Why the square of the wave function equals probability?
In summary: What is Gleason's theorem?Gleason's theorem is a result in the mathematical field of probability that states that if a probability measure P is Borel measurable then the product of P and the Borel function is also Borel measurable.
Prem1998
148
If the problem is just to avoid negative probabilities, then why isn't the modulus of the value of wave function equal to the probability of finding the particle? I mean, is it proved by mathematics that the integration of the square of wave function value over a particular region is equal to the probability that the particle will be found in that region?
It's not proved by mathematics, it's proved by experiment. There are many interesting mathematical constructs out there. One of them - superimpose amplitudes and then square - yields results that match the way the universe is observed to behave, so that's the one we use.
Likes ShayanJ and vanhees71
What kind of experiment can possibly prove this?
Let's leave aside for a moment the well known fact that strictly speaking "proving" something by experiment is not usually considered possible , only disproving is so let's center on this. The Born rule is just the most reasonable probabilistic interpretation of the mathematical formulation of QM, in that sense there is nothing to disprove about the rule itself as long as the formalism works within its own premises and definitions of states and superpositions, transitions and observables. If you identify observables with operators you have to take into account the cross-terms and that must be reflected in the way you calculate probabillities, this obviously cannot be disproved with experiments anymore than the arithmetic operations can be.
For instance what the papers linked in the previous post show is that once one identifies observables with operators the experiments confirm quantum interference as the best approximation.
Because then you get the wrong answer.
This is not a proof, but an argument about consistency: First, physicists like analytic functions. The modulus of the probability amplitude is not analytic at 0. The squared modulus is. Second probabilities are purely relative until normalized so that they sum to unity. The "length" of a vector is the sum of the squares of its components. In QM state vectors are normalized to unity. When written as a superposition this means the sum of the square moduli of its projections should add to unity. So it is natural to treat the squared moduli of the projection of the state vector onto an eigenvector as being the probability of finding that eigenstate. However, it is important to remember that it is the unsquared projections that contain the physics. The relative phases of projections are physically significant (as in interference for instance) so the probabilities obtained by squared moduli do not completely describe all the physics. And when they do describe the physics they do so only in the form of an approximation to relative frequencies of mutiple measured outcomes and converge to exact multiple frequencies only for an infinite number of samples. The projections {probability "amplitudes") however describe a single system exactly.
Related to Why the square of the wave function equals probability?
1. What is the wave function in quantum mechanics?
The wave function, denoted by the Greek letter ψ, is a mathematical description of the quantum state of a physical system. It contains all the information about the system, including its position, momentum, and energy. It is used to calculate the probability of finding a particle in a specific state.
2. Why is the square of the wave function used to calculate probability?
In quantum mechanics, the probability of finding a particle in a specific state is given by the square of the wave function. This is known as the Born rule, and it is a fundamental principle of quantum mechanics. It is based on the idea that the magnitude of the wave function represents the probability amplitude, and the square of this amplitude gives the probability of finding the particle in that state.
3. How does the square of the wave function relate to the position of a particle?
The square of the wave function represents the probability of finding a particle at a specific position. This means that the higher the value of the wave function at a particular position, the higher the probability of finding the particle at that position. The square of the wave function also gives information about the spread or uncertainty in the position of the particle.
4. Why does the square of the wave function represent the probability and not the wave function itself?
In quantum mechanics, the wave function is a complex-valued function, and the probability of finding a particle in a specific state must be a real number. The square of the wave function is always a real number, making it a suitable representation of probability. Additionally, the square of the wave function obeys the normalization condition, which ensures that the total probability of finding the particle in all possible states is equal to 1.
5. How does the square of the wave function change over time?
In quantum mechanics, the wave function evolves over time according to the Schrödinger equation. As the wave function evolves, the square of the wave function also changes, which means that the probability of finding the particle in different states also changes. This is what allows us to make predictions about the behavior of quantum systems and understand how they change over time.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
