Why observables are represented as operators in QM?
In summary, the use of operators to represent observables in quantum mechanics allows for a more general algebra of possible events, which is necessary for making accurate predictions. This algebra also requires a probabilistic treatment based on Hilbert spaces. The introduction of operators in quantum mechanics was first proposed by Heisenberg in his 1925 paper, where he aimed to find a quantum analogue to the classical equation for power radiated by an oscillating electron. The use of operators also leads to the important concept of non-commutativity, which is a central aspect of quantum mechanics, and can be seen as a fundamental difference between classical and quantum theories. However, the line between classical and quantum theories is not always clear-cut, and the use of operators in
MichPod
231
45
TL;DR Summary
What are the (core) reasons observables are represented as operators in QM?
Can somebody provide an explanation why the dynamical variables/observables are represented in QM as linear operators with the measured values being eigenvalues of these operators?
For energy this is probably trivially and directly follows from the stationary Shrodinger equation which solutions are eigenvectors of the Hamiltonian operator with the eigenvalue being the energy, but why on Earth one would try to introduce the same machniery for any other possible dynamical variable and why does this works?
I know that an operator of an observable may be represented as a sum of eigenvalues multiplied by an outer product of the eigenvectors, so it may be considered that the operator just directly encodes the results of measurements and corresponding orthogonal eigenstates, but I wonder whether some more may be said about the nature and origin of observable operators formalism in QM and whether some additional physical meaning may be attributed to the measurement operators other than merely mechanically encoding the eigenvalues.
In both classical and quantum physics, observables are technically operators. It's just they are more general in QM. The more general operators in QM permit a more general algebra of possible events, which is needed to make correct predictions.
Likes DarMM
Indeed and furthermore of interest is that the event algebra is of such a form that noncontextual probabilities on it seem to require the Hilbert space formalism and the collapse postulate:
https://arxiv.org/abs/1702.01845
So the algebra of possible events of our world requires a probabilistic treatment based on Hilbert spaces intrinsically.
Likes dextercioby
Operators / matrices were first introduced in Heisenberg's 1925 paper where he tried to find the quantum analogue to the classical equation for the power radiated by an oscillating electron by incorporating the rules of old quantum mechanics (Bohr frequencies, Ritz combination principle). For the details, see Aitchison et al.'s take on Heisenberg's paper.
Heisenberg's guiding principle to use only observable quantities led him to replace the unobservable classical trajectory ##x(t)## of the electron by a collection of transition amplitudes ##\langle m |\hat x | n \rangle \exp(i \omega_{mn}t)## which we now recognize as the matrix elements of the position operator.
He notes that if we want to combine two such collections which represent different observables we get non-commutativity. This is an important ingredient for central aspects of QM like the Heisenberg uncertainty principle. So the simple story is that while numbers are sufficient for classical mechanics we need operators to get the non-commutativity of QM.
The more complicated story is that the line between classical theories and quantum theories isn't as clear cut as it may seem at a first glance which is what I think the other replies are referring to.
Likes lowlize, *now* and fresh_42
Yes, classical physics can be formulated in terms of matrices and operators, along with a non-controversial collapse postulate, because the classical wavefunction now really does just encapsulate our knowledge of the system.
The important difference is that all classical operators commute with each other.
FAQ: Why observables are represented as operators in QM?
Why are observables represented as operators in QM?
In quantum mechanics (QM), observables are physical quantities that can be measured, such as position, momentum, energy, and spin. These observables are represented as operators because they are used to describe the behavior of quantum systems, which are described by wave functions. Operators in QM act on wave functions to produce new wave functions, which represent the state of the system after the measurement has been made.
What is the significance of representing observables as operators in QM?
The representation of observables as operators in QM allows for the prediction of the outcomes of measurements on quantum systems. By applying these operators to the wave function, the probability of obtaining a particular measurement result can be calculated. This is a fundamental aspect of QM, as it allows for the prediction of experimental results and the understanding of the behavior of quantum systems.
How do observables as operators differ from classical mechanics?
In classical mechanics, observables are represented by real-valued functions, such as position and velocity. In QM, observables are represented by operators, which are mathematical objects that act on wave functions. These operators do not have a direct physical interpretation, but rather represent the mathematical operations needed to obtain measurement results.
What is the relationship between observables and eigenvalues in QM?
In QM, observables are associated with eigenvalues, which are the possible outcomes of a measurement. When an observable is measured, the corresponding operator acts on the wave function, and the resulting wave function is a linear combination of the eigenfunctions of the operator. The square of the coefficients in this linear combination represents the probability of obtaining each eigenvalue as a measurement result.
How do observables and operators relate to the uncertainty principle?
The uncertainty principle in QM states that certain pairs of observables, such as position and momentum, cannot be simultaneously measured with arbitrary precision. This is because the operators representing these observables do not commute, meaning that the order in which they are applied affects the outcome. This relationship between observables and operators is a fundamental aspect of QM and highlights the probabilistic nature of quantum systems.
