energy for protons
Yes. The best neutron yield per unit energy is for ~ 2 GeV protons on a tungsten (or lead) target, and I think the optimum yield is ~ 20 spallation neutrons per proton per GeV (= 50 MeV per neutron). See plot for lead on ~page 7 in http://www.physics.indiana.edu/~p537/notes/20060927_Pynn.pdf
Related to Why not use proton bombardment to trigger nuclear fission?
1. What is proton bombardment?
Proton bombardment is a process in which high-energy protons are accelerated and directed towards a target material.
2. How does proton bombardment trigger nuclear fission?
When high-energy protons collide with the nucleus of an atom, they can cause it to split into two smaller nuclei, releasing a large amount of energy. This process is known as nuclear fission.
3. Why is proton bombardment not commonly used to trigger nuclear fission?
Proton bombardment is not commonly used to trigger nuclear fission because it requires a large amount of energy to accelerate the protons and a specialized facility to contain and direct the high-energy particles. This makes it a more expensive and complex method compared to other fission triggers.
4. Are there any advantages to using proton bombardment for nuclear fission?
One potential advantage of using proton bombardment for nuclear fission is that it can produce a more controlled and precise reaction, as the energy and direction of the protons can be carefully manipulated. This could potentially lead to more efficient and safer nuclear power generation.
5. Are there any potential risks associated with using proton bombardment for nuclear fission?
While proton bombardment may offer some advantages, it also poses potential risks. The high-energy protons can cause damage to the surrounding materials and can produce radioactive byproducts. Additionally, the technology and facilities required for proton bombardment are complex and require careful maintenance and operation to ensure safety.
