En_lizard
- 76
why sun looks bigger in the evening? although it's closer to the Earth during noon?
I believe that only happens because you (any person) are on the ground looking up from being too stoned to stand...mathman said:One thing I've noticed is that if you lie on the ground looking straight up at the sky, things overhead (clouds particularly) look closer than when you are standing up.
Didn't you ever picnic in the park with your girl friend?I believe that only happens because you (any person) are on the ground looking up from being too stoned to stand...
Yes, many times but I don't recall ever looking UP.mathman said:Didn't you ever picnic in the park with your girl friend?
This is true. If you will Google on fovea, you will see how the non-uniformity in the eye and the non-uniformity in the visual cortex work together to give us a magnified and sharpened image in the center of our field of view. This effect is especially pronounced in birds of prey, who often have to locate their food from very high up.mathman said:One thing I've noticed is that if you lie on the ground looking straight up at the sky, things overhead (clouds particularly) look closer than when you are standing up.
Labguy said:Yes, many times but I don't recall ever looking UP.
Not enough for you to notice, and the effect is in the wrong direction, anyway. When you are looking straight up, you are looking through the least amount of atmosphere possible. The apparent largeness and sharpness of things in the center of our field of view is due to the physiology of the eye and to the manner in which the eye is wired to the visual cortex.Chronos said:In a word, refraction. The Earth's atmosphere magnifies the image.
En_lizard said:why sun looks bigger in the evening? although it's closer to the Earth during noon?
The sun appears larger in the evening due to an optical illusion called the "moon illusion." This happens when the sun is low on the horizon and our brain compares its size to objects in the foreground, making it seem bigger.
No, the size of the sun remains the same throughout the day. It is only our perception that changes due to the angle and position of the sun in relation to our surroundings.
Similar to the sun, the moon appears larger in the evening due to the moon illusion. However, the moon's distance from Earth also plays a role in its perceived size, as it is slightly closer to us during its rise in the evening.
No, the moon illusion may vary for different people depending on their visual perception and the surrounding landscape. It can also vary for the same person on different days, depending on the atmospheric conditions.
Scientists have not yet reached a consensus on the exact cause of the moon illusion. Some theories suggest it is due to the refraction of light in the atmosphere, while others propose that it is a result of our brain's visual processing. Further research is needed to fully understand this phenomenon.
