Why the inductor voltage blows up for a sudden current change?
In summary, the conversation discusses the physical intuitive reason behind the voltage spikes that occur when the current through an inductor is suddenly stopped. Participants mention the collapse of the magnetic field, Faraday's Law, and Lenz's Law as factors contributing to this phenomenon. They also suggest conducting experiments and visualizing the lines of flux to gain a better understanding of the process.
Abhishek Dwivedi
Dear All,
This is my first question to the forum.
"Assume there is a + dc voltage across a inductor. So current will continue to increase. Now if the current through the inductor is forced to stop using some means ( eg. Current was flowing in inductor through a ON switch and then switch turns off in no time.) . I know the mathematical reason but I want to understand the physical intuitive reason about why the voltage across the inductor blows up.
Thanks
Abhishek
Magnetic field in the inductor collapses very fast. This gives rise to high voltage spikes as E=dΦ/dt. You may see sparks across the switch. Energy stored in the magnetic field is suddenly released.
Abhishek Dwivedi said:
...intuitive...
Well. If it'll be taken seriously then I'll deny that it's from me, but the way I think about this (before starting with the calculations) is something like 'this inductor wants to keep this current flowing, so it'll provide enough voltage on the terminals to make it possible - till the energy stored runs out'.
Thanks Helper. I also think the same. Please give me your feedback about what I think. " So Magnetic flux can't collapse in no time or current can't change in no time and to achieve it what inductor does is to generate a potential ( Faraday's Law) so as to maintain its current. But the current can't flow so inductor keep on increasing its potential in a hope to get the current go on . Current never flows as there is no path for it. So Inductor keeps on generating its voltage as high as it can before sparking.
Your reasoning sounds convincing, but I am not sure experts here will agree that it's the right approach.
If you want to know what happens "exactly" at the moment you open the switch or the sequence in which things happen, you'll have to go one level deeper i.e. Maxwell's equations or Electromagnetic wave theory and work with extremely short time scale.
As far as circuit theory is concerned, I find @Rive's reply spot on.
See if this old thread of mine helps.
https://www.physicsforums.com/threads/discharging-of-an-inductor.892992/.
Likes jim hardy
This should help
https://www.khanacademy.org/science...fields/magnetic-flux-faradays-law/v/lenzs-law
There's nothing like feeling something to make it intuitive. Have you ever been around an electric fence?
I'd suggest take an analog ohm meter and a small transformer not a big one.
Set to lowest ohms scale, RX1 if it has that.
Measure resistance of primary winding with secondary shorted, ie its wires twisted together.
Note where needle settles, and more importantly how quickly it moves to rest position.
Now untwist the secondary and repeat. Be careful hold the two primary wires in same hand on two different fingers . That'll keep any shock going through just that hand not through your body.
Needle should settle at same place but it'll get off to a slow start.
That slowness is the magnetic field building up inside the transformer.
You will notice a slight shock when you lift the test lead (or when it slips off) .
That is the transformer's magnetic field collapsing , Lenz's Law says it'll try to maintain the current that your ohm meter established.
Only place that currrent can flow is through your fingers.
That's why i said a SMALL transformer - running this experiment on ones over about a pound can be painful.
That's why i said hold the two wires in one hand , never subject yourself or anybody else to a whole body electric shock however mild.
old jim
Likes cnh1995
Dear All,
Thanks
Abhishek
This often come up and I offer a mechanical analogy. The inductor has inertia, like a moving mass, because it stores energy (in its magnetic field). To bring it quickly to a stop requires a large force. The force must be in the direction to provide braking, so must oppose the original accelerating force.
Likes Windadct and anorlunda
You have the idea just right.
"Anthropomorphizing" often helps us talk through a concept. You should refine your mental image to visualize the lines of flux surrounding the inductor, and how they'll move through the windings as the field collapses.
images here will help
http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/indcur.html
You're very close to saying: " charge buildup with opposite signs on the switch's open terminals, quickly increase the electric field". This electric field, which simultaneously reduces the current (and the mag.flux), also generates a spark when above a certain threshold. Integrating the electric field around a closed loop at any given instant will give you not zero, but exactly the induced fem (Faraday-Lenz), which in turn equals -dΦ/dt. The equations are coupled so as to transfer energy from the mag. field to the dissipative path of the sparking electrons.
If we think of the inductor as having inertia, it will try to keep the current flowing. If a perfect short circuit was applied to the inductor, the current would flow for ever, as in a superconducting magnet. To stop the current quickly we need a high reverse voltage, which could conceptually be applied from a reversed battery or by inserting a high resistance - the open switch.
Mechanical analogy is always nice, and may be the best answer to this "intuitive reason" type of question. It'll satisfy for most electric circuit basics. But the charge buildup is the only correct microscopic physical phenomenon explaining these rapid voltage surges, sparks, and so on. The flux inertia drives the inductor, but a simple resistor has also increased voltage across its terminals due to charge buildup and the resulting additional electric field: a high resistance path slows down charges inside, but is quickly offset and a current is set up.
FAQ: Why the inductor voltage blows up for a sudden current change?
What is an inductor and how does it work?
An inductor is an electronic component that stores energy in the form of a magnetic field. It consists of a coil of wire, usually made from a conductive material like copper, wrapped around a core. When a current flows through the coil, it creates a magnetic field that stores energy. The strength of the magnetic field is directly proportional to the current flowing through the inductor.
Why does the voltage across an inductor increase when there is a sudden change in current?
According to Faraday's Law of Induction, a changing magnetic field induces a voltage in a nearby conductor. When there is a sudden change in current through an inductor, it creates a sudden change in the magnetic field, which in turn induces a voltage in the inductor. This voltage can be much higher than the input voltage, causing the voltage across the inductor to "blow up".
How does the inductor voltage behave in a DC circuit?
In a DC circuit, where the current is constant, the voltage across an inductor will be zero. This is because there is no change in current, and therefore no change in the magnetic field, so no voltage is induced in the inductor.
What happens to the inductor voltage in an AC circuit?
In an AC circuit, where the current is constantly changing direction, the inductor voltage will also constantly change. When the current is increasing, the voltage will be positive, and when the current is decreasing, the voltage will be negative. However, the average voltage across the inductor will still be zero, since the positive and negative voltages will cancel each other out over time.
How can we prevent the inductor voltage from "blowing up" for a sudden current change?
One way to prevent the inductor voltage from reaching dangerously high levels is by using a diode in series with the inductor. This allows the current to flow in only one direction, preventing sudden changes in current and therefore limiting the induced voltage in the inductor. Another method is to add a resistor in series with the inductor, which can help dissipate the excess energy and prevent the voltage from "blowing up".
