Why the Moon Looks Big at the Horizon and Smaller When Higher Up.
In summary, the moon illusion, or oculomotor micropsia/macropsia, occurs when the focus of the eyes changes during natural viewing of the moon. This change in focus induces an illusion of angular size that varies depending on the distance-cue patterns available.
Rader
765
http://facstaff.uww.edu/mccreadd/intro4.html
Oculomotor micropsia/macropsia seems to be a truly fundamental angular size illusion. It shows up in many different kinds of visual spatial illusions (McCready, 1965, 1983, 1985, 1986, 1994a, 1994b, 1995). The present theory simply proposes that the moon illusion also is an example of the ubiquitous illusion of oculomotor micropsia/macropsia
Indeed, two independent researchers, J. T. Enright (1975, 1987b, 1989a, 1989b) ) and Stanley N. Roscoe (1979 1984, 1985, 1989) have demonstrated that oculomotor micropsia occurs during viewing of the "zenith" moon, and oculomotor macropsia occurs during viewing of the "horizon" moon:
In a nutshell, that can explain why the horizon moon looks angularly larger than the zenith moon.
A demonstration of oculomotor micropsia can be conducted by most readers as follows.
A Simple Demonstration.
The next time you look at the horizon moon, deliberately create oculomotor micropsia by strongly converging ("crossing") your eyes, say by looking at the bridge of your nose, but pay attention to the moon. That over-convergence of the eyes will create double vision of the moon and some blurring, but notice that the moon's angular size momentarily looks smaller than it did. At the same time, the moon will look either farther away than it did, or its linear size will look smaller, or else both of those secondary illusions will occur. That illusion imitates what occurs during viewing of the zenith moon. However, in this demonstration the apparent decrease in angular size undoubtedly is greater than the decrease found during natural viewing of the zenith moon. [Indeed, this demonstration of micropsia even works for the zenith moon, which already looks angularly smaller than the horizon moon.]
When you then return both eyes to being aimed straight ahead (their "far," divergence position) the moon will look single again and momentarily will look angularly larger than it just did (relative macropsia). Hence it also will look either closer than it just did, or its linear size will look larger, or else both of those secondary illusions will occur.
Try the experiment.
Astronomy news on Phys.org
could it have something to do with light and our atmoshphere. The sky is blye because of this, and at sundown, the sky is red. Our atmosphere allows differenct frequency photons at different possitions in the sky. I am wondering if this could be the solution.
The explanation in the link gives other reasons but this one seems to be proven by experimentation.
Distance Cue Control
The new theory points out that the reason the focus and convergence of the eyes change during natural viewing of the moon as it rises is because of changes in the visible patterns in the scene near the moon, which patterns are known to psychologists and artists as the many cues to distance, or distance-cues.
The most likely relationship is as follows: While one is viewing the horizon moon over a typical landscape, the details one sees in the landscape form distance-cue patterns that signal "very far" for objects at the horizon. Those distance-cues for "far" make the eyes adjust for a great distance, and that induces macropsia (larger apparent angular size) for the horizon moon.
On the other hand, the vista for the zenith moon typically offers relatively few distance-cue patterns, and when distance-cues are sparse, the eyes tend to adjust to a relatively near position, known as the resting focus position, about 1 or 2 meters from the face. That oculomotor adjustment to a relatively near point induces micropsia for the zenith moon
Cue Conflicts, Again.
The most common perceptions that the horizon moon either looks about the same distance away as the zenith moon or looks closer disagree with what is being 'signaled' by the distance-cue patterns responsible for the oculomotor micropsia/macropsia. As previously noted, other distance-cue factors are dominating the final percept. The report, "looks larger and closer" undoubtedly is due to relative perceived angular size cue. The report, "looks larger and about the same distance away," undoubtedly is the result of an intrinsic "equidistance tendency" (Gogel, 1965) or an "equal distance assumption" (McCready, 1965, 1985). The intermediate outcome illustrates a balance among the several conflicting distance cue patterns available.
If this is the explanation then I would have a question. How come when I sit in my room fully lite up, looking out the window the full moon looks larger and my focus is a cue, of the window fram inside the room at about 2 meters. It seems the cue does not have to be at a long distance it can be a short distance also, only a black sky, that drowns out the stars at a full moon, is no cue at all.
Go to Earth Science for the other answers, there is a few links there to blue skies and red sunsets. Could you pop over there and we could discuss this.
Related to Why the Moon Looks Big at the Horizon and Smaller When Higher Up.
1. Why does the moon appear bigger at the horizon?
When the moon is near the horizon, it is actually the same size as when it is higher up in the sky. However, our brain perceives it to be larger because we are comparing it to objects on the horizon, such as trees or buildings, which give us a sense of scale.
2. Is the moon actually closer to the Earth when it is on the horizon?
No, the moon's distance from the Earth remains the same regardless of its position in the sky. The moon's orbit around the Earth is elliptical, so its distance from us may vary slightly, but it does not significantly impact its size in the sky.
3. Why does the moon appear smaller when it is higher up?
As the moon rises higher in the sky, we lose the reference points of objects on the ground and our brain no longer perceives it to be as large. This is known as the Ponzo illusion, where objects appear smaller when surrounded by larger objects.
4. Does the moon's size change as it moves across the sky?
No, the moon's size remains constant as it moves across the sky. However, atmospheric conditions, such as temperature and humidity, can affect our perception of the moon's size due to the refraction of light.
5. Are there any other factors that can impact the moon's size in the sky?
The moon's apparent size can also be affected by its position in its orbit. When the moon is at its closest point to Earth (perigee), it may appear slightly larger in the sky compared to when it is at its farthest point (apogee). This is known as the "supermoon" effect, but the difference in size is generally not noticeable to the naked eye.
31K
