- #36
PeterDonis
Mentor
- 47,685
- 23,930
Austin0 said:Would this mean that the collapsing dust cloud [above] as it was approaching the Schwarzschild radius would be collapsing more rapidly on the surface with an increasing density and dilation gradient from there to a minimum at the center?
First, please note my later post in response to yuiop; his specific formulas only apply (I believe) to the case of a static equilibrium, *not* to the case of a collapsing object.
That said, your general intuition here is correct. As the object collapses, the density at its center increases, and the "time dilation" at its center becomes more extreme, relative to an observer far away (another way to look at it would be to say that the "potential well" inside the object becomes deeper). See next comment.
Austin0 said:Prior to the actual collapse and formation of the singularity at the center why would the clocks there be more dilated than at the surface??
Because there is a "potential well" there, and it gets deeper as the object collapses. Please note that the "potential", or "time dilation" factor, which is what we're discussing here, is different from the "acceleration due to gravity", which is what gets smaller as you go deeper inside a gravitating body (like the Earth) because more of it is above you, as I said in that previous post you quoted.
Also note that, strictly speaking, "acceleration due to gravity" only applies to a *static* observer, one who is "hovering" at a constant radial coordinate r. Once the object has collapsed inside its Schwarzschild radius, there are no such observers in the interior vacuum region inside the event horizon (i.e., outside the surface of the collapsing object but still below the horizon). (I'm not sure if there can still be static observers inside the collapsing object once it has collapsed inside the horizon; I think not, but I have not looked at the math in detail.)
