Why the Fourier transform is so important compared to other?
In summary: The Fourier Transform is a very common function in signal processing and mathematics, so it is more likely that someone will be able to use it if they need to.
ramdas
79
I am engineering student and studying signal processing. The term Fourier transform comes in the discussion several times. There are many transforms like Laplace transform,Z transform,Wavelet transform.But as per my view ,Fourier transform is mostly used compared to others in general.
My question is why Fourier Transform is so important compared to others?I request you all while answering please add any link or video or figure for reference to understand the concept easily.Thank you in advance
I'll assume you have or will read the wikipedia article.
Mathematically the Fourier transform is just another transform to convert between numerical domains. It happens to have a useful physical significance since it converts between time and frequency domain, which is extremely useful.
But I can't say it is any more important that the others. For example digital signal processing relies on the Z transform. . No one says "take a z transform of the signal", they just convert the analog signal to digital (with an ADC, for example) and then they can run an FFT if they want to determine the spectrum.
Again, all transforms are important. But the Fourier transform happens to be a useful (well compartmentalized) function that can do something important that is easily understood in a physical system.
Likes psparky
One way of thinking about this is that the Fourier Transform is a certain special case of the Laplace Transform, namely by a few assumptions and the substitution s=jω. Time-frequency is something that can be measured, and we have a certain intuition about it because of our senses- we can hear tones. Whereas the kernals of the Z transform or the Laplace transform are on a domain that is more abstract, and their use is more generalized.
It seems like there is a certain trade off between keeping things general and having them be intuitive. For example, an extremely general 'integral' transform would be something like: Find the coefficients an such that
f(t) = Σantn
Which is almost just a Taylor series. Mathematically simple, but what kind of physical intuition do we get from an? Would someone build a machine that takes the time series and tells us the coefficients, like we can with a spectrum analyzer? Probably not. With wavelet transforms, it is general to the degree that you even need to specify what wavelet shape to use before you can begin.
My point is that the importance is mostly accessibility.
Related to Why the Fourier transform is so important compared to other?
1. Why is the Fourier transform so important in signal processing?
The Fourier transform is important in signal processing because it allows us to break down a complex signal into its individual frequency components. This allows us to analyze and manipulate the signal in a more efficient and accurate way, as well as extract important information about the signal's properties.
2. How does the Fourier transform differ from other mathematical transforms?
The Fourier transform differs from other mathematical transforms in that it operates in the frequency domain, rather than the time or spatial domain. This makes it particularly useful for analyzing signals that are periodic or have repeating patterns.
3. What are some practical applications of the Fourier transform?
The Fourier transform has many practical applications, including image and audio processing, communication systems, and medical imaging. It is also used in fields such as physics, engineering, and finance for data analysis and signal processing.
4. Can the Fourier transform be applied to all types of signals?
Yes, the Fourier transform can be applied to any signal that is continuous and has a finite energy. This includes both analog and digital signals, such as sound waves, electrical signals, and images.
5. Are there any limitations to the Fourier transform?
While the Fourier transform is a powerful tool, it does have some limitations. It assumes that the signal being analyzed is stationary and does not change over time. It also requires that the signal is periodic or can be represented as a sum of periodic functions, which may not always be the case for real-world signals.
  • Electrical Engineering
9K
  • Linear and Abstract Algebra
  • New Member Introductions
  • Science and Math Textbooks
  • Differential Equations
