Why the vector equation of Line in threedimension is defined that way?
  • Thread starter Muthumanimaran
  • Tags
    Line Vector
In summary: This is all we need to find the equation of a line, but what if we want to find the direction of S vector? That is what we need the new vector V for. So we can say that tV is the vector that points in the direction of S vector.
Muthumanimaran
81
In three dimesnion, equation of a Line is determined using a fixed point on the line and any arbitrary point on the line and position vectors of these two points be r0 and r, then the equation of line is given by r-r0=S (by triangle law of addition), and this S is written as scalar times a vector which is parallel to it( let it be tV) (and I know if two vectors are parallel we can represent one vector as scalar times of another vector) and get the equation of Line r=r0=tV
But what is that S vector and to find the direction of S vector why do we need a new vector( let it be V) which is parallel to this S vector? and how do we know this new vector V is parallel to S vector?
Welcome to PF!
Hi Muthumanimaran! Welcome to PF! :smile:
I'd put it this way:
to define a line, choose any two points on the line, A and B (and let the origin be O)
then a general point P on the line has AP parallel to AB, so we can write AP = tAB,
so OP = OA + AP
= OA + tAB​
ie r = ro + tV (where V = AB) :wink:
This is, I assume, a typo- you mean r= r0+ tV.
?? We "know this new vector V is parallel to S vector" because it is defined that way: "S is written as scalar times a vector which is parallel to it( let it be tV)".
As for "what is that S vector", it is exactly that you say, r- r0, and, so can be thought of as the vector from r0 to r and so a vector pointing in the direction of the line.
You don't really need a new vector "V". The point is that the length of the vector S is not relevant- any two points on the line would give a vector "S" in the same direction but with different lengths. Some texts might want to define V to be a unit vector but, again, the length doesn't matter.
Thank you tiny-tim
When we have to define a line, we can do it if can give all points on that line. But the process is difficult because there are infinitely many points on a line. So we can give an equation so as to generalise the points on the line. The equation is nothing but r=r0+tV.
When we are giving the above equation we are just saying that "you go to the point r0 are start moving along the direction of the vector V, you will get all the points, in other words the line required". Thats why you need the parameter tV.
Related to Why the vector equation of Line in threedimension is defined that way?
1. What is the purpose of using a vector equation to represent a line in three dimensions?
The vector equation of a line in three dimensions is used to provide a more efficient and concise way of representing a line. It allows for easy calculation of points on the line and can be extended to represent planes and higher dimensional objects.
2. Why is the vector equation of a line defined as r = a + tb?
The vector equation of a line is defined as r = a + tb because it represents all the points on the line that can be obtained by starting at a fixed point, a, and moving any distance along the line in the direction of the vector b. This allows for flexibility in representing different lines with varying orientations and positions in space.
3. How is the vector equation of a line related to the parametric equations of a line?
The vector equation of a line can be thought of as a combination of the parametric equations of a line, which represent the x, y, and z coordinates of a point on the line in terms of a parameter, t. The vector equation simply combines these equations into one vector expression.
4. Can the vector equation of a line be used to represent a line in any direction?
Yes, the vector equation of a line can represent a line in any direction in three dimensions. This is because the vector b in the equation represents the direction of the line, and it can take on any value in three-dimensional space. This allows for the representation of lines in any orientation and direction.
5. How is the vector equation of a line used in practical applications?
The vector equation of a line is used in many practical applications, such as computer graphics, engineering, and physics. It allows for precise representation and calculation of lines and can be extended to represent planes, curves, and other objects in three-dimensional space. It is also used in vector calculus to solve problems involving lines and other geometric objects.
  • Calculus
  • Linear and Abstract Algebra
  • Calculus
