Why should a heat pump receive low return temperature?
In summary, a low return temperature for a heat pump indicates that the system is effectively using the heat provided by the pump. However, if the return temperature is too low, it can affect the efficiency of the system. The goal is to find a balance between efficiency and heat transfer rate. Heat pumps work by transferring heat from a cold reservoir to a hot one, and this process is achieved by manipulating the state of the refrigerant. While the name "evaporative refrigeration" may suggest that this is how a heat pump works, it is actually not the case.
TSN79
424
One is always told that a heat pump (heating water) should receive return water with a temperature as low as possible. I've never really understood why. My initial thought is that if the return is higher, then it's "easier" for the heat pump to heat the water up to whatever supply temperature you want. Or is it because a low return indicates that your system makes good use of the heat the heat pump provided in the first place?
Is there such a thing as too low return? Or does that just mean that your system's heat emitters are too small?
A heat pump works by transferring heat from the cold reservoir to the hot reservoir. In order for heat flow to occur from the cold reservoir to the system, the part of the system that is in thermal contact with the cold reservoir must be colder than the cold reservoir. The colder that part of the system is, the greater the rate of heat flow to the system and then delivered to the hot reservoir (eg. the room to be heated). But the colder it is, the worse the co-efficient of performance becomes. So with heat pumps one tries to reach a balance between efficiency and rate of heat transfer.
AM
A person can keep this sort of thing straight in their head if they think about it in the manner in which it is named after. Absorption refrigeration. Keep in mind that heat only travels from hot to cold so in order to make it go the other way we manipulate the state of the refrigerant to make part of the loop colder than the reservoir we wish to cool and allow heat to absorb into the refrigerant which is then carried away and made hotter than the reservoir we wish to dump the heat into. For a long time I thought that evaporative refrigeration was what a plain old refrigerator or heat pump was assuming it was called that since we evaporate the refrigerant in part of the cycle but of course I was wrong and this is not the case. :smile:
Related to Why should a heat pump receive low return temperature?
1. Why is a low return temperature important for a heat pump?
A low return temperature is important for a heat pump because it allows for efficient operation and helps to prolong the lifespan of the equipment. When the return temperature is too high, the heat pump has to work harder to extract heat from the source, leading to increased energy consumption and potential wear and tear on the system.
2. How does a low return temperature affect the efficiency of a heat pump?
A low return temperature allows a heat pump to operate at its optimal efficiency. This is because the lower the return temperature, the greater the temperature difference between the source and the sink, which leads to a higher coefficient of performance (COP) for the heat pump. In simple terms, the lower the return temperature, the more heat energy can be produced for a given amount of electricity used.
3. What factors can contribute to a high return temperature in a heat pump?
There are several factors that can contribute to a high return temperature in a heat pump, including a poorly insulated building, incorrect sizing of the heat pump, and insufficient flow rate of the heat transfer fluid. Additionally, external factors such as extreme weather conditions or lack of maintenance can also result in a high return temperature.
4. Can a heat pump still work efficiently with a high return temperature?
No, a heat pump cannot work efficiently with a high return temperature. As mentioned earlier, a high return temperature leads to a lower COP, which means that the heat pump will use more energy to produce the same amount of heat. This not only increases energy costs but also puts additional strain on the equipment, potentially shortening its lifespan.
5. How can the return temperature be kept low in a heat pump?
The return temperature in a heat pump can be kept low by properly insulating the building, sizing the heat pump correctly, and ensuring a sufficient flow rate of the heat transfer fluid. Regular maintenance and cleaning of the heat pump can also help to prevent any external factors from causing a high return temperature. Additionally, investing in a heat pump with advanced controls and sensors can help to optimize the return temperature and improve overall efficiency.
  • General Engineering
11K
  • Mechanical Engineering
