Why Parseval's Identity Fails for Higher Exponents in Basel Problem
  • Thread starter Boorglar
  • Tags
    Work
In summary: beware that the function might not be real-valued (or even injective), and that the integral might not be well-defined.
Boorglar
210
The solution using the Fourier series of x and Parseval's Identity to prove that
[tex] \sum_{n=1}^{∞} \frac{1} {n^2} = \frac{\pi^2} {6} [/tex]
doesn't seem to work for exponents higher than 2, why?
For example, I found the Fourier coefficients of [itex] - \frac{x^2} {4} [/itex] to be
[itex] \frac{(-1)^{n+1}} {n^2} [/itex].
So if I use the same reasoning as in the Basel problem:
[tex] \sum_{n=1}^{∞} \frac{1} {n^4} = \frac{1} {\pi} \int_{-\pi}^{\pi} \frac{x^4} {16} dx = \frac{\pi^4} {40}[/tex]
which is not even close to the correct value.How come when Euler does it, it works like magic, but when I try to do the same thing, it fails? Am I doing something wrong? Is Parseval's Identity valid only for the function f(x) = x?
How come when Euler does it, it works, but when I try to do the same thing, it fails? Is Parseval's Identity valid only for the function f(x) = x? Am I doing something wrong?
What "trick" or "reasoning" are you talking about? There are at least 3 more or less simple functions the Fourier
series of which can give the value of the series of inverse squares, and the same can be done with any series of inverse even powers.
DonAntonio
Unlike for the Basal problem, the Fourier coefficient [itex]a_0[/itex] for the problem you are doing is not zero.
When you account for the [itex]a_0^2[/itex] term, you should get the correct result.
(By the way, Euler solved the problem using different methods than Parseval's theorem).
Also, I think that your Fourier coefficients are not quite correct. They should be
[tex]\frac{1}{2\pi}\int_{-\pi}^\pi f(x)e^{-inx}dx[/tex]
I don't get your answer of [itex](-1)^{n+1}/n^2[/itex]. Rather, I get an extra factor of 1/2.
Also, as noted, there are problems with n=0, which you must calculate separately.
Oh I guess that must be my mistake.
And yet it is not obvious to me how the Bernoulli numbers come up. Anyways, I'll work on it more again.
But I have a related question:
is there any sort of analogue of Parseval's identity for the inner product of two functions?
What I mean is, Parseval's identity relates the squared norm (the integral of f(x) squared on some domain) with the sum of the squares of the Fourier coefficients, similar to the way one finds the squared norm of a vector. Could there be a similar relationship between the integral of f(x)*g(x) on the domain with the sum of the products of the Fourier coefficients of f and g? (analogous to the dot product of two vectors).
I'm asking this because zeta(3) could be considered the "dot product" of two sequences, one with Fourier coefficients 1/n and one with 1/n^2 (or with (-1)^n somewhere) and so the same method could have been used.
Parseval's theorem proves that the Fourier transform (discrete or continuous) is unitary. So yes.
Proving that an operator preserves the norm of all vectors is equivalent to proving that the operator preserves all two vector inner products. Furthermore, knowing the quadratic form of any linear operator for all vectors gives you the sesquilinear form of the operator for all pairs of vectors, and thus, completely specifies the operator. Look up the "polarization identity".
But then could this be used to find the value for the sum of the reciprocals of the cubes?
Because you could consider it the inner product of x and x^2 (multiplied by a scalar factor)?
Since the Fourier coefficients of x involve 1/n and the Fourier coefficients of x^2 involve 1/n^2, then the inner product of x and x^2 should involve 1/n^3?
In the interest of full disclosure, I haven't been paying full attention to this thread. I just knew the answer to this last question off hand. I'm not going to swear on anything given any assumptions or workflows that have been presumed already, but I'll say this:
There is an 'inner-product Parseval's identity'. The correct form of it can be seen in the third equation of http://en.wikipedia.org/wiki/Parseval's_theorem. The special case of real functions is shown in the fifth equation.
If you have found functions whose inner-product of Fourier coefficients gives you the series you are looking for, by all means go ahead an do the integral to find the value of the sum. Just don't forget the negative coefficients and don't forget the zeroth coefficient. If your using equation 5 from the link I posted, then the negative coefficients are taken care of. Just remember that those equations are talking about complex exponential Fourier series, not sines and cosines series.
As a hint, if you try to apply the Parseval's identity to x and x^2, and do so correctly, you will find 0=0.
If a_n are the x coefficients and b_n are the x^2 squared coefficients:
a_0=0
a_n for n≠0 are imaginary
b_n are all real.
a_n*b_n is imaginary or zero (either way the real part is zero, and the real part of any sum of such coefficients is zero).
x^3 is an odd function, and any integral symmetric about the origin will be zero.
I suspect you forgot about the factor of i in the coefficients of x.
FAQ: Why Parseval's Identity Fails for Higher Exponents in Basel Problem
1. Why is Parseval's identity important in the Basel Problem?
Parseval's identity is important in the Basel Problem because it provides a way to evaluate infinite series, which is essential in solving the Basel Problem. It states that the sum of the squares of the coefficients in a Fourier series is equal to the integral of the square of the function. This allows us to convert the Basel Problem, which involves an infinite series, into an integral that can be solved using calculus.
2. What is Parseval's identity?
Parseval's identity is a mathematical theorem that relates the coefficients in a Fourier series to the integral of the square of the function. It states that the sum of the squares of the coefficients in a Fourier series is equal to the integral of the square of the function. This is a powerful tool in evaluating infinite series and has many applications in mathematics and science.
3. How does Parseval's identity fail in the Basel Problem for higher exponents?
Parseval's identity fails in the Basel Problem for higher exponents because the integral of the square of the function diverges for exponents greater than 2. This means that the integral does not have a finite value and cannot be used to evaluate the infinite series. This is why other methods, such as Euler's approach, must be used to solve the Basel Problem for higher exponents.
4. Can Parseval's identity be used to solve the Basel Problem for all exponents?
No, Parseval's identity cannot be used to solve the Basel Problem for all exponents. As mentioned before, the integral in Parseval's identity diverges for exponents greater than 2. This means that it cannot be used to evaluate the infinite series in the Basel Problem. Other methods, such as Euler's approach, must be used for higher exponents.
5. What are some other applications of Parseval's identity?
Parseval's identity has many applications in mathematics and science. It is commonly used in signal processing, where it is used to analyze signals and filter out noise. It is also used in solving differential equations and in quantum mechanics. Additionally, it has applications in image and sound compression, as well as in the study of vibrations and waves.
