Why speed of the railroad hopper is the same? []
  • Thread starter amiras
  • Tags
    Speed
In summary: ZW50IGZyb20gY3Jhd2xlZCB0aGUgbWFzc2l2ZSBvZiB0aGUgc2FtZSBhZ2FpbiBvbiB0aGUgZ3JvdW5kLgoKSW4gc3VtbWFyeSwgIHRoZXJlIGlzIGlzbiB1bnJpY2FsbHkgZmVsbG93ZWQgYW5kIHNvbWVvbiBsb3N0IGZvcmNlc2hlZCBvbiB0aGUgcmFpbCBjYXIgaXMgYmF
amiras
65
There is this problem and I do not understand how could this be:
A railroad hopper car filled with sand is rolling with an initial speed of 15.0 m/s on straight,
horizontal tracks. You can ignore frictional forces on the railroad car. The total mass of the car
plus sand is 85,000 kg. The hopper door on the underside of the car is not fully closed, so sand
leaks out the bottom of the car and falls to the ground. After 20 minutes, 13,000 kg of sand has leaked out. What is the speed of the railroad car now?
The answer is 15 m/s. How could change in mass could not affect speed?
initial momentum of the system where sand is about to start leaking:
p_i = mv
and final momentum:
p_f = (m - 13000)v'
and solving gives v' = 17.7 m/s, but book gives answer of 15 m/s, what am I missing here?
Since most of the sand is on the ground now and do not have speed?
Yes, the car lost momentum. Perhaps you could explain why do believe the speed would change.
What about this force F=dp/dt = v*dm/dt + mdv/dt
dm/dt is not 0 here, since the mass is changing, that would mean that a force acts on the railroad hopper?
And the and which fall from the railroad hopper reached the ground sooner or later and it has no momentum, so how car could loose momentum?
I think the problem assumes that there is zero force acting on the car. Rather, there is only an initial velocity: like if you pushed a toy car and let go.
The answer definitely is NOT 15 m/s (assuming no external forces are acting on it). Perhaps it's a typo, but you are correct that the velocity will increase.
Okay, so what is final and initial momentum of the whole system?
Could you explain why exactly the velocity would increase?
I believe the equations you posted in your original post are correct.
That is the case, If I'm posted them correctly then the answer is 17.7 m/s and that means that the speed has increased, but the book gives answer 15 which means that speed does not change.
Assume the sand falls onto a frictionless surface and continues to move at the same speed as the railroad hopper. Depending on where the sand exits the railroad hopper, there will be some displacement of the railroad hopper and sand, but once the sand stops pouring out the railroad car, both should have the same speed as they did at the beginning.
The sand didn't transfer it's horizontal momentum to the car, but to the ground
The "whole system" would include the entire Earth if you want to consider conservation of momentum in this case. Or you simply assume that what happens between sand and ground has no significant effect on the car.
If the sand exits at the back, with a horizontal velocity component relative to the car, the car will accelerate of course.
This assumption that the sand does not stop after falling makes it right, thanks everyone.
p_i = mv
and final momentum:
p_f = (m - 13000)v'
You have the answer now, but the key is WHEN did the sand lose its forward momentum - and the answer is "when it hit the ground", not "as it left the rail car"
The equation F = dp/dt is *false* in non-relativistic mechanics with time-varying mass, but this is perhaps less well understood than it should be. Even as late as the 1990s, clarifications were being published and older errors uncovered. Google "variable mass dynamics", and download (free) the expository paper by Plastino and Muzzio.
RGV
Related to Why speed of the railroad hopper is the same? []
1. Why is the speed of the railroad hopper always the same?
The speed of the railroad hopper is determined by a variety of factors such as the weight of the train, the track conditions, and the power of the locomotive. These factors are carefully balanced to maintain a consistent speed for safety and efficiency purposes.
2. Is there a maximum speed for railroad hoppers?
Yes, there is a maximum speed for railroad hoppers. The maximum speed is determined by the design and capacity of the hopper car, as well as the weight of the train and the track conditions. Going above the maximum speed can cause safety hazards and damage to the train and tracks.
3. Can the speed of the railroad hopper be adjusted?
Yes, the speed of the railroad hopper can be adjusted. Train operators have the ability to control the speed of the train through the use of throttle and brake controls. However, there are limits to how much the speed can be adjusted to maintain safety and efficiency.
4. Why is maintaining a consistent speed important for railroad hoppers?
Maintaining a consistent speed is important for railroad hoppers for safety and efficiency reasons. Going too fast can cause accidents and damage to the train and tracks, while going too slow can cause delays and inefficiency in transportation.
5. Are there any exceptions to the consistent speed of railroad hoppers?
In certain situations, there may be exceptions to the consistent speed of railroad hoppers. For example, in case of emergencies or unexpected obstacles on the tracks, train operators may need to adjust the speed to ensure safety. However, these exceptions are carefully monitored and controlled to minimize any potential risks.
