Why potential of n side is higher in unbiased p-n junction
In summary: This potential is due to the diffusion of charge carriers across the junction. The potential is highest on the side with more positive charges.
Rishav sapahi
why the potential of n side is higher than that of the p side when no battery is connected to the p-n junction?
Well if there is no battery, the circuit is pretty much useless... The p-n junction is typically associated with a voltage drop across the p-n junction (somewhere around .5-3V for LEDs). However with no battery in the circuit, there will be no current flowing and thus no voltage across the junction, so they should be at the same potential.
but in my book they are stating that n-side is at higher potential without any explanation
Is the battery attached to the n-side? If so, then yes, the n-side would be at a higher potential and the p-side would be a 0V, since there in no (practically none) current flowing through the diode. This is known as the reverse-bias direction. The voltage at the n-side would be at the same voltage as the battery (assuming it is just connected with a wire).
Look up "PN junction depletion region". The natural potential that develops spontaneously across a PN junction is due to the diffusion of charge carriers across the junction. P type material has "holes" in its bond structure that can be "filled" by accepting electrons, while the N side has more than enough conduction electrons to satisfy its bond requirements.
However, every electron that crosses over leaves a small net positive charge in the N material, while the P side gains a small negative charge. These charges build up until they suppress further movement --- they raise a potential barrier against further diffusion of charges. This is what leads to the "turn on" bias requirement to get current moving across the junction (about 0.7V for silicon PN junctions).
so Is high potential just means that given side is more positively charged than other
Yes. A potential develops across the junction.
Related to Why potential of n side is higher in unbiased p-n junction
1. Why is the potential of the n side higher in an unbiased p-n junction?
The potential of the n side is higher in an unbiased p-n junction because of the difference in electron concentration between the n and p regions. The n region has a higher concentration of free electrons compared to the p region, resulting in a higher negative charge on the n side and a higher positive charge on the p side. This creates an electric field that causes the potential to be higher on the n side.
2. How does the potential difference affect the behavior of the p-n junction?
The potential difference in a p-n junction controls the flow of electrons and holes across the junction. When the junction is unbiased, there is a depletion region at the interface which prevents the majority carriers (electrons in n region and holes in p region) from crossing the junction. However, when a potential difference is applied, electrons and holes can move across the junction, resulting in a flow of current.
3. Can the potential of the n side ever be lower than the p side in an unbiased p-n junction?
No, the potential of the n side cannot be lower than the p side in an unbiased p-n junction. This is because the majority carriers in the n region (electrons) have a higher mobility compared to the majority carriers in the p region (holes). Therefore, when the junction is unbiased, the n region will always have a higher potential due to the higher concentration and mobility of electrons.
4. How does the potential of the n side change when a forward bias is applied to the p-n junction?
When a forward bias is applied to the p-n junction, the potential of the n side decreases compared to the p side. This is because the applied voltage reduces the potential barrier at the junction, allowing more majority carriers to cross the junction. As a result, the positive charge on the n side decreases, and the negative charge on the p side increases, causing a decrease in potential on the n side.
5. What happens to the potential of the n side when a reverse bias is applied to the p-n junction?
When a reverse bias is applied to the p-n junction, the potential of the n side increases compared to the p side. This is because the applied voltage increases the potential barrier at the junction, preventing majority carriers from crossing the junction. As a result, the positive charge on the n side increases, and the negative charge on the p side decreases, causing an increase in potential on the n side.
  • Atomic and Condensed Matter
  • Classical Physics
  • Electrical Engineering
