Why there are no other kind of length contractions?
  • Thread starter smm
  • Tags
    Length
In summary, the experimental results seem to show that no other form of length contraction or expansion exists in nature. It has never been observed in for example particle experiments or in astronomy. It is not a result that would deny them of course. What is the true reason, why they do not exist? It is unclear to the summarizer why they do not exist. It may violate some theoretical principle.
smm
31
hi!
i have asked about this issue, but i think i haven't got good answer to the question. can you help me, short answer would be good.
its unclear to me still why there are length contractions or
expansions other than lorenz contraction? Is there a theoretical principle or
result that deny them?
also, is it possible that some object could have length contraction or expansion
when it is in the same inertial reference frame, or does some theoretical principle deny it? this is my question.
the experimental results seem to point out that no other kind of length contractions or expansions exist in nature - they have never been observed in for example in particle experiments (all particles have same identical size), or in astronomy (all atoms in observed universe has exactly same size) . but this is not a result that would deny them of course. What is the true reason, why they do not exist?
if i give you an equation (to be exact), an example of isotropical length expansion/contraction of object that has relative velocity v=0, that is, it is in the same inertial reference frame than its observer. can you say at first sight is there something wrong with it? does it violate some principle?
transformation equation:
let there be two regions of space a and a' and two observers o' and o who are in these regions.
let relative velocity be zero v=0 and lorenz factor B=1, that is,
both regions and observers are in the same rest reference frame.
definition: if region a' has isotropical length expansion or -contraction,
observer o' measures unit length of any object ds =[dx',dy',dz'] to be
dx'= L dx
dy' = L dy
dz'= L dz
where L is contraction factor; if L>1 region a' (and observer o')has length
contraction
if 0<L<1 region a' has length expansion
quantum mechanics seem also to demand that length contraction must have
also different dynamical properties, if you think le broglie wavelength:
if Planck's constant h'=h both observers observe Planck constanst to be same
AND
le broglie wavelength of any particle measured by o' is l'=h/p' = L (h/p)
implication:
=> p'= (1/L) p observer o' measures any momentum p to be (1/L) times larger
=> E'= (1/L) E
m'= (1/L) m observer o' measures any object to have (1/L) times more energy
and mass
and if time dilation has always strict relation to momentum (as it has for
relativistic particles: dt'=Bdt and p'=(1/B)p => dt'/dt = p/p')
(dt'/dt) = (p/p')
=> dt'= L dt observer o' measures time dilation or expansion L
for any object compared to observer o s observation
example:
if a free neutron would have isotropical length contraction L=1.05:
-neutrons radius would be 1.05 times smaller
-neutrons momentum, mass and rest energy would be 1.05 times larger
-neutrons decay time would be 1.05 times faster (if L is constant)
example 2:
if L oscillates (or vibrates) L = (sin^2)(at) + L0 a is constant
-particles mass, momentum and energy would oscillate
-if two identical particles would collide, their trajectories after
collision would depend on both particles momentum in the moment of
collision. if you don't know the particles exact momentum at the moment of
collision, or their phases, you would have to use propability function.
but wait a minute, is this similar kind of propability function that the
shrödingers wave equation is? in other words can you assume that particles
mass ,energy, momentum, time rate and size oscillates, and its phase is
random variable -and get out quantum statistics similar than what is based on schrödingers wave equation?
(please do not consider this part a speculation. this is mathematical
question: can you get shrödinger equation from these assumptions?)
**i am asking a question, i don't speculate over existing theories, and please do
not think that i am advocating any very stupid crackpot things, or that i am not
satisfied with relativity theory - i am not stupid. i simply want to know theoretical reason why there are no other kind of length contractions - or is there such reason. i just don't have casual interest on physics and i am curious about this issue. a short answer will be good.**
I'm not really sure I understand your question. Why are there not more kinds of length contraction? Well, why are there not more planets in our solar system? Why are there not more fundamental particles in the Standard Model?
We don't see other types of length contraction, so why try to describe them?
"...can you help me, short answer would be good."
Based on your previous posts, shorter questions would be better, and I agree with the previous poster. Science is concerned with phenomena that are observed, and why they are there, not with phenomena that are not observed and why they are not.
The value of unseen phenomena lies in their falsification of hypotheses entail by theories explaining phenomena that do exist.
E.g. if hypothesis X should entail the appearance of (detectible) magnetic monopoles under condition(s) Y, where are the monopoles? The absence of monopoles then falsifies the theory that demands X.
"Why don't we see anisotropic 'expansion'" can only serve as a rhetorical response to an experiment that should have shown anisotropic expansion under a hypothesis X necessary to a theory that would explain something that has us scratching our heads.
What, exactly, do you mean by "length contractions or
expansions other than lorenz contraction"?
**DanR please you don't have to remind me of my earlier post that are badly edited and frankly, piece of crap, and they should be deleted.
why space don't ever contract other ways than in lorenz contraction? The lorenz contraction seem to be a weird single phenomenom of a relative particle or region of space that does not seem to exist elsewhere in physics (and it also exist always together with time dilation and increased momentum).
smm, is your question along the lines of "time dilates with changes in gravitational potential, as shown by the Erza Pound experiments. Why doesn't length change with gravitational potential?"
dx'= L dx
dy' = L dy
dz'= L dz
contraction
This is a perfectly valid transformation, and I have seen such a thing happen many times myself. I used to drive from Lansing, Michigan to Toronto, Ontario. Upon crossing the border into Canada I found that all lengths were expanded by a factor of 1.6. Luckily, since the expansion was isotropic my car's tires also expanded and I was still able to cover the expanded distances in the same amount of time as I would have if the expansion had not occured.
Now, if you don't mean a unit conversion, then such a transformation would not be inertial. E.g. Newton's second law is not invariant under the transformation but goes from f=ma to f=Lma.
to put the question in one hitline:
"why the space or particle in its own rest reference frame DO NOT have contractions ,ever?"
-what is the reason why space or particle do not have contractions or expansions in rest? is there a deep principle or fundamental reason why it does not have any contractions or expansions in rest?
The contractions are a matter of perspective. It is a similar reason why an object at rest with regard to you has no momentum, while someone moving with respect to you will measure it to have momentum.
Uh ... you really are beating a dead horse here. You need to come up with a reason why they SHOULD have contraction or expansion if you think they should, not keep asking why something that doesn't exist doesn't exist.
I already answered this.
let me write here my motivation for the question:
-it is a known fact that space or a particle can contract when it has
a relative motion. therefore it is reasonable to ask is it possible that
the space or particle can contract under other conditions, for example: can
it contract when it is at rest? this is a phenomenon that has never been
observed, but quantum mechanics, electromagnetism, special relativity and
classical dynamics do not either deny its existence.
it seems that it is additional postulate : space do not contract at rest. There are no known reasons for this, but it is very comfortable to postulate it since experimental results in high energy particle physics has never encountered such phenomenom. it is almost comes without saying.
but if some experiment in the future would encounter a particle that is at
rest and has some kind of length contraction, no theoretical physicist would
either say directly that its impossible phenomenom.
but if such length contraction can exist, that has very "wild" concequence:
in theory, you can then contract any particle or region of space into
a very small volume or expand it into a very large volume. for example
in theory, you can expand neutrino to a size of a sun. there is not deep
reason why this would not be possible but also it is true that there are no known methods that can do this, no known process in the world can contract or expand particles.
Dalespam, you don't take into account a possibility that length contracted particle or region of space may have also different dynamical properties: different rest mass, momentum, energy, time dilation and strengthness of 4 principal interactions.
You're not going to get a different answer. Yes, there may be "other types of length contraction," just like there may be a teapot orbiting the sun and just like there may be a flying spaghetti monster. However, since we do not see any of these phenomena, we do not build our theories to reflect them.
smm said:
-it is a known fact that space or a particle can contract when it has a relative motion.
This is not very clear. It takes at least two things to have relative motion - so how can one thing possesses this, as if it were a property ?
NanakixIII i think my hitline question above is valid. "what is the theoretical basis of the assumption or fact that space do not contract in rest? does any accepted theory have anything to say to it? or is it a postulate?"
am i right NanakixIII that You do a "categorical mistake" if you say that its worthless to think possibilities and restrictions of mathematically well described physical theories in the basis of argument that its worthless to think every kind of possibilities imaginable?
a relative motion.
"relative motion" is not an objective property which a space or particle "has" that causes it to objectively "contract." relative motion is a description of the situation which exists between the observer and the object - not completely dissimilar to the case when a moving object appears to shrink when it is moving away, or the fact that from Earth we only see one half of the Moon's surface. Physics works whichever inertial reference frame you use. You can use the frame of the object rather than your own rest frame, and in that case, you will not find any contraction.
You understand that for an observer traveling along with that "space or particle" there is no contraction, right?
Yes. I took it into account. I specifically said that the dynamical properties would necessarily change so that Newtons law would change from f=ma to f=Lma.
There are only two possibilities here: either you are talking about a change in units, or you are talking about a non-inertial transform.
You have asked about the theoretical basis. That would be the principle of relativity. The principle of relativity, when reduced to math, requires that inertial transforms be symmetric under spatial translations, temporal translations, spatial rotations, and boosts.
Length contraction / time dilation arise because of the differences in spacetime geometry between two moving objects (their relative motion). Once the geometry side of SR is understood, I don't think your question will stand. It really doesn't make sense...from a geometric perspective.
Interesting sci-fi perspective though, perhaps we will manipulate the temporal dimension to accelerate our flying saucers of the future. :smile:
Dalespam,
if the contracted space or particle has also time dilation or "fastness",
that would mean all its phenomena have slowed down or accelerated by some
factor- because the time rate effects to all physical processes.
that would mean that observer o' can measure different F' than what observer o
smm said:
Dalespam,
I think that is what is called a scale transformation. The laws of physics are not invariant under scale transformations. You should work this out for yourself. What would Newtons laws and Maxwells equations look like under a scale transformation?
From a theoretical point of view, space does not contract at rest because relativity theory is built like that. It follows from the basic postulates of the theory that length contraction occurs between moving frames of reference; that the smaller the velocity of this movement, the smaller the effect of contraction; and when the velocity vanishes, so does the contraction. "Space does not contract at rest" is not a postulate in itself.
I'm not really sure I understand your second question. Are you asking if one should consider every mathematically consistent theory, or at least not deny them?
You should not consider them. There are inifinitely many things you can do mathematically, and you can't consider them all. You'd just be taking stabs in the dark, like you are doing now.
I'm not saying you should deny them if they're not falsified, and nobody here is denying anything. There might be other types of contractions. The problem with your proposal is that it is not falsifiable and therefore of little scientific use. Compare it to Russell's Teapot.
FAQ: Why there are no other kind of length contractions?
Why do objects appear to be shorter when they move at high speeds?
The phenomenon of length contraction occurs because of the effects of special relativity. As an object approaches the speed of light, its length appears to decrease in the direction of motion according to an observer who is stationary relative to the object. This is due to the time dilation effect, where time slows down for objects moving at high speeds, causing them to appear shorter.
Is length contraction only applicable to objects moving at speeds close to the speed of light?
Yes, length contraction is only significant for objects moving at extremely high speeds, close to the speed of light. At everyday speeds, the effects of length contraction are negligible and cannot be observed.
Can length contraction be observed in everyday life?
No, the effects of length contraction are only significant at speeds close to the speed of light, which is much faster than anything we encounter in our daily lives. Therefore, we cannot observe length contraction in everyday situations.
Are there any exceptions to the phenomenon of length contraction?
The phenomenon of length contraction is a fundamental principle of special relativity and applies to all objects moving at high speeds. However, it is important to note that length contraction only occurs in the direction of motion and not in other dimensions.
How is length contraction related to time dilation?
Length contraction and time dilation are two sides of the same coin and are both consequences of the theory of special relativity. As an object's speed increases, its length appears to decrease in the direction of motion, while time slows down for the moving object. This is why the effects of length contraction and time dilation are always observed together.
9K
