Why the atmosphere spins with the Earth
In summary, the Earth's mantle and atmosphere spin at different speeds, with the atmosphere rotating in sync with the Earth due to friction. The Earth's rotation rate has decreased over time, and the atmosphere has kept pace with this change. Friction and interactions with the Earth's magnetic field also contribute to the rotation of the atmosphere. The jet streams are not a direct proof of the atmosphere's rotation, as they are counterbalanced by other factors. The ionosphere also rotates at a faster rate than the Earth, but this is a separate phenomenon from the jet streams.
Grap
The mantle of the Earth spins at about 1000mph at the equator and at 0mph at the poles. The atmosphere spins in unison and I've never fully understood why.
I would be very grateful for a scientific explanation.
Friction.
Suppose the atmosphere wasn't rotating. Think of what a 1000 mph would do. It would rip the surface to shreds. That however would slow the wind down, at least at the surface. The slower winds at the surface would in turn interact with the faster moving air aloft. Over a relatively short period of time the atmosphere wind would eventually settle into a state where it is more or less rotating with the Earth.
In fact, the Earth hasn't always been rotating at one revolution per 23.9344696 hours (the current length of a sidereal day). The rotation rate has been decreasing over time. 380 million years ago a day was only 22 hours long. The atmosphere has kept pace with this decrease because the atmosphere interacts with the rotating Earth.
Also, the Earth is not smooth, so you get turbulence and density waves which transfer energy between surface and atmosphere.
One example is the way wind over water drives waves: The longer the 'fetch', the bigger the wave as it absorbs energy from the wind. This is then dissipated when the wave breaks on a reef or shore...
http://www.seafriends.org.nz/oceano/waves.htm
The air closest to the surface of any spinning object tends to stick with the object. That's as true for hard drives and gyroscopes as it is for the Earth. The difference between the former two and the Earth is that the Earth's atmosphere has no outer element of friction, so it rotates with the Earth throughout its altitude.
I think the question has been mostly answered, but yes, friction... there's no (very little?) friction between "space" and the atmosphere, but there is friction (drag) between the Earth and the atmosphere...
Also, this is an interesting read... http://www.srh.noaa.gov/jetstream/global/jet.htm
Actually, the upper atmosphere is rotating faster than is the Earth itself. This is due to the diurnal bulge and due to interactions between the Earth's magnetic field and the partially ionized upper atmosphere, which in turn interacts with the neutral atmosphere.
Yeah, I guess it does spin faster, The jet stream would be proof... Right?
Not really. For one thing, the jet streams are rather small. For another, the jet streams are somewhat counterbalanced by the prevailing easterlies (the lower atmosphere under-rotates in the tropics). The super-rotation of the ionosphere encompasses much of the ionosphere and is a phenomenon quite distinct from the jet streams.
Related to Why the atmosphere spins with the Earth
1. Why does the atmosphere spin with the Earth?
The Earth's atmosphere is closely connected to the planet's rotation because of the force of friction. As the Earth rotates, the friction between the surface and the atmosphere causes the air to also rotate, becoming part of the same motion.
2. How does the atmosphere stay in place while spinning with the Earth?
The atmosphere stays in place due to the gravitational force of the Earth. Even as the atmosphere rotates, it is held in place by the Earth's gravity, preventing it from being spun off into outer space.
3. Does the atmosphere spin at the same rate as the Earth?
Yes, the atmosphere rotates at the same rate as the Earth because they are both influenced by the same forces. The atmosphere is connected to the Earth's rotation by the force of friction, causing it to spin at the same speed.
4. Can the Earth's rotation affect the atmosphere's weather patterns?
Yes, the Earth's rotation plays a significant role in shaping weather patterns in the atmosphere. The Coriolis effect, caused by the Earth's rotation, influences the direction and speed of winds and ocean currents, resulting in various weather patterns.
5. Is the Earth's rotation constant, and does this affect the atmosphere's spin?
The Earth's rotation is relatively constant, with only minor variations, and this does affect the atmosphere's spin. The steady rotation of the Earth helps to maintain the stability of the atmosphere, preventing it from being disrupted by sudden changes in motion.
  • Earth Sciences
  • Earth Sciences
  • Earth Sciences
  • Earth Sciences
  • Earth Sciences
  • Astronomy and Astrophysics
  • Earth Sciences
16K
