Why single phase induction motors are used for fractional HP applications
In summary, a single phase induction motor is commonly used for low HP rather than integral HP like 1,2,3HP because single phase gives low power. However, say you have designed such that your motor delivers 10HP for rated voltage and current...why such single phase machines are not common? Can anyone please explain and prove technically?
srinaath
52
why single phase induction motor is commonly used for low HP rather than integral HP like 1,2,3HP... i understand that single phase gives low power...but say you have designed such that your motor delivers 10HP for rated voltage and current...why such single phase machines are not common?can anyone please explain and prove technically??
10 HP ≈ 7360 W
Rated voltage = 115 V → Effective Current = 64 A
cos φ = 0.75 (assumed) → current = 85 A
Motor efficiency = 0.85 (assumed) → current = 100A
Starting current could be 4 times the nominal current (assumed) → Starting current = 400 A
Do you have fuses where you are staying = 400 A ?
The manufacturer of such a motor must have customers, thus 3 phases as for a 10 HP motor.
Likes CalcNerd
Hesch said:
10 HP ≈ 7360 W
sorry am not getting you..what i understood is that, you are saying that there is no 400A fuse for single phase? and how to relate this with three phase machine...please correct me if am wrong
Of course there is a 400A fuse, also for a single phase. You can get a 1600A fuse, if you want.
But it's not quite "normal" to install a 400A fuse for a single phase. You will have to change the cables in your house before it is legal.
Using 3 phases you will only need 1/3 of the current per phase, and you can use a Y/Δ-starter to decrease the starting current.
got it bro, thanks...but one more doubt...why efficiency of single phase machine is less than three phase machine? moreover efficiency is directly proportional to power,why is that so? (PS please forgive for asking too much doubts)
Because typically a 3-phase machine har more HP's than a 1-phase.
Now say that we have 2 machines: A) 1 HP , B) 10 HP.
The expenses building B will not be 10 times the expenses building A, but say 5 times. So the expenses as per HP will be less with B. Thus you have some money to invest in efficiency, thereby balancing the expenses for kW's and building expenses as for the lifetime of the motor:
It's a matter of economy (where to spend your money ).
Same reason: Minimizing total expenses as for the lifetime of the motor.
I don't think that the efficiency is "directly proportional" to power.
A lot of the reason is cost and circuit breaker size/panel space.
There may also be a minimum wire size and fuze sizes, so you probably have issues properly protecting a 0.3A motor. (Not certain)
Also consider that consumer equipment tends to use small motors. You get enormous economy of scale for this size of motors if you use single phase since you can use the motor in a larger variety of devices.
BoB
BoB
thanks rbelli1 for the input. i have a query what will be the size of three phase motor if power rating is 1HP in comparison with single phase motor? (2) i observed that efficiency of three phase motor is directly proportional to synchronous speed of the motor..how is that so?...(for example for 3600rpm-80% eff but 1200rpm-75% eff)
I did some research and it appears cost at 1hp is similar. The 3 phase motor was 80% the weight of the single phase one.
I was considering much less than 1hp in my previous comment. Think blenders and fans.
I don't know about the efficiency except that the two motors have similar efficiencies.
BoBhttp://www.walkerindustrial.com/120000-00-Leeson-General-Purpose-p/120000-00.htm
http://www.walkerindustrial.com/192125-00-Leeson-IEC-Metric-p/192125-00.htm
Related to Why single phase induction motors are used for fractional HP applications
1. Why are single phase induction motors used for fractional HP applications?
Single phase induction motors are used for fractional HP applications because they are cost-effective, reliable, and require minimal maintenance. They are also compact in size, making them suitable for smaller applications that require less power.
2. How do single phase induction motors work?
Single phase induction motors work by using a single alternating current (AC) supply to create a rotating magnetic field. This field interacts with the rotor, causing it to rotate and power the motor.
3. What are the advantages of using single phase induction motors for fractional HP applications?
Some advantages of using single phase induction motors for fractional HP applications include their simplicity, low cost, and easy maintenance. They also have a high starting torque and can operate at variable speeds.
4. Can single phase induction motors be used for larger applications?
Yes, single phase induction motors can be used for larger applications, but they are typically limited to applications that require less than 10 horsepower. For larger applications, three phase induction motors are typically used.
5. Are single phase induction motors efficient?
Single phase induction motors have a relatively low efficiency compared to three phase induction motors. However, they are still widely used in fractional HP applications due to their other advantages, such as cost-effectiveness and easy maintenance.
  • Electrical Engineering
