Why superspace formulation works only for at most 4 supersymmetries?
  • Thread starter Osiris
  • Tags
    Works
In summary, the number of allowed supersymmetries in superspace formulation is determined by the maximum dimension of the underlying space. In the case of four-dimensional space, the maximum number is four, as this allows for a balance between bosonic and fermionic degrees of freedom. Superspace formulation works for 4 supersymmetries by using four fermionic coordinates to transform the four bosonic coordinates, resulting in a unified framework for both types of particles. While superspace formulation can be extended to higher dimensions with more than four supersymmetries, it has limitations in fully describing some supersymmetric theories, requiring the use of alternative formulations such as extended superspace. Additionally, superspace formulation is closely related to other approaches to supersym
Osiris
For more than 4 supersymmetries, why some of the supersymmetries would not be manifested?
What's the consideration here?
&_&
Hmm actually, does superspace formulation work for more than one supersymmetry? Most examples only put a generator in.
i read this statement in the Vol I of "Quantum Field Theory and Strings: A Course for Mathematicians" by Pierre Deligne et al. (eds.).
But there's no further explanation there.
Related to Why superspace formulation works only for at most 4 supersymmetries?
1. Why are only 4 supersymmetries allowed in superspace formulation?
The number of allowed supersymmetries in superspace formulation is determined by the maximum dimension of the underlying space. In the case of four-dimensional space, the maximum number of supersymmetries is four. This is because supersymmetry requires a balance between bosonic and fermionic degrees of freedom, and in four dimensions, there are only four bosonic dimensions to match with four fermionic dimensions.
2. How does superspace formulation work for 4 supersymmetries?
In superspace formulation, the four supersymmetries are represented by four fermionic coordinates, also known as Grassmann coordinates. These coordinates are used to transform the four bosonic coordinates, giving rise to the supersymmetric transformations. The resulting superspace has both bosonic and fermionic dimensions, allowing for the inclusion of both types of particles in a unified framework.
3. Can superspace formulation be extended to more than 4 supersymmetries?
The maximum number of supersymmetries allowed in superspace formulation is determined by the dimension of the underlying space. In four-dimensional space, the maximum number is four. However, in higher dimensions, such as ten or eleven dimensions, more than four supersymmetries can be accommodated. This is why superspace formulation is often used in theories such as supergravity and string theory, which require higher-dimensional spaces.
4. What are the limitations of superspace formulation with only 4 supersymmetries?
The main limitation of superspace formulation with only 4 supersymmetries is that it cannot fully describe all possible supersymmetric theories. Some theories, such as certain types of supergravity, require more than four supersymmetries to be fully described. In these cases, alternative formulations, such as extended superspace, may be used.
5. How does superspace formulation relate to other formulations of supersymmetry?
Superspace formulation is one of several approaches to incorporating supersymmetry into theoretical physics. It is closely related to other formulations, such as the component formalism, which uses explicit calculations and equations to describe supersymmetric theories. Superspace formulation, on the other hand, provides a geometric and elegant way to describe supersymmetry, making it a popular choice among physicists.
  • Beyond the Standard Models
11K
