Why topological insulators are topological?
In summary: Essentially, I give you a Hamiltonian, perhaps I give you a symmetry you must respect, and I tell you that the gap must not close. You are free to deform my Hamiltonian all you want, but you must respect the two conditions of symmetry and finite gap. Topological insulators may be characterized by saying that there are two (or more) different gapped states associated to two different Hamiltonians which can never be deformed into each other without either breaking the symmetry or closing the gap. Note that symmetry is not always required.As an example of a topological insulator called a Chern insulator, consider a two band model in two dimensions. Neglecting uniform onsite energies, a general Hamilton
urric
Hi, this is my first post here!
I've been studying about topological insulators, but still I can't understand why this materials are called topological, I've read about topological analogy between the donut and the coffee mug and the smooth changes on the Hamiltonian, but I can't get the full picture, can somebody please explain this to me? or can you direct me about an article with an easy explanation about this.
thanks
Basically, I give you a Hamiltonian, perhaps I give you a symmetry you must respect, and I tell you that the gap must not close. You are free to deform my Hamiltonian all you want, but you must respect the two conditions of symmetry and finite gap.
As an example of a topological insulator called a Chern insulator, consider a two band model in two dimensions. Neglecting uniform onsite energies, a general Hamiltonian may be written in terms of a vector [itex] d^a(k) [/itex] where k sits in the Brillouin zone, a two dimensional torus. In momentum space the Hamiltonian is [itex] H(k) = d^a(k) \sigma^a [/itex]. The requirement that the gap remain finite is simply the requirement that [itex] || d || > 0 [/itex]. [itex] d^a [/itex] lives in three dimension, but the point at the origin is removed. Three dimensional space with a point removed is topologically equivalent to a two dimensional sphere. In the Hamiltonian language, you get the sphere by replacing [itex] d [/itex] with [itex] \hat{d} = d^a/||d|| [/itex] i.e. by normalizing it. This doesn't change any of eigenvectors, it only deforms the energies, and it is always possible if [itex] ||d|| > 0 [/itex].
Now the punchline is that [itex] \hat{d}(k) [/itex] defines a map from the two dimensional torus (k space) to the two dimensional sphere (space where [itex] \hat{d} [/itex] lives). Deforming the Hamiltonian is deforming this map, but such maps are labelled by a topological integer called the winding number, and this number does not change under smooth deformations. This number is called the Chern number and physically it gives the Hall conductivity, but the point here is that it also labels different inequivalent gapped Hamiltonians. If you're just beginning, it is essential to play with these maps a bit e.g. try constructing one.
Topology enters in many other places and with many elaborations. However, I hope that this helps make contact between the two fundamental ideas you mentioned: deformation of Hamiltonians and topological invariance e.g. donut = coffee cup.
Did you get any nice explanation of why these are called topological insulators?
If so Please share the same.
I don't need any mathematical explanation I just need to know based on physical sense.
And also do you have any nice explanation of Z2 topological order.
Thanks!
Related to Why topological insulators are topological?
1. What is the difference between a regular insulator and a topological insulator?
A regular insulator is a material that does not conduct electricity due to its large band gap, whereas a topological insulator is a material that is insulating in its bulk, but has conducting surface states due to its unique electronic band structure.
2. How are topological insulators different from other types of materials?
Topological insulators are unique in that they have a band structure that is topologically protected. This means that certain properties, such as the number of surface states, are guaranteed to be the same as long as the material maintains its topological properties, regardless of its shape or size.
3. What is the significance of the "topological" aspect of topological insulators?
The "topological" aspect refers to the fact that the electronic band structure of topological insulators is determined by the topology, or shape, of the material rather than its chemical composition. This makes them fundamentally different from other types of materials and allows for their unique properties.
4. How do topological insulators exhibit protection against disorder?
Topological insulators have a robustness against disorder due to their topologically protected surface states. These states are robust against impurities or defects in the material, making topological insulators promising for potential applications in quantum computing and other technologies.
5. What are some potential applications of topological insulators?
Topological insulators have potential applications in various fields, such as spintronics, quantum computing, and energy harvesting. They can also be used in creating new types of electronic devices with unique properties, such as low-power consumption and high-speed performance.
  • Atomic and Condensed Matter
