Why the term diffraction in XRD
In summary, the term "diffraction" in XRD refers to the bending of x-rays at the corners of crystals, which results in a non-rectilinear deviation of light. This phenomenon is different from traditional reflection or refraction and is better explained through interference. However, interference and diffraction are not mutually exclusive and can sometimes both be used to explain certain phenomena, such as the appearance of colors on an oil slick. The term itself may be considered a misnomer, but it is widely used in the field of XRD.
abhi2005singh
63
Why the term "diffraction" in XRD
When there is selective reflection of x-rays from crystals, why the phenomena is called "diffraction"? As we know that diffraction is associated with the bending of waves at the corners of any obstacle, here there does not seem to be any bending around the corner. So why the name diffraction? Since it is an interference between the waves emitted from the upper and lower plane of atoms, shouldn't it be called "interference"?
Some possible answers can be the following:
1. It is an unfortunate misnomer. (One of my colleagues told me this recently)
2. The idea of diffraction stated above is not correct or we can say it is not accurate. Then how to define "diffraction"?
Diffraction on atoms is first, interference is second.
There's two answers here (but I'm sure there may be others):
First of all, the assumption of specular reflection from "planes of atoms" is a very big assumption to make. Indeed, with XRD wavelengths being on the order of (and usually smaller than) the atomic spacing, how can one ever assume specular reflection?! The only reason the Braggs' simple explanation was so convincing is that it gave the correct results.
(Still on the first answer) Now a proper derivation of Braggs' law requires a Fourier analysis on a reciprocal space of the crystal lattice (i.e. the reciprocal lattice). The end result is a non-rectilinear deviation of a ray of light that is neither due to reflection nor refraction. Such is the definition of diffraction.
The second answer (somewhat of a more general nature): Interference and diffraction are not entirely separate entities. It is true that there are cases that can only be explained through interference or through diffraction, but there are cases where either explanation does suffice.
Examples:
1) The appearance of colors on a watery oil slick is properly explained by interference.
2) The inability to focus light to an infinitesimal spot is properly explained by diffraction.
3) Young's double slit experiment is properly a problem of diffraction, however, it can also be explained as the interference of secondary Huygens waves.
It is interesting to note, however, that lots of XRD specialist (at least coming from a materials engineering background) tend to talk about "x-ray reflectometry" as a synonym for XRD.
Thank you all for the help.
Related to Why the term diffraction in XRD
1. What is diffraction in XRD?
Diffraction in XRD (X-ray diffraction) is a technique used to analyze the atomic and molecular structure of materials. It involves shining X-rays onto a sample and measuring the resulting diffraction pattern, which can provide information about the arrangement of atoms in the sample.
2. Why is the term "diffraction" used in XRD?
The term "diffraction" is used because the X-rays are diffracted, or scattered, by the atoms in the sample. This scattering produces a unique diffraction pattern that can be analyzed to determine the structure of the material.
3. How does XRD use diffraction to determine structure?
XRD uses the principles of Bragg's Law, which states that when X-rays are incident on a crystal, they will be diffracted at specific angles determined by the spacing of the crystal lattice. By measuring the angles and intensities of the diffracted X-rays, the atomic and molecular structure of the sample can be determined.
4. What are some applications of XRD and diffraction?
XRD and diffraction have a wide range of applications in materials science, geology, chemistry, and physics. They are commonly used to analyze the structure of crystals, minerals, and other solid materials, and can provide valuable information for research and development in various industries.
5. Are there any limitations to XRD and diffraction analysis?
While XRD and diffraction are powerful techniques for structure analysis, they do have some limitations. They may not be suitable for analyzing non-crystalline or amorphous materials, and the sample must be prepared in a specific way to obtain accurate results. Additionally, XRD cannot provide information about the chemical composition of a sample, so it is often used in conjunction with other analytical techniques.
