Why Substitute Force Magnitude in Spring Work Calculation?
In summary, substituting force magnitude in spring work calculation is essential because it simplifies the computation of work done by or against the spring. Instead of integrating variable force over distance, using the spring constant allows for a straightforward application of Hooke's Law. This substitution leads to an accurate evaluation of work as it directly relates to the displacement and the characteristics of the spring, ensuring that results are both efficient and precise.
dainceptionman_02
TL;DR Summary
i read through work done by a spring force derivation and have a simple question about the substitution.
i'm copying from the book...
Hookes Law - F = -kx
W = Fdcos∅
since ∅ is 180°, W = -Fd = -Fx
W = ∫(-Fxdx)
now the book says, from Hookes Law equation "the force magnitude F is kx. Thus, substitution leads to W = ∫(-kxdx)"
why are they saying to substitute the magnitude of the force and not the restoring force of (-kx) resulting in a positive formula in the integral with the two negatives?
The actual formula for work done is [tex]
W = \int \mathbf{F} \cdot d\mathbf{x}.[/tex] In one dimension this is [tex]
W = \int F\,dx[/tex] where [itex]F[/itex] is the signed force, [itex]-kx[/itex], yielding [tex]
W = -\int kx\,dx.[/tex]
Likes berkeman
this formula is missing the cosine of the angle in one dimension
No it's not - that's what the signed force is. In 1d it's either parallel to dx (+ve sign) or anti-parallel (-ve sign). There are no other options.
but Halliday still wrote it in the way that i showed in the original post...
One must know what work you are talking about. The work done by the spring will be the negative of the work done on the spring. If one understands the Physics, the sign is clear. This is why understanding the physics is always better than memorizing the equation.
Likes nasu and jbriggs444
Then he isn't working in 1d. That's fine; as is working in 1d with a signed force and no cosine.
The problem here is keeping straight which force you are talking about, which way it's pointing, and which body you're doing work on. The spring exerts a force ##F## in the ##-x## direction on the mass, so the spring does work ##-Fx## on the mass (that's the mass' kinetic energy decreasing). The mass exerts a force ##F## in the ##+x## direction in the spring so the mass does work ##Fx## on the spring (that's the spring's potential energy increasing).
A vector in 1D is just a signed number!!
I think I can say something usefull here, the problem in the book is probably with the overload of the symbol F: It is used to mean both the vector force and the magnitude of the force. When the book says ##W=Fdx\cos\theta## this F is the magnitude of the force.
As it is well know the work (infinitesimal) is the dot product ##dW=\vec{F}\cdot d\vec{x}=|\vec{F}||d\vec{x}|\cos\theta##.
I mean when you see that ##\cos\theta## in the expression for the work you know that the dot product is expanded so the other symbols must be the magnitude of the vectors.
Likes dainceptionman_02, nasu, Lnewqban and 1 other person
FAQ: Why Substitute Force Magnitude in Spring Work Calculation?
Why do we need to substitute force magnitude in spring work calculations?
We substitute force magnitude in spring work calculations to accurately determine the work done by or on the spring. The force exerted by a spring is variable and depends on the displacement from its equilibrium position. Using Hooke's Law, which states that force is proportional to displacement (F = kx), allows us to integrate this variable force over the displacement range to calculate the total work done.
How does Hooke's Law relate to spring work calculations?
Hooke's Law is fundamental to spring work calculations because it provides the relationship between the force exerted by the spring and its displacement (F = kx). By substituting this linear relationship into the work integral, we can derive the formula for the work done by the spring, which is (1/2)kx^2. This substitution is crucial for accurately calculating the work involved in compressing or stretching the spring.
What is the integral form of work done by a spring, and why is substitution necessary?
The integral form of the work done by a spring is W = ∫ F dx, where F is the force exerted by the spring and dx is the infinitesimal displacement. Since the force F varies with displacement x, we substitute F with kx (from Hooke's Law) in the integral, resulting in W = ∫ kx dx. This substitution is necessary to integrate the variable force over the displacement range, leading to the final result W = (1/2)kx^2.
Why can't we use a constant force value for spring work calculations?
We can't use a constant force value for spring work calculations because the force exerted by a spring is not constant; it changes linearly with displacement according to Hooke's Law (F = kx). Using a constant force would only be accurate for situations where the force does not change, which is not the case for springs. The variable nature of the spring's force requires us to account for this change by substituting the force magnitude appropriately.
How does substituting force magnitude affect the accuracy of spring work calculations?
Substituting the force magnitude using Hooke's Law (F = kx) significantly improves the accuracy of spring work calculations. This substitution ensures that the variable nature of the spring's force is correctly accounted for in the integral, leading to an accurate calculation of the work done. Without this substitution, the calculations would be incorrect, as they would not reflect the true relationship between force and displacement in the spring.
