Why proton and electron collision doesn't result in annihilation?
In summary, the conversation discussed the concept of particle annihilation and how it occurs between particles and their exact antiparticles. It was explained that electrons and positrons annihilate due to their opposite charges, while electrons and protons do not because they are not exact antiparticles. The conservation of Baryon and Lepton numbers was also mentioned. The conversation also touched on the discovery of the positron by Dirac and the possibility of changing fermions into bosons through annihilation. It was clarified that while individual particles do not have temperatures, they do have energy, and the conservation of energy applies after annihilation. Additionally, the conversation briefly mentioned the relationship between temperature and the form of matter, with higher temperatures favoring bosonic
aditya23456
114
I am new to particle physics, but I heard that electron and positron annihilate each other in case of contact mainly because both have opposite charge( even same mass). Consider an electron is given enough kinetic energy such that it compensates mass differentiation between proton and electron, and undergoes perfect collision, then we should observe annihilation. In case they don't annihilate there's some other parameter which is main reason for annihilation other than opposite charge. Am I right?
The reason has already been stated by kjhskj... Annihilation occurs between particles-antiparticles. The electron's antiparticle is the positron and not the proton.
At first when Dirac found out the existence of "antiparticles" in his theory and tried to interpret this result. Quote from wiki http://en.wikipedia.org/wiki/Positron:
Dirac wrote a follow-up paper in December 1929[3] that attempted to explain the unavoidable negative-energy solution for the relativistic electron. He argued that "... an electron with negative energy moves in an external [electromagnetic] field as though it carries a positive charge." He further asserted that all of space could be regarded as a "sea" of negative energy states that were filled, so as to prevent electrons jumping between positive energy states (negative electric charge) and negative energy states (positive charge). The paper also explored the possibility of the proton being an island in this sea, and that it might actually be a negative-energy electron. Dirac acknowledged that the proton having a much greater mass than the electron was a problem, but expressed "hope" that a future theory would resolve the issue.
Robert Oppenheimer argued strongly against the proton being the negative-energy electron solution to Dirac's equation. He asserted that if it were, the hydrogen atom would rapidly self-destruct.[4] Persuaded by Oppenheimer's argument, Dirac published a paper in 1931 that predicted the existence of an as-yet unobserved particle that he called an "anti-electron" that would have the same mass as an electron and that would mutually annihilate upon contact with an electron.
Kinetic energy doesn't really play much of a role for the rest masses to be equal.
In general you can have INTERACTION between the proton and the electron... it can be electromagnetic interactions [between the e and the p, or maybe the proton's sea and valance quarks] or it can be weak interactions [electron capture- an alternative form of the beta+ decay]. But these are not annihilations.
[OUT OF SCIENCE COMMENT :smile: ]
I have also heard this thing about Dirac and the proton as electron's antiparticle as a joke...as for example Dirac's colleagues would knock on his door and ask him every now or then if he finally discovered his antiparticle, and one day Dirac replied "yes I did and it's the proton" or something like that...I don't actually remember it.
Really thanks for reply. So I can conclude that to form annihilation pairs, it's not just that 2 particles should possesses opposite charge.
Actually I am trying to understand how boson can be turn into fermion or viceversa. I found annihilation as a process to change fermions to boson. Can you please list similar reactions ( natural or experimental made) which involves change of fermion to bosons or viceversa.
Also, I want to know whether there are any experimental efforts done to try change spin of an elementary particle?
Also I have a weird question. Consider the fermion before annihilation has some temperature say 32 C, after annihilation does light beam( boson) have that temperature? I guess not, then where does this temperature go?
Note:- I am just naive and trying my best to learn QM on my own, my questions may be ridiculous, please just give me links where I can study about them. Really thanks for your time.
You can't "change" a fermion into a boson, but you can have two fermions resulting in a boson, or a boson giving two fermions, as in the decay of neutral pions
\pi^0 \rightarrow \gamma + e^- + e^+
Angular momentum (spin) has to be conserved.
This is like trying to change the charge of the electron. Spin is an intrinsic property.
Individual particles don't have temperatures, they have energy. Conservation of energy does apply, you get as much energy after annihilation as the total energy of the particles before annihilation.
Thanks for reply. But I read that at high temperatures, electromagnetism and weak forces to be same. Here temperature is temperature of particles( photons,W,Z boson's ) or ambient temperature? I feel temperature has an effect on particle(energy) nature, because at big bang when all forces were united , temperature of primodial soup was in billions and at this temperature, matter existed in bosonic form only. As universe temperature decreased, we found fermionic form. So was curious if there is any relation of temperature with change of fermionic to bosonic form. Also we know at absolute zero, matter( mass form) ceases to exist. Is there any study on this?
If you think of a collision as something like a chemical reaction with inputs and outputs, then the rules are:
  1. The total charge must be conserved (same before and after)
  2. The total angular momentum must be conserved.
  3. The total energy must be conserved.
  4. The total momentum must be conserved.
  5. In most interactions, the quantities B (baryon number) and L (lepton number) are conserved. B is "baryon number", which for ordinary matter counts the number of protons and neutrons.
    L is "lepton number", which for ordinary matter counts the number of electrons and neutrinos (there are other kinds of leptons, but they are not found in ordinary matter). Anti-particles have negative baryon numbers or lepton numbers.
The rules for combining angular momentum are a little complex: If you two particles with spin (intrinsic angular momentum) [itex]S_1[/itex] and [itex]S_2[/itex], then the total angular momentum (which includes both spin and orbital angular momentum) of the two of them can be any integer greater than [itex]|S_1 - S_2|[/itex]. So an electron and its anti-particle (the positron), which have spin-1/2 can be combined to produce angular momentum 0, 1, 2, etc. Two photons, each of which have spin-1, can be combined to produce angular momentum 0, 1, 2, etc. So an electron and a positron can collide to produce two photons. (They can't collide to produce just one photon, because you can't get the energy and momentum to work out, although angular momentum works out.)
Temperature is not a property of a single particle, but of a (large) collection of particles. It is related to the average energy of the particles and when the temperature is high particles tend to have large energy. The statement that forces unite at high temperatures is really just saying that when the universe was very hot, particles would generally have so high energies that the forces unite.
Could you provide references to those statements please? What do you mean by fermionic and bosonic form? Fermions and bosons are different types of particles and there is nothing preventing either from existing in the early universe.
The angular momentum combining rules indeed behave oddly.
When electron and positron annihilate to produce two photons, this is only possible if these photons have exactly opposite spin AND no orbital angular momentum whatsoever. This requires the combined spin to have been 0, so that the spins of electron and positron had been opposite.
If spins of electron and positron are parallel, total spin 1, then they have no way whatsoever to annihilate into two photons. They cannot annihilate into two photons spin 1 into different direction totalling 1, nor can they annihilate into two photons with combined intrinsic spin 0, but orbital angular momentum 1 relative to each other (emitted off-center). No, orthopositronium lives 1000 times longer than parapositronium and eventually decays into 3 photons, most of the time. There is an alternative, that happens to one in a million orthopositroniums - and that is decay into 5 photons! Meaning that for over 1 000 000 000 times the lifetime of parapositronium, orthopositronium has no way to decay into 2 or 4 photons by any mechanism.
Proton and antiproton annihilate into pions. But pions have no spin whatsoever! Then how can orthoprotonium annihilate and dispose of its spin, seeing that annihilation into particles with orbital angular momentum is utterly impossible for positronium? Yet orthoprotonium appears to annihilate without any obvious trouble...
With 1876 MeV from the proton & antiproton there is enough energy to create a rho meson (774 MeV & J=1) in addition to pions.
But then rho (J=1) decays to pi + pi (J=0) ?
Angular momentum from the relative motion of the particles can solve that.
Related to Why proton and electron collision doesn't result in annihilation?
1. Why don't protons and electrons annihilate each other?
The reason why protons and electrons do not annihilate each other is because they have opposite charges. Protons have a positive charge, while electrons have a negative charge. When these particles collide, their opposite charges cause them to be attracted to each other. This attraction results in a change in their direction and energy, but not in their annihilation.
2. What is the role of mass in the annihilation process?
The mass of a particle plays a crucial role in the annihilation process. In order for annihilation to occur, the colliding particles must have the same mass. In the case of protons and electrons, their masses are significantly different, which means they cannot undergo annihilation.
3. Can protons and electrons ever annihilate each other?
While protons and electrons do not typically undergo annihilation, there are some scenarios where it can happen. If a proton and electron collide with enough energy, they can create a positron and a neutrino. This process is known as pair production and is the reverse of annihilation. However, this only occurs in high-energy environments, such as particle accelerators.
4. How does the conservation of energy and momentum prevent proton-electron annihilation?
The law of conservation of energy and momentum states that these quantities must be conserved in any physical process. In the case of proton-electron collision, the energy and momentum of the particles are not equal and opposite, which prevents annihilation from occurring. The resulting change in energy and momentum is instead transferred to the particles, causing them to change direction.
5. Are there any other factors that prevent proton-electron annihilation?
In addition to charge and mass differences, there are other factors that can prevent proton-electron annihilation. For example, the quantum mechanical properties of particles, such as spin and angular momentum, also play a role in determining whether or not annihilation can occur. Additionally, the presence of other particles or fields can also influence the outcome of a collision between protons and electrons.
