Why Tetrasubstituted Alkenes More Stable Than Tri/Bi/Mono
  • Thread starter Queequeg
  • Tags
    Stable
In summary, the stability of a tertiary carbocation outweighs the significance of steric strain, leading to a more stable tertiary carbocation. The increased steric strain in cis-isomers compared to trans isomers explains why cis-isomers are less stable. In terms of alkene stability, a more substituted alkene will have a smaller enthalpy change upon hydrogenation due to increased hyperconjugation interactions. This trend is experimentally determined and used to explain the stability of alkene substitution.
Queequeg
25
I understand it when you have a mechanism and the tertiary carbocation is more stable than a secondary and primary carbocation, but is that the reason? Cis-isomers are less stable than trans isomers because of steric strain on that side of the double bond, but a tetrasubstituted alkene will have twice the steric strain and more so with bulkier substituents.
If I had to guess, it's because the stability of the tertiary carbocation outweighs the significance of the steric strain.
Chemistry news on Phys.org
You are correct about about the cis- and trans-alkene case being readily explained by the increased steric strain for the cis-alkene case. When it comes to alkene stability in regard to substitution, the theory is meant to explain the trend that a more substituted alkene will have a smaller enthalpy change upon hydrogenation. Since the enthalpy change is inversely proportional to "stability" of the alkene, we can simply take the stability trend as an experimentally determined trend. The theory which explains the trend, from memory, is that highly substituted alkenes have a greater extent of hyperconjugation interactions.
Related to Why Tetrasubstituted Alkenes More Stable Than Tri/Bi/Mono
1. Why are tetrasubstituted alkenes more stable than tri/bi/mono substituted alkenes?
The stability of an alkene depends on the number and position of substituent groups. Tetrasubstituted alkenes have four substituent groups, which results in a greater degree of hyperconjugation and steric hindrance, making them more stable than tri/bi/mono substituted alkenes.
2. How does hyperconjugation contribute to the stability of tetrasubstituted alkenes?
Hyperconjugation is the interaction between an alkene's π-bond and adjacent σ-bonds. In tetrasubstituted alkenes, the presence of four substituent groups allows for more hyperconjugative interactions, leading to increased stability.
3. What role does steric hindrance play in the stability of tetrasubstituted alkenes?
Steric hindrance refers to the repulsive interactions between bulky substituent groups. In tetrasubstituted alkenes, the four substituent groups create a crowded environment, which helps to stabilize the molecule by preventing unwanted reactions.
4. Are there any exceptions to the rule that tetrasubstituted alkenes are more stable?
Yes, there are some exceptions. For example, if the substituent groups are very bulky or have a high degree of unsaturation, they can destabilize the alkene by creating too much steric strain.
5. How can the stability of tetrasubstituted alkenes be experimentally determined?
The stability of tetrasubstituted alkenes can be determined using techniques such as nuclear magnetic resonance (NMR) spectroscopy, which can provide information on the relative energy levels of different alkene isomers. Additionally, computational methods can also be used to calculate the stability of different alkene structures.
9K
14K
