Why only Closed Forms Matter in DeRham Cohomology?
In summary, DeRham cohomology is isomorphic to singular cohomology with real coefficients, and closed forms give you information about chronology while non-closed forms don't. Topological features de Rham cohomology captures include integration and the de Rham isomorphism.
WWGD
11,340
Hi All,
One gets homological/topological information (DeRham cohomology ) from a manifold by forming the algebraic quotients
H^Dr (n):= (Closed n-Forms)/(Exact n- Forms)
Why do we care only about closed forms ? I imagine we can use DeRham's theorem that gives us a specific isomorphism with Singular Homology to see why, but I cannot see an answer off-hand?
We do not care only about closed forms. But closed forms modulo exact forms give you the chronology with real coefficients. The key is Stokes Theorem.
Well yes, but that seems to beg the question ( and I think I am using that expression correctly here). Why is it that the quotient gives you information ; why is it that non-closed forms give you no information?
To give an example, if you have a divergence-free vector field, then to find the line integral around some loop, you can choose any surface you want and integrate the curl vector field over that. Gives you independence of the surface. So, it's a higher-dimensional version of that.
As to why it gives topological information, that's the universal coefficient theorem, which basically says homology and cohomology are two sides of the same coin. The example I gave is illustrating the fact that the Kronecker pairing is well defined on homology (cocycle evaluates to the same thing in a well-defined way on homology, not just on the chain-level), and that's what's involved in the universal coefficient theorem.
So, when you mod out by exact forms, you are making the Kronecker pairing well-defined, so that you get something that's sort of dual to homology, which is the more geometrically meaningful thing, for which we understand why it should be a topological invariant. You could say the same for singular cohomology, as well as De Rham. At least, that's the way I see it.
I guess I don't understand your question. De Rham's theorem proves that de Rham cohomology is isomorphic to singular cohomology with real coefficients. Are you asking how the proof works?
A non closed form will not take on the same value ,in general, on homologous smooth cycles. Therefore such a form is not in the dual space to the singular homology. A closed form is. Two closed forms that differ by an exterior derivative will take on the same value on homologous cycles. Taking the quotient identifies them which is right because their values are the same on smooth cycles.
But I feel that I am still begging the question.
A good example of a form that is not closed but is information packed is a connection one form on a circle bundle. Such a form is closed only if the connection is flat.
Thanks, Lavinia, Homeo; I guess it is up to me now to read the DeRham proof and your answers more carefully before asking a new question.
It might help to revisit where exactly the definition for de Rham cohomology comes from. Basically the idea is given a smooth manifold M we can look at the space Kq of differential q-forms and notice that the exterior derivative gives a map d:Kq→Kq+1 that satisfies d2 = 0. This means we have a cochain complex associated to each manifold and so with a little work it makes sense to call the homology of this cochain complex the (de Rham) cohomology of M; that is, the de Rham cohomology is closed forms modulo exact forms. My hunch is that this is all pretty unsatisfying, but on a formal level at least it explains why closed forms come in.
Now to understand the topological information this provides it is probably best to pay attention to integration and the de Rham isomorphism, as others in the thread have suggested. Try working some examples, especially in the small dimensional cases where we can actually draw the manifold, to get some intuition on exactly what topological features de Rham cohomology captures. If you want a textbook that covers this kind of stuff in detail, then Bott and Tu is a great choice.
Lastly since you seem to be asking why pay attention to only closed q-forms (modulo exact forms) instead of all q-forms, the answer partially comes down to computability. The (co)chain complexes arising in our definitions for the (co)homology of a space often contain lots of topological information. Problem is these things are enormous and pretty much impossible to compute with. Passing to (co)homology provides a major advantage since things get smaller and more manageable and we also pick up some formal rules for computing (like excision, long-exact sequence of a pair, etc) which are tremendously helpful.
I strongly suggest the beautiful proof in Singer and Thorpe.
FAQ: Why only Closed Forms Matter in DeRham Cohomology?
Why is it important to focus on closed forms in DeRham Cohomology?
In DeRham Cohomology, we are concerned with classifying closed differential forms on a smooth manifold. Closed forms are important because they represent exact forms, which have the property that their integral over any closed curve is zero. This property allows us to define cohomology groups, which are used to classify topological spaces and study the global properties of manifolds.
What is the difference between closed forms and exact forms?
Closed forms are differential forms that have zero exterior derivative. This means that they are closed under differentiation and their integral over any closed curve is zero. Exact forms, on the other hand, are closed forms that are also the exterior derivative of some other differential form. In other words, they can be written as the gradient of a scalar function. Closed forms are important in DeRham Cohomology because they represent the building blocks for exact forms.
Can non-closed forms be used in DeRham Cohomology?
No, non-closed forms are not used in DeRham Cohomology. This is because we are only interested in closed forms, which have the property that their integral over any closed curve is zero. Non-closed forms do not have this property and thus, they cannot be used to define cohomology groups in DeRham Cohomology.
How are closed forms related to de Rham cohomology groups?
In DeRham Cohomology, the cohomology groups are defined as the quotient space of the space of closed forms by the space of exact forms. This means that closed forms are the building blocks for defining these cohomology groups. The elements of the cohomology groups are equivalence classes of closed forms, where two closed forms are considered equivalent if their difference is an exact form.
Can closed forms be used to study topological spaces?
Yes, closed forms play a crucial role in studying the topology of a space. In DeRham Cohomology, closed forms are used to define cohomology groups, which are topological invariants. This means that they do not change under continuous deformations of the space. By studying these cohomology groups, we can better understand the topological properties of a space, such as the number of holes or handles it has.
