zenterix
- 706
- 84
- Homework Statement
- In deriving the rotational work-kinetic energy theorem, the approximation is used that for small displacements
$$\frac{d\omega_z}{dt}d\theta=d\omega_z\frac{d\theta}{dt}=d\omega_z\omega_z\tag{6}$$
Why is this true?
- Relevant Equations
- Suppose we have a rigid body rotating about an axis and let ##S## be a point on this axis.
Define a coordinate system such that the ##z##-axis coincides with the rotation axis.
If there is a net external torque on the system about ##S##, then this net torque vector must have its direction on the ##z##-axis (since the system is only rotating about this axis at all times).
This torque generates angular acceleration
$$\tau_{S,z}=I_S\alpha_z\tag{1}$$
where ##I_S## is moment of inertia about the axis of rotation and ##\alpha_z## is the z-component of angular acceleration, ie ##\vec{\alpha}=\alpha_z\hat{k}##.
The force generating the torque does work as the rigid body rotates from an initial angle ##\theta_i## to ##\theta_f##.
$$W_{rot}=\int_{\theta_i}^{\theta_f}\tau_{S,z}d\theta\tag{2}$$
$$=\int_{\theta_i}^{\theta_f} I_S\alpha_zd\theta\tag{3}$$
My question is about getting from this equation to a relationship with kinetic energy.
We have
$$dW_{rot}=I_S\alpha_zd\theta\tag{4}$$
$$=I_S\frac{d\omega_z}{dt}d\theta\tag{5}$$
The notes I am reading say that "in the limit of small displacements"
and so
$$dW_{rot}=I_Sd\omega_z\omega_z$$
and when we integrate this we easily reach the conclusion that ##W_{rot}=\Delta K_{rot}##.
But why is (6) true?
We have
and so
