Why should I use a substitution here?
In summary: The "reverse chain rule" is the u-substitution method. Suppose, for example, you differentiatey = (2 + x3)4 to gety' = 4(2 + x3)3(3x2) = 12x2(2 + x3)3Now suppose you are asked to integrate f(x) =(2 + x3)4. Notice that this didn't come from the above example because it is missing the "derivative of the inside" 3x2. As a consequence, trying the u-substitution u =2 + x3 won't help integrate f(x).That's why u-substitutions are not appropriate for some integrals. But suppose you have
thomas49th
655
[tex] Area = \frac{2}{\sqrt{3}}\int\sqrt{1-\frac{x^{2}}{4e^{2}}}dx[/tex]
Apparently I should use a substitution x/2e = sin(u) and I can see why it's those value but I don't understand why they need the substitution in the first place. Isn't the integral simply:
[tex] \frac{2}{\sqrt{3}}\cdot \frac{2}{3}\cdot \frac{-4e^{2}}{2x} (1-\frac{x^{2}}{4e^{2}})^{\frac{3}{2}}[/tex]
Having tried the other method, the answers are different and I cannot see why.
Thanks
Thomas
No, it isn't. It looks to me like you are trying to apply the chain rule "in reverse"- dividing by the derivative of a function of x rather than multiplying. You can't do that. If you had, say, [itex](f(x))^2[/itex] and wanted to differentiate it, it would be 2(f(x))f'(x). But to integrate [itex](f(x))^2[/itex], you can't just divide by f'(x). You could try dividing and multiplying by that:
[tex]\int (f(x))^2 \frac{f'(x)}{f'(x)}dx}[/tex]
but then since f'(x) is a function of x, you cannot take it outside the integral.
That is NOT the same as
[tex]\frac{1}{f'(x)}\int (f(x))^2f'(x)dx= \frac{1}{3f'(x)}(f(x))^3[/tex]
Did you look at the derivative of what you give?
The derivative of
[tex]\frac{-8e^2}{3x\sqrt{3}}\left(1- \frac{x^2}{4e^2}\right)^{3/2}[/tex]
is
[tex]\frac{4e^2}{3x^2\sqrt{3}}\left(1- \frac{x^2}{4e^2}\right)^{3/2}- \frac{8e^2}{3x\sqrt{3}}\left(1- \frac{x^2}{4e^2}\right)^{1/2}\left(-\frac{x}{2e^2}\right)[/tex]
not at all what you were trying to integrate.
The point of the substitution you mention,
[tex]sin(u)= \frac{x}{2e}[/tex]
is that
[tex]\left(1- \frac{x^2}{4e^2}\right)^{1/2}[/tex]
becomes
[tex]\left(1- sin^2(u)\right)^{1/2}= (cos^2(u))^{1/2}= cos(x)[/tex]
and, of course,
[tex]cos(u)du= \frac{1}{2e}dx[/tex]
so that
[tex]2e cos(u)du= dx[/tex]
and the integral
[tex]\frac{2}{\sqrt{3}}\int \sqrt{1- \frac{x^2}{4e^2}}dx[/tex]
becomes
[tex]\frac{2}{\sqrt{3}}\int (cos(u))(2e cos(u)du)= \frac{4e}{\sqrt{3}}\int cos^2(u)du[/tex]
which can be integrated using the identity [itex]cos^2(u)= (1/2)(1+ cos(2u))[/itex].
That way
The derivative of
is
is that
becomes
and, of course,
so that
and the integral
becomes
That way
I was doing the chain rule in reverse. Is that method never never valid. I spent a year out doing little integration, have I just made the method up all together or is it allowed (just not in this circumstance). I'm sure that's how I was taught. Hmm
You are using an ordinary substitution, u = 1 - x2/(4e2), so du = -2x/(4e2) dx.
In your original integral you have the dx, but not the remaining part needed to make du, so you are tacking on a factor of -2x/(4e2) and accounting for it by multiplying by the reciprocal, -4e2/(2x). You can't do that.
You can bring in factors that are constants, but you can't bring in factors that involve your variable x.
The quickest way to see that your substitution is incorrect is to differentiate the answer you got.
Here's an example that shows why your technique doesn't work.
[tex]\int cos(x^2) dx[/tex]
Let u = x2, so du = 2x dx.
The integrand is missing a factor of 2x, so let's just stick it in. To account for this, we'll also bring in a factor of 1/(2x), which we'll move outside the integral (this is what HallsOfIvy was saying was invalid).
[tex]\frac{1}{2x}\int cos(x^2) 2x ~dx = \frac{1}{2x} \int cos(u) du = \frac{1}{2x} sin(u) + C = \frac{1}{2x} sin(x^2) + C[/tex]
By differentiating the answer above, you should see that you don't get cos(x2).
thomas49th said:
I was doing the chain rule in reverse. Is that method never never valid?
That's why u-substitutions are not appropriate for some integrals. But suppose you have a problem that did come from the chain rule like:
[tex]\int x^2(2+x^3)^4\, dx[/tex]
Here the "derivative of the inside" is there, to within a constant. That's the x2 term. Now if you try the u-substitution u =2 + x3 it will work with you only having to adjust for the missing constant. That reverses the chain rule. The u-substitution method is the "reverse chain rule".
Thanks, I see what you mean
FAQ: Why should I use a substitution here?
Why is substitution helpful in scientific experiments?
Substitution allows for controlled changes in a variable, making it easier to observe the effects of one specific change on the overall outcome of the experiment. This helps to ensure accurate and reliable results.
How does substitution differ from other methods of data analysis?
Substitution involves replacing one variable with another, while other methods of data analysis may involve comparing variables or identifying patterns in data. Substitution is particularly useful for isolating the effects of one specific variable.
Can substitution be used in all scientific experiments?
While substitution can be a useful tool in many experiments, it may not be applicable or appropriate for all experiments. It is important to carefully consider the goals and methods of the experiment before deciding whether to use substitution.
How can I determine the best substitution to use in my experiment?
The best substitution will depend on the specific variables and goals of your experiment. It is important to carefully consider the potential effects of each substitution and choose one that will allow for the most accurate and relevant results.
Are there any limitations to using substitution in scientific experiments?
Like any method of data analysis, substitution has its limitations. It is important to carefully consider the potential impact of the substitution on the overall experiment and results. Additionally, it is important to properly control for any potential confounding variables when using substitution.
