Why the energy that waves transfer is only dependent on amplitude
In summary, the energy that waves transfer is dependent on both their amplitude and frequency. Higher frequency waves will transfer more energy as long as the amplitude is kept constant. This is because more cycles per second means more power. However, this may not always be the case for all types of waves, as some, like water waves, may have different formulas for energy, speed, and wavelength.
Karagoz
Hi,
I wonder why the energy that waves transfer is only dependent on amplitude?
E.g. in this animation:
http://lifecdn.dailyburn.com/life/wp-content/uploads/2015/02/2.Alternating-Slam4.gif
The waves on the rope transfer energy to the items on the right side.
Wouldn't there be transferred more energy if the man produced faster waves, but with same amplitude?
Or waves transfer energy to the boat on water (by moving the boat up and down).
Even if the amplitude of the water waves was the same, with faster waves, the boat would move more up and down than if the waves were slower.
So wouldn't the waves transfer more energy to the boat if the speed of the waves was faster, even when the amplitude is same?
(btw, I'm very very new to physics).
Hey, i don't know if you know that or not, speed of the wave in a medium is constant for a given condition. So, for a given wave if frequency is constant then the wave transfer same energy for given amplitude. But if frequency increases then for the same time there will be more disturbance in the medium, so the energy transferred by that wave is more due to its frequency keeping the amplitude constant.
But what about frequency?
As higher the frequency, more will there be disturbance, hence more energy will be transferred?
Higher frequency in wave (not photons or light wave, but other waves) means more energy?
Is it? See the link sophiecentaur posted. It contains this equation..
Perhaps get a rope and try it out. Is it harder for you to shake the rope faster (eg at a higher frequency)?
Likes sanpokhrel
Is angular frequency is something similar to frequency of the wave, which is measured with Hertz?
This is what's written in physics textbook for students (translation):
"We know how water waves transfer energy to a boat. They put the boat into swings with same frequency as waves' frequency. How much energy the boat gets, is not dependent on the wave-frequency , but dependent on amplitude. Bigger the amplitude the waves have, higher the boat will get lift up, and thus more energy it will get. All waves, including sound waves too, transfer energy that way." (in later paragraphs it explains that photons and light waves work differently).
This is why I get confused.
Water ('surface') waves have a different formula for energy, speed and wavelength and they are not the best waves to discuss for a starter. It's best to sort out waves on strings or normal sound waves before getting involved with surface waves on fluids, which don't follow the normal rules.
Likes sanpokhrel
Good catch.
Yes, it means higher energy as long as you keep amplitude constant for the wave.
Related to Why the energy that waves transfer is only dependent on amplitude
1. Why is energy transfer in waves only dependent on amplitude?
Energy transfer in waves is only dependent on amplitude because amplitude is directly related to the magnitude of the wave. The larger the amplitude, the greater the displacement of the particles in the medium. This displacement causes a greater amount of energy to be transferred as the wave passes through the medium.
2. How does increasing amplitude affect energy transfer in waves?
Increasing the amplitude of a wave increases the amount of energy that is transferred. This is because a larger amplitude causes a greater displacement of particles in the medium, leading to a higher energy transfer as the wave passes through.
3. Is amplitude the only factor that affects energy transfer in waves?
No, amplitude is not the only factor that affects energy transfer in waves. Other factors such as frequency and wavelength also play a role in determining the amount of energy transferred. However, amplitude is a key factor that directly impacts the energy transfer in waves.
4. Can waves with the same amplitude have different energy transfer?
Yes, waves with the same amplitude can have different energy transfer. This is because the type of wave and the medium through which it travels can also affect the amount of energy transferred. For example, sound waves with the same amplitude can have different energy transfer in different mediums.
5. How does the amplitude of a wave affect its intensity?
The amplitude of a wave directly affects its intensity. The higher the amplitude, the higher the intensity of the wave. This is because intensity is a measure of the energy transferred per unit time, and as discussed, amplitude plays a crucial role in determining the amount of energy transferred in a wave.
  • Other Physics Topics
  • Mechanical Engineering
